Questions about bumpstops - upgrade or not and why
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rimfire7, Aug 4, 2021.
  1. Aug 5, 2021 at 5:15 AM
    #41
    usmc2msu
    usmc2msu Well-Known Member
    TJ
    2017 SR5
    For what it's worth, I went with SumoSprings, but my main reason was to keep the truck from squatting when towing. There is a local trail that I had bottomed out on the bump stops and when I went back with the SumoSprings it was no long an issue. They were an easy bolt on with no needed modifications to make them work. You can also get them in different hardness so you could likely get the softest for your purpose. They do ride just under the frame rails though and will engage sooner than some of the above mentioned options.
    taco_rhyno and rimfire7[OP] like this.
  2. Aug 5, 2021 at 5:17 AM
    #42
    BT17
    BT17 Well-Known Member
    B
    17 Tacoma TRDORDCSB 4x4 AT KDmax SLT/Reg
    a few...
    rimfire7[OP] likes this.
  3. Aug 5, 2021 at 5:27 AM
    #43
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    Both I went with Wheelers rear flip kit and front bump stops. Just helps with any hard hits etc … These bump stops are progressive way better than the stock ones which are like rocks.
    Good Luck OP :hattip:
    rimfire7[QUOTED][OP] likes this.
  4. Aug 5, 2021 at 5:54 AM
    #44
    skeletron
    skeletron Disgraced Member
    Clark
    Sakerlina
    2020 TRD Broh
    U-bolt flip helps with clearance as it moves the mounting plate above the axle. After the flip the lowest point will be where the u-bolts wrap around the axle itself.
  5. Aug 5, 2021 at 6:26 AM
    #45
    DAS Taco
    DAS Taco Well-Known Member
    DAS
    2017 TRD Offroad
    Exactly, I can't recommend enough Timbren. I have been using them for years. Currently I have them on 3 vehicles. They basically prevent sagging, bottoming out, side to side sway. Once installed they are maintenance free, no worry about punctured airbags, cracked air lines, compressor failure. And the best part is that they last a lifetime and they work. I payed with my own money for all of them and I'd say they are one of the best suspension upgrades one can invest in.
    https://timbren.com/
  6. Aug 5, 2021 at 6:51 AM
    #46
    pinem56
    pinem56 Well-Known Member
    NE
    2018 TRDOR DCSB AT
    If you need to ask, you likely don't need hydro bumps, and still have a lot of other mods to make before they make sense. They are nearer to the end of a full suspension swap rabbit trail, than the beginning.
    As for timbrens, watch this first:
    https://m.youtube.com/watch?v=HSg5QYdum20
    I wouldn't get them for your application until doing a shock relocation and extending rear shock travel to at least 10 inches.
    I would look into superbumps, durobumps or speedbumps. These generally compress around 1.75" at full crush, so you will still loose a bit of free travel over a stock bump that only compresses some 0.75" at the rear.
    I would not bother with bump replacement on the front, reduces free travel too much.
  7. Aug 5, 2021 at 8:20 AM
    #47
    Timbren-Industries
    Timbren-Industries Well-Known Member
    Lots of great info here and many repping the Timbren brand which is awesome to see! It is true that the Timbren bumps will aid in all your off-road adventures and help make sure you get back in one piece. The stock bumps are just not adequate to handle the stress that you are putting on your rear end when "sending it" at the dunes. While a full front and rear replacement would be the best course of action we have seen many choose to upgrade the rears first not just to save money but because they use their trucks for a number of things, especially when loading up the bed.
    JJ Diablo, 71tattooguy and lynyrd3 like this.
  8. Aug 5, 2021 at 10:35 AM
    #48
    DAS Taco
    DAS
    2017 TRD Offroad
    Here is my Timbren's, compare sizes Timbren vs OEM (rear first picture and front the second).
  9. Aug 5, 2021 at 12:58 PM
    #49
    rimfire7
    rimfire7 [OP] I'm here for the tacos
    beth
    2021 army green taco
    Toytec lift, old man emu springs, Victory 4x4 front bumper and skids, light bar
    I need to learn more about reducing travel. With the new tacoma this was also a new concept as far as trucks go.
  10. Aug 5, 2021 at 12:59 PM
    #50
    rimfire7
    beth
    laughable
    JJ Diablo likes this.
  11. Aug 5, 2021 at 2:01 PM
    #51
    DAS Taco
    DAS
    2017 TRD Offroad
    In what way?
  12. Aug 5, 2021 at 2:02 PM
    #52
    71tattooguy
    Dino
    Petaluma , Ca (707)
    When size matters :rofl::rofl:
  13. Aug 5, 2021 at 2:03 PM
    #53
    rimfire7
    beth
    The size difference! What's the point of having one so small?
    a2lowvw and 71tattooguy like this.
  14. Aug 5, 2021 at 2:03 PM
    #54
    71tattooguy
    Dino
    Petaluma , Ca (707)
    :rofl::rofl::rofl::rofl::rofl:
  15. Aug 5, 2021 at 2:04 PM
    #55
    DAS Taco
    DAS
    2017 TRD Offroad
    Totally agree, but this is a common practice amongst all truck manufacturers. I think they do it to save money...who knows
  16. Aug 5, 2021 at 2:05 PM
    #56
    DAS Taco
    DAS
    2017 TRD Offroad
    Beyond funny :D
    71tattooguy[QUOTED] likes this.
  17. Aug 5, 2021 at 2:09 PM
    #57
    DAS Taco
    DAS
    2017 TRD Offroad
    One other thing, Tundra and Tacoma share the same OEM bump stops!, keeping in mind that Tundra is much heavier therefore if you hit something...
    JJ Diablo and rimfire7[OP] like this.
  18. Aug 5, 2021 at 2:29 PM
    #58
    rimfire7
    beth
    I'm getting the same protection? as a Tundra would.
    DAS Taco[QUOTED] likes this.
  19. Aug 5, 2021 at 6:20 PM
    #59
    DAS Taco
    DAS
    2017 TRD Offroad
    Yes you are
  20. Aug 6, 2021 at 4:59 AM
    #60
    pinem56
    NE
    2018 TRDOR DCSB AT
    The stock bump is primarily a failsafe. Its stiffness is made higher so it can sit lower and let the shock down travel more. This results in a very abrupt transition that isn't so great when doing whoops. All the aftermarket bumps exist to smooth this out. The trade off is that you hit your bumps sooner.
