Rack n Pinion boot clamp help/suggestions
Discussion in '1st Gen. Tacomas (1995-2004)' started by jammer, Apr 16, 2020.
  1. Apr 16, 2020 at 9:16 AM
    jammer
    jammer [OP] 2003 Toyota PreRunner 3.4L
    Ben
    Bentonville, AR
    2003 Lunar Mist Tacoma PreRunner 3.4l
    OME Coils/Bilstein 5100's front / 5125's rear 105 Amp Denso Alternator
    2003 Toyota Tacoma DBL Cab PreRunner 3.4l / Auto
    Approximately 150,000 miles
    I'm in the process of replacing the inner and outer tie rods while in lock down. Waiting on the replacement parts from LowRangeOffRoad.
    In anticipation of the parts being delivered I removed the outer tie rod, but I destroyed the bellows clamp that secures it to the rack (pic below).
    I really don't want to have to buy an expensive tool to remove/replace so is there a trick to this or are you guys using a different type of clamp?
    Much Appreciated!!
    Toyota replacement boot clamp part no.: 90460-62006 x 2
    Pics of the original inner tie rod
  2. Apr 16, 2020 at 9:18 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    If $30 is expensive.........
  3. Apr 16, 2020 at 9:41 AM
    jammer
    Ben
    Bentonville, AR
    What tool do you recommend? I went to Amazon but it's confusing looking for the right band clamp tool, but there are several different ones to choose from.
  4. Apr 16, 2020 at 9:45 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    You know what, disregard my last.
    I remember reading about the clamp being the same style used on a cv axle.
    I bought the cv axle tool and used it on my extra parts and figured I'd use the same tool for my steering.
    Works well but I've yet to try it on anything else other than the axles.
    Its this one -
    jammer[QUOTED][OP] likes this.
  5. Apr 16, 2020 at 9:57 AM
    jammer
    Ben
    Bentonville, AR
    Appreciate your help.
  6. Apr 16, 2020 at 9:57 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    Only tool needed is a pair of pliers. No bending or crimping.
    Study pic and your new clamp. Squeeze at the little hooks/tabs and lift the end off the inner hook (black arrow) with a pic or little screwdriver.
  7. Apr 16, 2020 at 10:01 AM
    Dirty Pool
    99 XCAB V6 MT TRD
    I think I see water spots on your rack.
    TWJLee and jammer[OP] like this.
  8. Apr 16, 2020 at 10:08 AM
    jammer
    Ben
    Bentonville, AR
    I'll be taking care of that later today.
    OneWheelPeel likes this.
  9. Apr 16, 2020 at 10:51 AM
    Timmah!
    Timmah! Well-Known Member
    TIM
    I was able to get them off without destroying them but I can see how it can happen. I used a large pair of channel locks in combination with a flat head screwdriver. Here's a video that would help people get the job done of replacing their inner and outer tie rods.
    https://www.youtube.com/embed/--HcOQlv03U
  10. Apr 16, 2020 at 11:15 AM
    Actionjackson
    Actionjackson Well-Known Member
    Jack
    MA
    2004 Tacoma
    I've been using good quality black tie wraps. Lasted ok for me and no rusting.
  11. Apr 16, 2020 at 11:47 AM
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
    Those water spots are embarrassing... :rofl:
    Kwikvette and jammer[OP] like this.
  12. Apr 16, 2020 at 1:08 PM
    jammer
    Ben
    Bentonville, AR
    This is a little better
    fatfurious2 likes this.
  13. Apr 16, 2020 at 3:32 PM
    COMAtized99
    COMAtized99 Well-Known Member
    North Carolina
    99 DCLB v8
    The Bed is stock...ish
    I used big zip ties on my last rack. Worked great.
    jammer[OP] likes this.
  14. Apr 16, 2020 at 5:02 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    I have been running a ~$2 hose clamp for more than a decade.
    All it does is hold the boot on. The rack itself has seals that keep the PS fluid inside.
    Hell, I have a hose clamp holding one of my CV boots on and guess wheat: it hasn't exploded.
    MalinoisDad and jammer[OP] like this.
  15. Aug 12, 2021 at 5:52 AM
    mollyareb
    mollyareb New Member
    When I had the need to clamp I used a toggle switch, The built-in quick action mechanism can turn them on or off in one quick motion, and the lever system of pivot pins and levers increases the force applied.
  16. Aug 12, 2021 at 7:17 AM
    MalinoisDad
    MalinoisDad Misanthropic dog person
    Michael
    01 TRD PreRunner 5VZ
    5100s w/ 881s, JBA UCAs, J59s, other stuff and things
    I did it this way too but it took some patience… and a few expletives.
  17. Aug 12, 2021 at 7:50 AM
    OpeCity
    OpeCity Well-Known Member
    Long Beach, CA
    Am I the only one using zip ties?
    eon_blue likes this.
  18. Aug 13, 2021 at 10:29 AM
    bajorjoevel
    bajorjoevel New Member
    When I had the need to clamp I used a toggle switch, The built-in quick action mechanism can turn them on or off in one quick motion, and the lever system of pivot pins and levers increases the force applied. By the way, Once engaged, the toggle clamp is virtually locked in place. I know that tumbler clamps https://www.sandfieldengineering.com/toggle-clamps/ are used in a multitude of media and applications, including automotive plants, food production, engine testing, and ammunition production. If there's a common theme, it's the challenge of finding a reliable but flexible method of holding a piece of work in a manufacturing process or application.
  19. Aug 13, 2021 at 10:33 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    I used those metal ones but yeah, same idea. Much easier to remove than that OEM clamp that requires a special tool.
    Been rocking them for almost 2 years since I did the inner tie rods and no issues.
