quick question for water pump torque and gasket
Discussion in '1st Gen. Tacomas (1995-2004)' started by NightProwler, Nov 24, 2014.
  1. Nov 24, 2014 at 11:59 AM
    NightProwler
    NightProwler [OP] Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '16 trd4x4, '09 R1, '03 cbr954rr, '03 rc51
    '01 3.4liter
    About to tackle this right now. Water pump bolts need to be torqued to 168 in-lbs. What's the conversion for this using a torque wrench in ft-lbs?
    Also to run rtv sealant for the water pump, I assume it needs it on both sides of the gasket? Or should I say one bead on the water pump, one bead on the block, then place/squish the gasket on the block, then install the water pump?
    Sorry for the noobish questions. Never done this job before. thanks.
  2. Nov 24, 2014 at 12:03 PM
    Manwithoutaplan
    ID
  3. Nov 24, 2014 at 12:07 PM
    NightProwler
    Harlan
    Maricopa, Az
    Ha just realized I just need to devide by 12. Der.
