Question on Rock Lights!!
Discussion in 'Baja Designs' started by PerRunner_Taco2wd, Mar 18, 2020.
  1. Mar 18, 2020 at 5:10 PM
    PerRunner_Taco2wd
    PerRunner_Taco2wd [OP] Member
    Joseph
    2013 white Tacoma
    Stock
    My buddy has Amber Rock Lights from baja Design and it's hooked up to a Switch-Pro. He didn't have any problems with it till like a year Later then the lights starts not to work. He says only the passenger Front and passender rear side lights work not the driver side front or rear but the driver side rear it flashes like it wants to come on but it doesn't. Does anyone have in idea of what it could be? A bad light or a pinch wire somewhere
  2. Mar 18, 2020 at 5:18 PM
    Baja Designs
    Baja Designs The Scientist of Lighting Vendor
    San Marcos, CA
    PerRunner_Taco2wd,
    I would double check the wiring and ensure you don't have any breaks in your leads. Also, check your grounds and see if there's any corrosion. To test the light, you can also do a direct power test with a 12v car battery. By putting the red wire to the positive terminal and grounding out the black wire on the negative terminal, it should turn on the light.
  3. Mar 18, 2020 at 5:36 PM
    PerRunner_Taco2wd
    Joseph
    2013 white Tacoma
    Stock
    Ok thank you I'll check that out.
    Baja Designs[QUOTED] likes this.
  4. Mar 19, 2020 at 10:24 AM
    Baja Designs
    San Marcos, CA
    If for some reason the light does not turn on, our LED products do have a limited lifetime warranty. PM inbound on warranty information. Thank you!
    asudevil likes this.
