Radiator hose clamps. Spring type vs screw type clamps
Discussion in '1st Gen. Tacomas (1995-2004)' started by Scutter, Aug 23, 2023.
  1. Aug 23, 2023 at 10:59 AM
    Scutter
    Scutter [OP] Active Member
    Scott
    San Diego
    2002 Tacoma Extracab SR5 V6 Auto 4X4
    All stock
    I have a new radiator so I’m also going to change out the hoses. I think they come stock with spring clamps. Previous owner has changed to screw type.
    I tend to believe the engineers are smarter than me. So, is there any advantage to staying with the screw type clamps?
  2. Aug 23, 2023 at 11:03 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    I’ve heard the spring clamps are more consistent, can’t be over tightened and handle temperature cycles better over the long run. It’s what I prefer to use, less of a pain to take off.
  3. Aug 23, 2023 at 1:18 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    When the hose is new and fresh....dont think it matters....
    when the hose ages/hardens.......both clamps have their own problems....
  4. Aug 23, 2023 at 2:57 PM
    c0bra
    c0bra Well-Known Member
    OEM spring clamps are fantastic if you have the choice. Stay away from any aftermarket spring clamps.
    Screw clamps are not created equal. The cheap ones will strip out and apply uneven pressure. There are nicer types that overlap and don't chew into the rubber, they work really well. There is also the type on the intake boots that is more like a wire and these work well.
  5. Aug 23, 2023 at 5:52 PM
    Glamisman
    Glamisman Well-Known Member
    I look at it this way, if you have to change a hose on the side of the road you can always come up with a screwdriver, spring clamp pliers, not so sure on that.
  6. Aug 23, 2023 at 5:59 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Just get constant tension clamps
    They're great and affordable
    btu44 and TnShooter like this.
  7. Aug 23, 2023 at 6:15 PM
    Nessal
    Nessal Well-Known Member
    Texas/Bay Area
    2003 V6 4X4 TRD DCAB
    I used spring clamps for liquid and spring or screw for air.
  8. Aug 24, 2023 at 5:44 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    You must not have had to deal with many engineers in your case.:rofl::rofl::rofl:
    Time is money who wants to mess with screw type clamps on the assembly line .
    That is the only reason they are used from the factory.
    Yes they work good I would not waste time tracking them down if I see them unused they follow me home.
  9. Aug 24, 2023 at 3:59 PM
    OLDHMECH61
    OLDHMECH61 Well-Known Member
    Andy
    Odessa FL
    99 Prerunner Std cab green
    1UZ swap, trutrac diff, tundra brakes, 3 lift, FJ rims
    The name says it all......constant.....pressure....clamp, I do not have a screw clamp anywhere on my truck, i thought they were for garden hoses or lawn mower fuel lines, but i'm not an automotive mechanic.
  10. Aug 24, 2023 at 4:06 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Screw type clamps are easier to find in stainless steel. That reason alone is enough for me to choose screw type clamps.
    Bivouac likes this.
  11. Aug 24, 2023 at 4:40 PM
    Scutter
    Scott
    San Diego
    All stock
    Looks like the constant tension clamps are what I was referring to as spring clamps.
    Good, that’s what I installed.. thanks you the suggestions
