Rack And Pinion Bushing Replacement, raise truck?
Discussion in '1st Gen. Tacomas (1995-2004)' started by lonzorizo, May 9, 2011.
  1. May 9, 2011 at 6:53 PM
    lonzorizo
    lonzorizo [OP] Well-Known Member
    Lonnie
    Hoopa, Ca
    2003 TRD OR, 2016 TRD OR Tacoma
    Is it really necessary to jack the truck up to change the rack and pinion bushings? Is it only noted to do so to have extra room to work? Or is there another underlying reason?
  2. May 9, 2011 at 9:00 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    I put mine up on jackstands, mostly to have more working room. I don't think you have to but it makes the job a little easier having that extra room to work.
  3. May 9, 2011 at 9:03 PM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    1988 Pickup 22R 5sp 2wd
    Weber 32/36, RV Cam, LCE exhaust headers, Desmogged
    no, it is not necessary, but it would give you extra space, as digiratus mentioned. i did mine around christmas time without lifting it. did you get the energy suspension ones?
  4. May 9, 2011 at 9:08 PM
    lonzorizo
    Lonnie
    Hoopa, Ca
    Yeah energy suspension kit from wheelers. And thanks 4 the info guys guess that means I can get this stuff done tomorrow now. My jack stands are too short since I lifted my truck, I'll grab some new ones this weekend.
  5. May 9, 2011 at 9:23 PM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    nice, you'll be happy with them. and for $20, you can't go wrong. another thing you may check into is the . between the new bushings and that "mod"/fix, it's like a whole new truck!
  6. May 9, 2011 at 9:32 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    x2, welding that thing did way more than the bushings for me.
  7. May 9, 2011 at 9:35 PM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    i would agree. my original steering rack bushings were starting to look pretty bad and cracked, so i replaced them. i felt a minor improvement. i noticed a huge difference with the steering column weld. but for $20, i definitely feel it's a worthwhile endeavor! :)
  8. May 9, 2011 at 10:25 PM
    lonzorizo
    Lonnie
    Hoopa, Ca
    Alright sweet thanks for the heads up buddy!
  9. May 22, 2012 at 8:47 AM
    BonesD
    BonesD Member
    Austin Texas
    99 Pre runner 167,000miles
    Is changing the 5 bushing's a difficult job or can the average person do it?
    Any special tools required?
    How long does it take on average with hand tools?
    Thanks
    Bones
  10. May 22, 2012 at 9:39 AM
    lonzorizo
    Lonnie
    Hoopa, Ca
    Average person can do it. I did it with no experience at all last year. And fyi you do have to have the front end off the ground to get the rack off enough to get a bushing replaced.
  11. May 22, 2012 at 9:58 AM
    BonesD
    BonesD Member
    Austin Texas
    Thanks for answering back. Do you have to take it loose from the tie rods or can you leave it hanging there to change the bushings?
  12. May 22, 2012 at 10:00 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    you can leave it hanging.
    make sure you cut the little lip off the old bushings before trying to press them out.
  13. May 22, 2012 at 10:07 AM
    BonesD
    BonesD Member
    Austin Texas
    Steve O 77, i received an email that says you had submitted something for this forum but I don't see your entry.
  14. May 22, 2012 at 11:21 AM
    BonesD
    BonesD Member
    Austin Texas
    Got you PM and went back to the forum to say thanks and low and behold your post is there now.
    I appreciate the help.
    Bones
  15. May 22, 2012 at 11:23 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    no problem
  16. Mar 8, 2013 at 5:24 AM
    BonesD
    BonesD Member
    Austin Texas
    Here I am 9 months later and finaly changing the bushings. I ordered the ones from Wheelers and am wondering if I want to jack the truck up and remove wheels or would ramps work as well? I have to buy one or the other so I thought ramps would be nice for oil changes etc. Is the job easier with the wheels out of the way?
    Thanks
  17. Mar 8, 2013 at 5:52 AM
    tacoma04
    tacoma04 Retired to the lake
    Bruce
    Tennessee
    2017 TRD OR DCSB BBP
    I didn't take my wheels off and didn't have a problem. I also left the tire rods connected.
  18. Mar 8, 2013 at 6:02 AM
    BonesD
    BonesD Member
    Austin Texas
    Great, I guess I will buy some ramps instead of the jack stands. My hydraulic jack is to small for the height of this truck so the ramps would make sense at this time. I need to get it up higher as I have lots of bending and crawling issues Too darn old!
    Thank You
    Bones
  19. Mar 8, 2013 at 6:06 AM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    I'm about to do mine later this week. I also got sway bar bushings and outter tie rods as well.
  20. Mar 8, 2013 at 7:57 AM
    BonesD
    BonesD Member
    Austin Texas
    Thanks for the reply. I went and bought some ramps and between them and the sharp inclnie on part of the drive I have it up pretty high. Hope my arms are long enough now.
    I got several of the bolts off but had to use a 7/8 6 point socket on one. I have another that is pointing straight down that needs a deep 7/8 socket or a longer one in 1/2 drive with 6 points. I tried using a 7/8 12 point and it is starting to roll off of the nut. What size is this nut in a wrench size? I might as well get it in mm's to fit correctly. I am guessing 20 or 21 mm.
    Anyone, anyone at all?
    When I worked on German cars back in the 70's all you needed was up to about a 19mm unless you were working on a VW then you might need a 30mm.
    I just looked at conversion chart that say's it might be a 22mm.
    Another edit, 22mm is equal to .866 thousanths so that is only .006 larger than my nut where as the 7/8 at .875 is .015 bigger than the nutso I guess the 22 has to be it.
    Off to the store.
