R4T High Clearance exhaust
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacoma13_NC, Oct 23, 2024.
  1. Oct 23, 2024 at 2:25 PM
    Tacoma13_NC
    Tacoma13_NC [OP] Well-Known Member
    2013 SR5 4x4 DCSB 4.0L (Black) OTT
    Bilstein 6112/5160; JBA HD UCAs; 1.5" 3-Leaf AAL's w/ overload; OME CB drop; RCI aluminum skids w/ catalytic converter shields; Wheeler's U-Bolt flip kit with Superbumps; TRD Pro 4-Runner Wheels; BFG KO2's (265/70/17); Diode Dynamics SS3 Sport (Yellow) fogs; CaliRaised 32" hidden light bar; Morimoto XB LED headlights with upgraded HD harness; Unifilter mod; Rear-View mirror riser bracket; Truxedo Lo Pro tonneau cover; New OEM color-matched grille; Bumpershellz color-matched rear bumper cover; Ultra-Gauge MX 1.4 w/Spiker mount; Baja Designs S2 Sport Ditch Lights with SDHQ brackets; Fog Light Anytime Mod; Overland Tailor Tune (OTT)
    I just found out today that production on this system is halted for the unforeseeable future. That sucks because I spent a lot of time researching what the best sounding exhaust was, and this seems to be it (subjective). I also want to dump my tailpipe so this would work nicely. Is there anything else out there that is like this, or am I just going to have to cut my factory exhaust and be happy with it?
  2. Oct 23, 2024 at 4:44 PM
    TacoTuesday1
    FL
    I have a TRD catback cut by the axle. Pretty straightforward.
    it is hidden.
    truck has a high clearance steel rear. Without a cut it would be sticking out and hanging a mile down low which is not good.
    had an exhaust shop weld in a Vibrant 1141 resonator to get rid of the highway drone it had.
    reallifedog and Tacoma13_NC[OP] like this.
  3. Oct 24, 2024 at 11:24 AM
    BigCountry762x39
    BigCountry762x39 Well-Known Member
    TL
    PNW, Oregon!
    2009 Tacoma, with the cool white paint peel
    Arb Deluxe bull bar Front Bumper Ironman4x4 12k winch synth line AFE Intake OME 2.75in Dakar Leaf springs (R) Fox 2.0 bypass shocks (R) Bilstein 6112 (F) 33's on KMC wheels off road lighting comfort mods Redrock HD roof rack Retevis rt95 Radio Slotted Rotors and HD pads
    going to just say cut the tail pipe off just over the axle, still the stock exhaust but also the only real cost might be a new saw-z-all blade, or a wheel for your angle grinder. most exhaust for 2nd gen Tacoma's sounds like hot garbage! I will say this I hate how my flowmaster exhaust sounds, but for $200 brand new in a box I figured i would deal once it gets super obnoxious ill throw on a different muffler. something likely with a U turn outlet close to the inlet to keep some of the noises down
    Tacoma13_NC[OP] likes this.
  4. Oct 24, 2024 at 11:45 AM
    Tacoma13_NC
    Thanks. I do like the sound of the TRD exhaust too, just a little bit deeper tone than the OEM one. I don't want to spend that kind of money on a system that I'd end up cutting the tail pipe off. Maybe I can source just the TRD muffler somewhere.
  5. Oct 24, 2024 at 1:57 PM
    BigCountry762x39
    TL
    PNW, Oregon!
    do you have the stock exhaust on there now? if just chop that back I think the truck sounded a bit better with the chop. but put any good muffler on you would like still likely cheaper and they might be even cheaper to get a good muffler put on and a dump off that muffler maybe hundred or so depending on muffler cost and their shop rate, if they are willing to weld on a muffler
