Quick help with a choice of brake controller Redarc brand
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ruff -Daulton-, Sep 14, 2022.
  1. Sep 14, 2022 at 1:10 PM
    Ruff -Daulton-
    Ruff -Daulton- [OP] Member
    Daulton
    2022 Tacoma TRD pro 6' bed
    under construction
    We just bought a 2022 Tacoma Off Road pickup.
    I am set to order a brake controller and I like the Redarc brand. I see that the price has gone up on the Tow-pro Elite, to $185.
    Is it worth the money to choose this over the $139 cheaper product?
    I have a 2 thousand lb trailer now but have no idea what I may have in the future. Whatever that will be will be as light as I can get.
    Thank you for your suggestions, and for your time to reply.
  2. Sep 14, 2022 at 1:48 PM
    JCT86
    JCT86 Active Member
    2017 Tacoma TRD Off Road
    I have the elite, and it's a great product. Installation wasn't bad, and it fits and looks perfect, unlike some other controllers, which can be a bit of an eyesore. It tucks right away and looks OEM. Just make sure to get the Tacoma-specific harness from them. I followed some guides here that have you buying a different harness and doing some splicing to get it to work, but in the end, I ended up with the Redarc Tacoma harness anyway, so save yourself the trouble.
  3. Sep 14, 2022 at 2:03 PM
    mattleg
    mattleg Well-Known Member
    Kansas
    2020 OR DCSB AT 4WD
    I went for the Redarc Liberty. The Liberty can do two braked axles which is enough for anything a Tacoma can tow.
    The Elite can do three braked axles and has a special off-road trailer mode, neither of which I needed.
    The only difference on install, the Liberty uses regular computer network cable for the switch (RJ45 Cat5 Patch). The Elite uses something less common. I prefer the network cable because you can easily buy or make a custom length.
    gatriguy and AZ Pete like this.
  4. Sep 14, 2022 at 3:24 PM
    Ruff -Daulton-
    Daulton
    under construction
    Well, I went ahead and bought the Elite, and hoped for, but accept, it will not plug into my Tacoma, and I will, (may) splice it to make it work. After taxes it came to just over 2 hundred. I do appreciate the replies, and the comment about being able to handle two axles, the Liberty, but I won't be hauling anything with three axles.
    Really frustrating that I might have to spend another $20 for a compatible cable.
    Thank you.
  5. Sep 14, 2022 at 4:05 PM
    mattleg
    Kansas
    2020 OR DCSB AT 4WD
    Maybe I'm confused. If you don't need three axles with brakes, then get the lower cost Liberty. For the cost of the Elite module alone, you can get the Liberty with Tacoma specific harness and Toyota specific switch plate.
    Edit:
    $169 for Liberty with Tacoma specific cable (plug and play) and Toyota switch plate. Elite module that includes generic (splice required) cable is $219.
    You have a plug and play connector in the foot well. I strongly suggest not cutting that off and splicing. It is worth far far more than $20 not to cut factory wiring, let alone the pain of working in such tight areas on wiring.
    Rockomuchaco and Toycoma2021 like this.
  6. Sep 14, 2022 at 5:55 PM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
  7. Sep 14, 2022 at 6:06 PM
    mic_sierra
    mic_sierra Toshiba HDDVD is the future
    Elsewhere
    '21 DCSB TRD Sport 4x4 Auto
    I bought the elite and couldn't be happier. Check out my install thread if you want to see details. Link in my signature and scroll down to the towing section for the link to the Redarc install.
    you really cannot go wrong either way, it is just deciding if the difference in features is worth it. I tow on and off road (jeep trails, service roads, cross country off-road) so I went with the elite.
  8. Sep 14, 2022 at 6:17 PM
    TacoSupremo19
    TacoSupremo19 Well-Known Member
    NJ
    2019 Black Tacoma TRD SPort DCSB
    Brushed Copper Blaze 10 Rims | 265 70 17 Toyo Open Country A/T III tires | Bilstein 5100 w/ Eibach Coils 2.5" lift | Blackhawk UCAs | ICON Rear 3 AAL |TRD Skid Plate | TRD CAI | OEM Rear Bed Lighting | OEM rear Tailgate lock | RC Bed Molle Racks | Custom Blacked out OEM LED Headlights | MESO V4 Mirror Turnsignals | MESO Interior trim blackout | TG DMM dash mount | TRD Shift Knob | OEM SR5 interior door handles | Upgraded Stereo including Alpine 700W Amp Alpine Type R Components & Hertz speakers 12" Sub | Custom Clazzio Seat covers | Mobtown Sliders | Front Camera
    The 3 things I bought including the Elite controller
    Mounting Panel for Redarc Tow-Pro Trailer Brake Controller Control Knob (this is for mounting on the left side of the steering wheel. The center console requires a different one)
    Item# 331-TPSI-002
    Redarc Tow-Pro Elite Trailer Brake Controller - 1 to 3 Axles - Proportional
    Item# 331-EBRH-ACCV2
    Tekonsha Custom Wiring Adapter for Trailer Brake Controllers - Pigtail - Toyota
    Item# 3031-S
