Questions following new tire installation - 40 PSI??
Discussion in 'Wheels & Tires' started by Pinatacoma, Feb 25, 2023.
  1. Feb 25, 2023 at 5:22 PM
    Pinatacoma
    Pinatacoma [OP] Well-Known Member
    Vancouver Island, BC
    2020 ACOR
    After much deliberation (Google and YouTube) I finally purchased a set of Goodyear Wrangler DuraTrac tires for my 2020 ACOR. I opted for the slightly narrower LT245/75R16 120/116 E rather than the stock 265/70R16.
    1. The shop that installed them set the pressure to 40 PSI though, rather than the 30 PSI stated on the door sticker. Do they know something I don't? I didn't think pressure would be different for a different tire. They otherwise seemed competent, but I'm not generous enough to give them a pass on this one. I actually sort of like the harder ride on the surface roads, but I'm thinking to set it back to 30 PSI unless I can get some evidence for something else.
    2. I'm not a lead foot, and generally avoid jack rabbit starts. However, my first takeoff from a stop sign on wet asphalt after leaving the shop resulted in quite a bit more wheel spin than I saw with my previous worn OEM tires. Are tires more slippery when new? Will this likely improve? Is it perhaps related to the (over)inflation pressure above?
    3. It's been a while since the days when I turned wrenches for a living - before TPMS was the norm. The shop charged me for rubber valve stems, but aren't those integral to the TPMS sensor? Do they actually get replaced still?
    Your thoughtful responses are much appreciated!
  2. Feb 25, 2023 at 6:29 PM
    Taco23Trl
    Taco23Trl Well-Known Member
    Brandon
    2023 Taco Trail Edition
    So far…. Added fog lights swapped halogens to led’s, interior lights to led’s, bed lights added, led/strobe brake lights, trying to figure out the right leds for turn signals.
    Would definitely stick to the door jam recommended pressure, that allows better control, proper ride and performance. If the tires are the same size should be good to go with factory pressure. Anything higher has marginal gains on fuel economy at the cost of ride benefit and handling
    Mark77, eurowner and Pinatacoma[OP] like this.
  3. Feb 25, 2023 at 6:41 PM
    DavesTaco68
    DavesTaco68 Well-Known Member
    North Thompson, BC
    2013 Tacoma TRD
    - ICON UCAs, BP51/Kings, SCS wheels, 285s, Leer 100XR canopy. Greenlane aluminum winch bumper, Smittybilt X20 winch. Trying Falken AT3w now, Really like BF KO2s.
    They scammed you on the valve stems, the Tpms valves are one piece, they wouldn’t have to touch them to swap tires.
    I run 30 in the back with a leer canopy and 35 in the front.
  4. Feb 25, 2023 at 6:49 PM
    Pinatacoma
    2020 ACOR
    Thanks. I'll be questioning them about this when I return for a re-torque.
  5. Feb 25, 2023 at 6:54 PM
    Pinatacoma
    2020 ACOR
    So it seems they may know something I don't know about tire pressures and conversion to different tire sizes/ratings...
    I've learned just enough to hurt myself, but have a look here and read the paragraphs below the calculator before commenting: The results are as follows:
    Now, I gather this means that the pressure needs to be increased to maintain the rated load capacity. I haven't really looked at what that is for a Tacoma and how much of that I'll actually be needing (I'm not hauling anything heavy), but if I'm understanding this correctly then running these new tires at 30 PSI gives a lower load rating than the OEM setup.
    jaymac10 and Taco23Trl like this.
  6. Feb 25, 2023 at 6:58 PM
    Bishop84
    Bishop84 Well-Known Member
    BFG actually told us to start setting the E's at 44psi or they won't qualify for warranty (Not that any tire ever does)
    I set E's to 40psi on customers trucks, it's for liability.
    It's not ideal, but its for the load rating.
  7. Feb 25, 2023 at 7:03 PM
    Pinatacoma
    2020 ACOR
    Do you know if there's a way to determine the optimal tire pressure? I'm talking about general on-road use here. Offroad is a different story, and I'll be airing down as needed.
    I'm concerned that having a higher pressure with lower loads might give me a smaller contact patch and cause the tire to wear more in the center.
    TacoEspecial likes this.
  8. Feb 25, 2023 at 7:07 PM
    Bishop84
    If unloaded, 30psi is fine for cold pressure. If towing or hauling, bump up to 40psi.
