Quick question, clamshell bushing related ( solved )
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Abdulla, Mar 8, 2024.
  1. Mar 8, 2024 at 1:47 AM
    Abdulla
    Abdulla [OP] Active Member
    1 Inc lift / 285/75/16
    I've changed my needle bearing into the ECGS bushing then the vibration started , didn't have it before ,just though to be in the safe zone and go for it , to be honest I'm regretting doing that , is it possible that my tacoma is manual 2018 access cab and the ecgs doesn't work on manuals?
    The vibration starts at 30 to 60 then it goes away , I'm thinking of installing the needle bearing back again
  2. Mar 8, 2024 at 2:06 AM
    AssQuake
    AssQuake Unknown Member
    A.J.
    Washington
    4runner
    Made in Japan
    Have you ruled out wheel balance? How high is your lift and how many miles are on the truck? Check driveline u joints and center carrier if you’re high mileage.
  3. Mar 8, 2024 at 2:15 AM
    Abdulla
    Done balancing, lifted 2 inches, + the vibration goes away on 4H , checked the drums , and wheel bearing+ u joint and center bearing checked and greased the front shaft
  4. Mar 8, 2024 at 6:30 AM
    mootiger49
    mootiger49 It’s mine, not yours!
    23’ Lunar Rock OFF ROAD. 24’ Underground 4-Runner. 2000 IJM OFF ROAD
    V2 grille OTT Tune 5100’s Pro rims
    Interested to see how this plays out.
    Sounds like the clam shell fix would have solved these symptoms.
  5. Mar 8, 2024 at 6:39 AM
    Abdulla
    Just checked my axle and there is a huge play in it I'm surprised it happened after installing the Bush, or it might just me chose a wrong Bush!! Or the mechanics screwed it when installation, ordered this bush Yukon Gear & Axle Yukon Cv Axle Bushing for Front Toyota 8" with Clamshell Design https://www.amazon.com/dp/B07P83HNKC ill install it myself
  6. Mar 8, 2024 at 8:10 AM
    808stateofmind
    808stateofmind Well-Known Member
    Kona
    '22 Lunar Rock TRD OR 4x4 DCSB 6MT
    Eibach pro truck 2.0/2R lift kit 1.5" AAL OME/ARB UCA BFG KO2, 285/70-17 SCS Blaze 10, 17-8.5, -10 offset ECGS bushing needle bearing replacement Clutch accumulator disk delete Poor mans TRD intake, K&N 57 series intake tube, K&N high flow filter, TRD flow accelerator
    It definitely works on a manual trans. I did the clamshell bushing on my '22 trd OR and gave had no issues. Could be something other than the bushing possibly? Maybe they put in the wrong bushing(not an 8")
  7. Mar 8, 2024 at 8:17 AM
    Abdulla
    This is the first one I got that made the axle free from what it's look like there is a difference I guess
    Vanshly YB AX-018 Drive Axle Shaft Bushing for Front Toyota 8" with Clamshell Design https://www.amazon.com/dp/B0C9HTMPY3
  8. Mar 8, 2024 at 8:31 AM
    offroadguy651
    offroadguy651 Well-Known Member
    The North
    2023 TRDoffRoad
    5100's 1.5 front. 1 inch Eibach block in the rear. KO3 285/70/17 RRW RR6-H 17x8.5.
    Oh boy. Fixing something that doesn’t need fixing now it needs fixing. Good luck.
  9. Mar 8, 2024 at 8:33 AM
    Abdulla
    I need that luck I hope I don't need to do more than that
  10. Mar 8, 2024 at 1:19 PM
    BillyE
    BillyE Well-Known Member
    Almost certainly an installation issue. Might have destroyed the bearing and/or CV shaft though.
  11. Mar 15, 2024 at 8:01 AM
    Abdulla
    Got the new bushing , installed it myself its now perfect
    bkhlrTaco's, BillyE[QUOTED] and b_r_o like this.
  12. Mar 15, 2024 at 5:35 PM
    gdr
    gdr Well-Known Member
    Bill
    Temescal Valley, Ca.
    2016 Inferno Tacoma TRD OR 4x4
    Ok, let me get this corect.
    You bought some unknown Vanshly brand bushing what a Yukon part number off of Amazon and had a mechanic install it. This one Sucked.
    You then bought the Yukon bushing and installed it yourself. This one is good.
    So you never had a ECGS=East Coast Gear Supply bushing?
    mlcc likes this.
  13. Mar 15, 2024 at 5:42 PM
    SpeySquatch
    2016 TRD OR DCSB
    has zero to do with transmission type. Most likely wheels, alignment, or if lifted it could be your driveline angles.
    Get a cheap magnetic digital angle measure device of Amazon and check the angle coming out of the transfer case and the one coming out of the rear diff. If outside of 4 degrees you may need a carrier bearing shim which is cheap. Angles should match. If they don’t and differ by 1 degree it could be your driveline because it’s a 2-piece driveline and the carrier bearing spacing will bring the angles closer within range
  14. Mar 16, 2024 at 3:43 AM
    Abdulla
    yes this is exactly what happened and no never had the east coast gear supply bushing
  15. Mar 16, 2024 at 3:52 AM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Junk Amazon parts………why does everyone keep buying junk crap from Amazon?
  16. Mar 16, 2024 at 3:55 AM
    Abdulla
    Ive done that
    Front shaft 6.20
    Back shaft 9.00
    Carrier bearing angle 2.8
    Pinion angle 3.18
  17. Mar 16, 2024 at 3:58 AM
    Abdulla
    Because im in dubai and cant have parts of the tacoma in here we dont have a tacoma dealership or parts anywhere and i mean oem parts , do you think someone gonna care for accessories
  18. Mar 16, 2024 at 4:44 AM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    So was it a bad/wrong bushing?
    The ECGS (East Coast Gear Supply)
    8" clamshell is what I used, and many others use, with great results.
  19. Mar 16, 2024 at 4:47 AM
    Abdulla
    I didn’t get the bushing from east cost gear supply just realized that the one on Amazon is a cheap headed thief unfortunately
    bkhlrTaco's[QUOTED] likes this.
  20. Mar 16, 2024 at 8:11 AM
    SpeySquatch
    2016 TRD OR DCSB
    that rear shaft seems like a lot. Mine was like 4.5. Have you thought about 3 degree axle shims? I did those and now my angle is like 1.4
