R150 transmission questions
Discussion in '1st Gen. Tacomas (1995-2004)' started by Hub_G, Nov 21, 2021.
  1. Nov 21, 2021 at 11:43 AM
    Hub_G
    Hub_G [OP] Member
    95 toyota tacoma 4x4
    I read on the internet that you can take a R150 transmission from the 3.0L and change the bell housing to the 3.4L and itll work. Im trying to see if thats true.
  2. Nov 21, 2021 at 11:49 AM
    Team_Jake
    Team_Jake Well-Known Member
    '99 4Runner Limited '01 Tacoma Xtracab
    Not exactly, it's a little more involved. The input shafts are different lengths, and the tail housings are completely different so your t-case (if you are 4x4) won't bolt up.
  3. Nov 21, 2021 at 1:26 PM
    Hub_G
    Hub_G [OP] Member
    I seen the transfer case difference. I read something about an adapter to make the transfer case work. But I'm not quite sure about the input shaft.
  4. Nov 21, 2021 at 2:34 PM
    Team_Jake
    The only adapter I know that could work would be the new eco-crawler doubler from NWF, but that's a much more expensive route than just finding the correct R150F. Do a search, there are many threads explaining the differences between the two transmissions.
    Hub_G[OP] likes this.
