Radiator mount hole doesn’t line up!!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Zingsauce, Jul 21, 2020.
  1. Jul 21, 2020 at 7:34 PM
    Zingsauce
    Zingsauce [OP] Active Member
    Brian
    San Deigo CA
    2019 tacoma DCSB
    Kings 2.5 with adjusters Built right UCA DAKAR medium leaf pack Wheelers U-bolt flip kit with timbrens Method 315 wrapped in Falken wildpeaks AT3W 285/75/16
    Hey guys. I decided to replace my radiator mount bushing due to squeaking. Everything is all fine and dandy until I tried lining up the hole for the bolt to go through.
    Any tips on how to line up the holes?
    It’s getting dark here in San Deigo, might have to uber to work tomorrow if I don’t get this sorted out. Lol
  2. Jul 21, 2020 at 7:58 PM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Jack it up again and use a crow bar or piece of metal between the mount and the pinch weld to move it.
  3. Jul 21, 2020 at 8:00 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Yeah work it OP. Jack it up and see if u can get it started. Started as in like a full nut, not like 1 or 2 threads.
  4. Jul 21, 2020 at 8:28 PM
    Zingsauce
    Brian
    San Deigo CA
    2019 tacoma DCSB
    I tried using a crow bar and couldn’t get it to line up. I’ll try again tomorrow when I have more daylight.
    I left the upper bushing on there without the bolt, is that a bad idea?
  5. Jul 21, 2020 at 8:30 PM
    Zingsauce
    Brian
    San Deigo CA
    2019 tacoma DCSB
    I’ll give a shot tomorrow when I have more daylight. For now, it’s park in the driveway with the upper bushing mounted but no bolt.
    Skydvrr[QUOTED] likes this.
  6. Jul 21, 2020 at 8:31 PM
    Grossomotto
    2017 4WDV6LB6MT
    It'll be fine as long as you don't move the truck :)
    Zingsauce[QUOTED][OP] likes this.
  7. Jul 21, 2020 at 8:34 PM
    Zingsauce
    Brian
    San Deigo CA
    2019 tacoma DCSB
    I backed it out from my garage to the driveway very very slowly. It’s parked slightly inclined....sigh
    Skydvrr and Bleep100 like this.
  8. Jul 21, 2020 at 8:41 PM
    Grossomotto
    2017 4WDV6LB6MT
    I'm sure you'll be fine
  9. May 27, 2022 at 8:01 PM
    MPFuini
    MPFuini New Member
    So what was the outcome here because I'm running into the same problem. Bolt goes through, but at an angle so I can't slide the interior metal barrel up into the bushing.
  10. May 27, 2022 at 9:04 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    No other way than to bar shit around. Gotta make it line up.
    Grossomotto likes this.
  11. May 27, 2022 at 9:19 PM
    Grossomotto
    2017 4WDV6LB6MT
    Leverage, just move it over, it'll only drop about an inch.
  12. May 27, 2022 at 11:03 PM
    Zingsauce
    Brian
    San Deigo CA
    2019 tacoma DCSB
    What worked for me was using a 21mm wrench and just kept moving it around until it lined up. I read somewhere here that the 3rd gen Tacoma came off the lot already misaligned lol.
  13. May 28, 2022 at 1:48 AM
    toku58
    toku58 Well-Known Member
    On a Rock in the middle of the Pacific
    Mall Crawler!
    21' TRD OffRoad 2" 887 OME on Bilstein 5100's. 285/70R17 General Grabbers G3 17x8.5" Icon TRD wheels (Gun metal gray) 4.75" BS
    Pry bar and move it so that he bolt aligns. Seems to be a common issue. Not too hard to do with a pry bar.
    https://amzn.to/3wVYmq3
    Alway good to have a few of these if you're planning to work on your truck!
  14. May 28, 2022 at 3:19 AM
    ClassyTacos
    ClassyTacos National Treasure 3, Times a ticking Nickolas
    Papalote
    Florida
    2017 TRD Sport 4x4
    Stockish
    Pry bars are your friend here. Also don't hammer down on one side and then try to install the other side. Leave them both lose till both are threaded in. Then hammer down on them.
