Raam Mat vs Dynamat Xtreme - my impressions
Discussion in 'Audio & Video' started by rkdiddy, Oct 11, 2008.
  1. Oct 11, 2008 at 11:38 AM
    rkdiddy
    rkdiddy [OP] Senior Member
    OC Baby!
    '08 Taco DC PR
    So I decided to apply sound deadening to the interior of my truck.
    I started with the back wall and worked my way forward. The install wasn't difficult, just time consuming. Due to availability I started with a bulk buy of Dynamat Xtreme. I was able to complete the back wall and floor with 9 sheets.
    I then decided to tackle the doors. Since I needed to purchase additional sound deadening I decided to try Raam Mat.
    After using both, I must say the they both have their pros and cons:
    Dynamat Xtreme:
    I liked working with the Dynamat. I found it easy to cut and install. The sticky layer doesn't appear as tacky as the Raam Mat, which makes it easy to reposition. Once it sets though, it will definately stay stuck. It also has a little stretch to it, which is nice to get into all the crevisis.
    Pros:
    - Readily available (Circuit City, eBay, etc)
    - Thicker foil topper
    - Thicker Butyl layer
    - Easier to install because Butyl layer isn't as sticky initially
    Cons:
    - Sharp foil topper (I have cuts all over my hands and legs)
    - Expensive
    Raam Mat:
    I found this mat a little more difficult to work with. The Butyl layer is quite gooey. It makes for a messy install. It is also VERY sticky - which means it is hard to position into small areas (like the inside of the doors).
    Pros:
    - Cheaper than Dynamat (it comes in a large roll)
    - I like the additional Ensolite material - easy to install
    Cons:
    - Very sticky and hard to reposition
    - Has more of a smell than Dynamat
    - Not as thick as Dynamat
    Overall I'm happy with my install. Installing the sound deadening really helps reduce the ambient sounds in the cabin and really seems to kick the stereo's sound up a few notches.
    I think the Dynamat is a good product. I think the addition Ensolite material is what helps Raam Mat with overall sound deadening. If I had to do the whole thing over again I would have purchased Dynamat as the Butyl layer and then purchased Ensolite as a topper.
    Cheers,
    R [​IMG]
  2. Oct 11, 2008 at 12:09 PM
    atsaubrey
    atsaubrey Dealer/Sales Rep for Sundown Audio.
    california
    blue 2007 double cab
    Sundown Audio 100.4 and 1500D, Pioneer 880PRS, Zapco Refernece 6.5" comps, 2 10" Image Dynamics IDQ, 200ft of Second Skin deadener, Kicker wire
    If you liked the Dynamat you def. need to check out Second Skin Audio. Best stuff on the planet in my opinion. www.secondskinaudio.com
  3. Oct 13, 2008 at 9:05 AM
    trtripoli
    trtripoli lower management
    Denver, CO
    07 4,0 L, 6M, Dbl Cab, TRD Off Road
    Eclipse AVN6620 JL 500/1 amp JL 13TW5 sub JL 300/4 JL XR-650CSi Mr Marv Box Blu tooth XM radio Back Up camera, RAAMmat and Ensolite everywhere but ceiling
    What is the the estimated cost for using the Raam Mat and Dynamat for typical installation in the 2nd generation tacoma (doors, behind rear seat and floor)?
  4. Oct 13, 2008 at 9:07 AM
    Chickenmunga
    Chickenmunga Nuggety
    Keizer, Oregon
    08 TRD Offroad DC 4x4 with stuff
    All the normal TW BS
    I used to hear about something called... "Brown Bread" I think... thoughts anyone?
    x2!!
  5. Oct 13, 2008 at 11:37 AM
    atsaubrey
    california
  6. Oct 13, 2008 at 11:45 AM
    trtripoli
    Denver, CO
    good article with good cost analysis. Do you know how many sqft are needed to do a 2nd gen. taco?
  7. Oct 13, 2008 at 12:52 PM
    atsaubrey
    california
    depends on what you consider "done" I am a firm believer in two things when it comes to car audio. #1 you can never have enough power. #2 you cannot have enough deadener. I firmly believe in this deadening in this order with our trucks.
    Doors and door panels.
    backwall
    roof
    floor
    Do your deadening in that order, really doing the floor with deadener should be your last choice, the foam insulation works better on the floor.
    I would say to do a "good" job 36ft should do your doors and back wall nicely, if your going to do the roof and floor I would suggest another 36ft. Like I said you cannot have enough deadener IMO. Keep in mind the Taco have some pretty thin metal and I sugest doubling up in several areas.
  8. Oct 20, 2008 at 8:31 PM
    EAR28
    EAR28 Active Member
    Houston, TX
    Silver Truck
    With the one roll of Raam Mat I bought, I completed all four doors and still have plenty for the back wall and much much more.
  9. Oct 21, 2008 at 8:55 AM
    Ken Dawg
    Ken Dawg Well-Known Member
    EAST COAST
    08 Prerunner TRD Sport LB
    Tranny rebuilt 12/2016 at 142,500 Pioneer deh-p400ub head unit Alpine spr-69c fronts Alpine 17c rears. Rockford Fosgate 4 channel amp JL sub behind seat Upper console solder fix Recall: Rear leaf's 12/2016 To Do List: JVC KW-V820BT with Backup cam Zelwig Helper Spring Clazzio Dark Gray seat covers /heat Viper alarm w/ Starter Then drive to 250,000 miles!
    doing the doors only is fine if you just have speakers, amp and NO sub I am thinking. this sound about right?
  10. Oct 21, 2008 at 9:34 AM
    Chickenmunga
    Keizer, Oregon
    I think it's all a matter of how crazy do you want to be. More matting is going to reduce more outside noise & reflection, but it's all at a price. Each vehicle has different levels of need -
    for sub comparison, my '86 Accord created more rattle than my friend's '97 Cadillac, but my brother's '91 LeMans hatch sounded best. The non-scientific of this is that for the same listening level, the Accord had low restriction but also low insulation, Cadillac was pushing all the sub noise to the metal because the seats were soaking up everything that emanated forward, and the LeMans had no restriction.
    For speakers, the Cadillac sounded best because of its natural insulation, the LeMans sounded worst because it was a tin can on wheels and you could hear tons of road noise.
    Start small and see where your comfort level is?
  11. Oct 21, 2008 at 10:54 AM
    Ken Dawg
    EAST COAST
    Yeah, had a chat with Marvelous Marv just now...
    doors are a must... back wall 2nd....
    I like the idea not only for stereo but road noise cut down etc.
    my system isnt a drop dead system but no matter what it is I always try to make the most out of whatever is in front of me. Especially with women....lol
    Pioneer deh-p400ub head unit (like it)
    alpine spr-69c 6x9
    alpine spr-17c 6.5
    and to follow: amp....undecided between http://www.alpine-usa.com/US-en/products/product.php?model=PDX-4.100 and http://www.pioneerelectronics.com/PUSA/Products/CarAudioVideo/Amplifiers/PRSSeries/PRS-D4200F
    so...as you can see there isnt a sub and will only be 75-100 rms per channel....
    so....
    doors completely and back wall...done deal!
    Sound about right to you?
    thx
