Rack and pinion leak. Help
Discussion in '1st Gen. Tacomas (1995-2004)' started by 98.tacoma, Jan 29, 2017.
  1. Jan 29, 2017 at 4:46 PM
    98.tacoma
    98.tacoma [OP] Member
    Ga
    98 tacoma preruner
    just a 98 Tacoma with some new parts. 2wd, 160k miles
    My 98 has a leak on rack and pinion and its pritty bad. but i cant find a vidio to fix the seals on it. i think if i replace the seals then ill be good hopefully. A new rack and pinion is way too expensive. anyone know about these or could help??
  2. Jan 29, 2017 at 4:53 PM
    043RZ
    043RZ Well-Known Member
    Spring Grove, PA
    2004 Tacoma SR5
    6" Fabtech Lift, OME Dakar leaf springs, BudBuilt Traction Bar, 15" American Racing Wheels, 5.29 Nitro Gears, 35" BFGs AT, Pioneer 200 Watt Stereo, 6x8 Pioneer speakers, Raised Front and Rear Diff Breathers, Deck Plate Mod, Red Interior Underglow, Red Exterior Underglow, Cool White LED Rock Lights,
    Is that coming out of the boot? If so your probably going to have to buy a new rack and send in the core. You could rebuild it but it will prolly be worth just getting a new one with a warranty
  3. Jan 29, 2017 at 5:38 PM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    Check for rust on the rack shaft inside the boots first.
    Then this link might help but it's not for everyone. Remember if your 98 rack is original it has the "old style" guide and should be upgraded to the new style along with the seal kit. Also replacing "rack end seals" can be done without fooling with the more involved control valve/pinion shaft.
    Light a fire and get comfortable.
    https://www.tacomaworld.com/threads/rack-pinion-service-tools-tips.312600/#post-8072827
    Dalandser and cruiserguy like this.
  4. Jan 30, 2017 at 1:16 AM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    Honestly you'll be better off replacing that bad boy. After fooling around with seals even if you can find em or have it done you'll already be into it fairly good $$ wise. Then you still have an aged unit. Look around there are lots of options for new and remaned racks from super cheap all the way to toyota oem.
  5. Jan 30, 2017 at 7:17 AM
    98.tacoma
    Ga
    98 tacoma preruner
    Id love to do oem but i dont have the money. and it is comming out of the seals. the boot looks fine just oil on outside. i might try the seals first because they are a whole lot cheeper. i just need something to get thew for a cupple yeirs. also r there any springs or anything that if i take that bolt off the back (right where there is red fluid) to replace the seal that is busted, will it mess it up where i would have to replace whole unit? this is out of my feild of knowledge.
  6. Jan 30, 2017 at 1:02 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    I've never rebuilt or replaced seals in a steering rack, so don't know your answer. But I bet this guy does @Dirty Pool
  7. Jan 30, 2017 at 5:54 PM
    COMAtized99
    COMAtized99 Well-Known Member
    North Carolina
    99 DCLB v8
    The Bed is stock...ish
    Replace it.
  8. Jan 30, 2017 at 9:43 PM
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    First of all, are you sure it's not leaking from a hose above and just dripping down onto the rack?
    If it is the rack leaking, then you have a few options other than a new/rebuilt unit. You could find a used one (that's not leaking) for cheap at a junkyard. If you look up the part number, you may find that some other models used the same rack & pinion, such as 4Runners. If you're lucky you could find a junkyard vehicle with the engine removed to make it a little easier.
    Second, there are rack & pinion seal kits available either from Toyota or Gates (~$50) or cheaper brands. The problem with this is the procedure for disassembling and reassembling involves pressing some bearings and seals in and very carefully installing teflon rings. I've never done it, but you can read through the procedure in the factory repair manual. This would be the cheapest route if your time is worth nothing.
    If you want a relatively cheap rebuilt unit you could try Detroit Axle for $225. That pages shows what other vehicles are compatible which might help if you want to look at a junkyard for a rack.
  9. Feb 6, 2017 at 6:22 AM
    98.tacoma
    Ga
    98 tacoma preruner
    Oh wow... yahhh i know id mess that up. Nore do i have the tools. well i just ordered a new rack and it was around 300. but thank you verry much. and thank all yall. ill tell yall how it goes when i put new one in this weekend
    DrZ likes this.
  10. Feb 6, 2017 at 10:16 AM
    99SuperTaco4x4
    99SuperTaco4x4 Well-Known Member
    Adam
    Sacramento
    1999 3.4L V6 Tacoma, 4x4, TRD Supercharger
    YMMV, but Lucas PS Stop Leak worked for me. It is a temporary fix, but I was refilling my reservoir weekly, with a stain on my driveway from a constant drip. After putting Lucas in, I haven't put in any PS fluid for 1.5 months. Again, it may not work for you and this is not a permanent solution, but so far its saving me from the time, hassle and cost of a new rack.
  11. Mar 21, 2017 at 6:36 AM
    98.tacoma
    Ga
    98 tacoma preruner
    I got the new one in and all new lines and it works like a charm. Not one leak at all. thanks yall!
  12. Mar 22, 2017 at 9:41 AM
    spazoner
    spazoner 303
    Thomas
    Fort Riley, Kansas
    98 Tacoma Xtra Cab Limited
    4" ProComp Lift, Volant Intake, ProComp Wheel/Tire Combo
    Check if that came with a warranty. Had mine replaced and couple months later had to use the warranty to replace it yet again. Just food for thought.
  13. Mar 22, 2017 at 1:22 PM
    98.tacoma
    Ga
    98 tacoma preruner
    it does, i made sure of that at least lol. but thanks!
