Question regarding outlined white letters on tires
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoWI, Jun 7, 2023.
  1. Jun 7, 2023 at 3:10 PM
    TacoWI
    TacoWI [OP] Well-Known Member
    Jim
    2020 Cement TRD Off-road DCSB
    I have a rather trivial question but it does bug me. Putting new tires (BFG Trail Terrain) on my cement 2020 TRD ORDC. Everything is blacked out on the truck so I was going to have the tires mounted ‘outlined white letters inside’. It just looks cleaner to me. For anyone who has mounted tires with white letters inside do you see the white letters if you look at your truck from an angle from the front or rear? After a while I assume the inside of the tires will get dirty so may not matter anyway. Photo of current setup.
  2. Jun 7, 2023 at 3:16 PM
    AusBerg
    AusBerg Well-Known Member
    Austin
    North MN
    2022 TRD OR DCLB
    My ko2s have white on the inside, never even noticed until I was down there for unrelated reasons. They're so dirty you can hardly even notice they're white in the first place. Wouldn't worry about it.
    danielgonzzz and MannyS like this.
  3. Jun 7, 2023 at 3:17 PM
    WrecklessAbandon
    WrecklessAbandon They call me skippy
    Travis
    Olympia, WA
    Crocs with socks
    You can still see the white letters from certain angles but looks way better than white out :puke:
    r2pinter and danielgonzzz like this.
  4. Jun 7, 2023 at 3:19 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Yes, and yes. You answered yourself. They will get dirty, so you won't notice them.
  5. Jun 7, 2023 at 3:21 PM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    Fun to watch this thread go zany.
    if you look closely at many white outs after a few months even those are filthy. White in is nearly invisible.
  6. Jun 7, 2023 at 3:31 PM
    Crow41
    Crow41 Well-Known Member
    Lehigh Valley PA
    I had them on the inside of a previous truck and you would never notice it.
  7. Jun 7, 2023 at 3:36 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Paint them black if it bothers you.
    danielgonzzz and AusBerg like this.
  8. Jun 7, 2023 at 4:52 PM
    BillyE
    BillyE Well-Known Member
    I’ve never seen it unless I’m under the truck. Color it in with sharpie if you think it’s an issue.
  9. Jun 7, 2023 at 4:55 PM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Wide tip sharpie will take care of your issues
  10. Jun 7, 2023 at 5:00 PM
    DrRansom
    DrRansom Well-Known Member
    Utah
    Silver Sky 2021 SR5 Tundra 4WD
    Unrelated...
    I have the same rack setup on my truck. Does the wind faring help reduce the noise significantly?
    Tacomaryan18 likes this.
  11. Jun 7, 2023 at 5:09 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    You can see them for a little while. A few off road trips will cure that.
  12. Jun 7, 2023 at 5:19 PM
    bmgreene
    bmgreene Well-Known Member
    Brian
    L.A. Westside
    2010 PreRunner V6 SR5/OR
    Alcan Leaf Packs, OME884 Coils, 5100 shocks, U.S. Offroad Winch Mount w/Winch, Trail Gear Rear H/C Bumper, Prinsu Cabrack, DIY custom in-bed storage/sleeping deck, Sway bar delete, hidden "snorkel" intake mod, In-dash CB, Bestop Supertop, Undercover Swingbox, hood lifters, assorted lights and front spotting camera
    It's hard to make anything on an outer surface completely invisible to someone who's going to seek it out.
    I can't remember ever having accidentally noticed the inside face of my tires, but I also don't spend much time staring at the outsides of them either. Maybe if I spent half my day gazing at the tires on my truck, I'd probably catch a glimpse of the inside faces here and there. Or if I decided for some reason to crawl around the permieter of the vehicle while keeping my head within 12" of the ground I'm sure I'd see them.
    If you have a high-clearance front bumper and trimmed fenders, and look head-on while the wheels are at full "lock" steered to one side or the other that'd probably be the most likely situation in which you'd have a clear view of the inside face of a front tire while it's not in a fairly deep shadow.
  13. Jun 7, 2023 at 7:55 PM
    TacoWI
    Jim
    I have the Yakima jet stream bars. By themselves I could hear them but found that the fairing did help reduce noise in my opinion. Did not eliminate it but improved it. I also have a Yakima kayak rack that I can certainly hear even with the fairing, but that is to be expected.
    DrRansom[QUOTED] likes this.
  14. Jun 7, 2023 at 7:56 PM
    TacoWI
    Jim
    Thanks for everyone’s replies on this. Sounds like I should be just fine with black side out.
  15. Jun 7, 2023 at 8:17 PM
    arbezee
    arbezee Active Member
    Northern California
    Some tire shops can spray paint the white letters black prior to mounting them on to the wheels.
  16. Jun 7, 2023 at 8:19 PM
    ScrippsRanch67
    ScrippsRanch67 Well-Known Member
    Bob
    06 Tacoma Pre-Runner 2wd Quad Cab short bed
    Fiberglass shell
    You can see the white letters turned in only when you wake up next to your truck after a heavy night of drinking.
    arbezee likes this.
  17. Jun 7, 2023 at 8:20 PM
    ScrippsRanch67
    Bob
    Fiberglass shell
    Anza Borrego Desert?
  18. Jun 7, 2023 at 9:04 PM
    808stateofmind
    808stateofmind Well-Known Member
    Kona
    '22 Lunar Rock TRD OR 4x4 DCSB 6MT
    Eibach pro truck 2.0/2R lift kit 1.5" AAL OME/ARB UCA BFG KO2, 285/70-17 SCS Blaze 10, 17-8.5, -10 offset ECGS bushing needle bearing replacement Clutch accumulator disk delete Poor mans TRD intake, K&N 57 series intake tube, K&N high flow filter, TRD flow accelerator
    you might be able to find the same version with only black letters. I got Ko2's, and they make a few different part numbers. if you look up the part numbers and the specs on bfg's website, you see ones that are labeled RBL, and RWL, one being raised black letters, and raised white letters. get the RBL if you dont wanna have to see the white letters on the inside if you get white letters and have them flipped to the inside
    VaToy and Out2gtcha like this.
  19. Jun 8, 2023 at 6:19 AM
    MannyS
    MannyS Well-Known Member
    Republic of Texas
    You only see the white letters when you swap the needle bearings for an ecgs bushing
  20. Jun 8, 2023 at 9:02 AM
    6MTPro
    6MTPro Well-Known Member
    HI -> CA
    2018 TRD Pro 6MT | 2004 4Runner 4.7 V8
    Tune, 285/75/16, Diode Dynamics, PPF, Bakflip Mx4, Meso, Cali Raised, TJM
    I have white letters out on both my tacoma and 4runner with the 4runner having trail terrains (great tires by the way). Did it because I thought it complimented the white paint color nicely.
