Radiator Petcock Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TnShooter, Oct 14, 2019.
  1. Oct 14, 2019 at 7:45 PM
    TnShooter
    TnShooter [OP] The TacomaWorld Stray
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Just getting around to doing a cooling system drain.
    The petcock is plastic, what's the chance it breaks off the little wings you use to unscrew it?
    And how tight does it need to be when tightening it back up?
    Is it sealed by an o-ring or just direct contact seal?
    I don't want to mess it up, old plastic scares me. I can just see it breaking. Yikes.
  2. Oct 14, 2019 at 7:46 PM
    Bishop84
    Bishop84 Well-Known Member
    Finger tight, it seals before its even tight,
    to loosen try by hand, otherwise a small pair of plyers, or an old secret, a 22mm wrench fits on the wings.
    SR-71A, llamasmurf and TnShooter[OP] like this.
  3. Oct 14, 2019 at 7:53 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    22 mm socket works great. Just don't over tighten it.
  4. Oct 14, 2019 at 8:34 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Lol, petcock
  5. Oct 16, 2019 at 8:13 PM
    TnShooter
    Deogee
    STOCK
    Thanks man.
    I was hoping you’d respond.
    I figured if anyone would know you’d probably know best.
    I’d say you’ve done more than a few by now.:thumbsup:
  6. Oct 16, 2019 at 8:19 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Never had a problem in 17 years
  7. Oct 16, 2019 at 8:21 PM
    op9nf
    op9nf Well-Known Member
    Nilo
    Bothell,Washington
    2013 Tacoma TRD DCLB 4X4
    Bilstein 5100’s With OME 288. 2inch blocks with freedom off-road extended shocks.
    Hey Bill, it’s that a 1/4 to 1/2 adapter you’re using to loosen the drain wing?
  8. Oct 17, 2019 at 4:15 AM
    Plain Jane Taco
    USA
    That 22 mm socket is a 1/2" and the ratchet is 3/8".....so a 3/8" to 1/2" adapter
    Climberclimb likes this.
  9. Oct 17, 2019 at 1:20 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    This ^ go easy and you will be fine,the valve wings are nylon ,not plastic so they wont break so easy.
    Skyway and TnShooter[OP] like this.
  10. Oct 24, 2019 at 12:08 AM
    TnShooter
    Deogee
    STOCK
    Any tips on bleeding the system of air?
    Going to try to get this done this weekend.
    Thanks man.
  11. Oct 24, 2019 at 1:54 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Lester Lugnut, b_r_o and Rob MacRuger like this.
  12. Oct 24, 2019 at 4:53 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    Does the skid plate need to come off in order to loosen the drain screw?
  13. Oct 24, 2019 at 6:58 AM
    Rob MacRuger
    Rob MacRuger Well-Known Member
    2006 4X4 SR5 4.0
    No but it makes it much easier. I have always used a 13/16” socket on mine and the fill kit above is worth it.
    spitdog[QUOTED] likes this.
  14. Oct 24, 2019 at 6:37 PM
    Bishop84
    Funnel is best, but you just leave the cap off, keep adding until you have consistant cabin heat.
    The heat in the cabin means good flow and no air in the heater core, which is the hardest place to remove the air.
    Usually I let it idle for 5 minutes, then start to rev 2000-3000, until heat. If no heat in cabin, I'll shut it off and try to let it settle and burp for a minute. Repeat.
    On REALLY bad bleeds, I'll jack the front of the truck up.
  15. Oct 24, 2019 at 8:46 PM
    TnShooter
    Deogee
    STOCK
    Leave the cap OFF with the engine running until warm air is felt in the cabin?
    The FSM, says to replace the cap, and warm engine with heat to Warm and fan ON, then let it cool and add more coolant if needed.
    That seems like it would take awhile, as waiting for it cool would make the job take a good while.
    Thanks Bishop.:thumbsup:
    The way you stated above is the way I’ve typically done it in the past.
    But, I did have a headache with a Nissan Altima once. Almost never got the air out of the system.
    I never want to deal with one of those again.....EVER.
    You are absolutely right about jacking the front up to get the air out.
    On the Altima, I had to find a steep drive way (really steep) to get it working.
    Thank goodness the Tech @ Nissan felt sorry for me. He told me what to do.
    That’s really the reason I asked the question.
  16. Oct 25, 2019 at 8:25 AM
    TnShooter
    Deogee
    STOCK
  17. Oct 25, 2019 at 10:56 AM
    spitdog
    I never used one of those funnels either, I always just kept the radiator full, let it idle with the cap off, heater on, and top off as needed. How does the funnel make it any easier? I’m just replacing a gallon’s worth in the radiator by the way.
  18. Oct 25, 2019 at 11:31 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    spitdog likes this.
  19. Oct 25, 2019 at 12:35 PM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    80% less mess! Don't fill the funnel to the top, 1/4 or halfway is enough.
  20. Oct 25, 2019 at 12:36 PM
    spitdog
    Would this work? Fill radiator to top, screw on radiator cap to first click, put heater on and go for a drive for 15 min. Come back and top off radiator. By putting cap on first click, won’t that let the air escape the system?