    Ultimately E rated tires are not designed for light trucks, so you'll never get proper edge wear.
    I bumped mine up to 44psi when the gas prices were bonkers a year ago.
  9. Feb 25, 2023 at 7:15 PM
    Pinatacoma
    2020 ACOR
    Thanks. I have no idea of your qualifications, but you sound convincing. ;-) I know that the door sticker is there to make things easy for people who don't know any better. I've always gone that route for "safety", but I'm beginning to see that this is something that can be altered within a range for certain conditions.
    I went with the 10-ply because of my perception that they will offer more protection against puncture on sharp stones and maybe other hazards. I'm committed now, so if I'm wrong on this gently let me know and I won't make the same mistake next time.
  10. Feb 26, 2023 at 12:12 AM
    Pinatacoma
    2020 ACOR
    Just a quick update for #2... I'm not sure about the wet road thing, but OMG on greasy snow covered roads these things are more impressive than I'd have imagined!
    I have to get some hours on them, but so far I'm very impressed. Granted, just about anything would have been an improvement over what they're replacing.
  11. Feb 26, 2023 at 12:47 AM
    Robnik
    Robnik Disciplined Maniac
    Rob
    Greenacres, Florida
    2012 Base Reg Cab 2.7L 2TR-FE A340E
    I just put 37 PSI all around. Never had a problem in 11 years.
    They wear nicely. Get a good tire gauge, not those "pencil" things.
    Similar to what I have:
  12. Feb 26, 2023 at 2:35 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Set them to the recommendation on the door sticker. If decide to tow or load the bed with weight increase the tire pressure as needed. It’s really not that hard.
  13. Feb 26, 2023 at 3:22 PM
    Haole Toy
    Haole Toy Well-Known Member
    Mauna Kea, AZ
    '21 SR 4x4
    I live at 6,500 ft elevation and both the dealership and Discount Tire set my tires at 40 psi. They say it is to compensate for the elevation.
  14. Feb 27, 2023 at 5:17 AM
    atc250r
    atc250r Recovering Ram Owner
    Orange County, NY
    2022 Tacoma SR5 - DC/LB
    LED interior, license plate, and fog lights. More to come.
    @Pinatacoma tires to grip better after they've been "scrubbed in" a bit. As far as the valve stems, unless your 20 is different than my 2022 the sensors are attached to the back of the rubber stems with a small screw. I removed mine and IIRC it was a small torx but. It's quite standard for places that do tires to keep the new style rubber stems with the threaded insert on the back in stock nowadays. They look very similar to the ones on the left in this picture.
    Pinatacoma[OP] and eurowner like this.
  15. Feb 27, 2023 at 12:15 PM
    jaymac10
    jaymac10 Well-Known Member
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    The door sticker is for stock SL rated tire pressure, not an LT tire which needs a higher psi.
  16. Feb 27, 2023 at 12:15 PM
    Pinatacoma
    2020 ACOR
    Mine definitely look like the one on the right (from the outside, anyway). I'm very doubtful they were replaced.
  17. Feb 27, 2023 at 12:17 PM
    jaymac10
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    Stick with what that PSI calculator has told you! LT tires need higher psi over SL rated. Just because some people run lower pressure, doesn't mean you/they should! At 30psi (vs 42psi), you are running those tires 28.6% lower pressure than recommended.
    I recently went through the exact same thing as you. Got LT tires for the deeper tread depth. Leaving the shop, I thought my kidney was going to explode from the harsh ride. Shop set my tires at 45psi. I now run 40psi all round based on that psi calculator.
  18. Feb 27, 2023 at 2:26 PM
    atc250r
    Orange County, NY
    If they were the metal ones then they probably weren't replaced. My point was if they are the rubber ones it's very possible they were.
  19. Feb 28, 2023 at 8:18 AM
    Discount Tire
    Discount Tire Tire & Wheel Specialists Vendor
    Arizona, USA
    @Haole Toy, thanks for the recognition, we are glad your local Discount Tire store was able to get you taken care of.
    Haole Toy likes this.
  20. Mar 1, 2023 at 8:23 AM
    Haole Toy
    Mauna Kea, AZ
    '21 SR 4x4
    The Show Low, AZ. store is great.
    Discount Tire[QUOTED] likes this.
