Question For 9SIX9 Wheel Owners
Discussion in '3rd Gen. Tacomas (2016-2023)' started by atc250r, Dec 1, 2022.
  1. Dec 1, 2022 at 9:43 AM
    atc250r
    atc250r [OP] Recovering Ram Owner
    Orange County, NY
    2022 Tacoma SR5 - DC/LB
    LED interior, license plate, and fog lights. More to come.
    Going to be putting a set of 9SIX9 Six-1 wheels on and was wondering if others with these wheels are running standard splined lugs or if extended thread is needed with them. I tried their website but their "contact us" form link is broken. Waiting for word back from the place I bought from but I trust those of you with first hand experience more.
    Thanks!
  2. Feb 11, 2023 at 1:45 PM
    PowerKord
    PowerKord Member
    Ohio
    I'm looking at these wheels too. Did you ever get them installed?
  3. Feb 13, 2023 at 5:14 AM
    atc250r
    Orange County, NY
    I did. You could likely fit a standard hex "acorn" type lug if it is a 19mm hex but I had already ordered a set of splined lugs. I'm not comfortable with the number of threads the lugs catch on the front so I'm debating whether I'm going to drill the wheels so the splined lugs with the short shank on the end will fit or if I'm going to get slightly longer studs. If I can find a stud that is maybe 1/4" longer than stock that would be the way I'd like to go. The wheels are off for the winter so I've got a little time to figure it out. 20230105_164232~2.jpg 20230105_164218~3.jpg
    PowerKord[QUOTED] likes this.
  4. Feb 13, 2023 at 2:12 PM
    PowerKord
    PowerKord Member
    Ohio
    Thanks for your feedback. What size and offset wheels are those?
  5. Feb 13, 2023 at 2:15 PM
    atc250r
    Orange County, NY
    17x8.5 -12mm offset. 265/70r17 Cooper Rugged Treks.
    PowerKord likes this.
  6. May 23, 2023 at 4:32 PM
    need4gforce
    need4gforce Member
    What did you end up doing? So strange that these would have so much extra flange to make it shorter. Maybe I dont want to pull the trigger on a set of these??
  7. May 24, 2023 at 3:39 AM
    atc250r
    Orange County, NY
    @need4gforce I've just been running it. It's not that these wheels have an exceptionally thick flange, these trucks have very short lug studs.
  8. May 24, 2023 at 4:47 AM
    need4gforce
    need4gforce Member
    Right on! Do you have a link to the lug nuts? Thanks
  9. May 24, 2023 at 7:18 AM
    atc250r
    Orange County, NY
    I used these. I don't run these wheels or lugs in the winter so I wasn't worried about them getting crusty because they're cheap.
    DPAccessories Black Spline Lug Nuts - m12x1.5 Lug Nuts 24 Pack for Aftermarket Wheels - Spline Tuner Lug Nuts 12x1.5 - Set of 24 Black Lug Nuts and One Spline Lug Nut Socket - D5246P-2308/24 https://www.amazon.com/dp/B00JH1HODY
  10. Feb 7, 2024 at 10:26 PM
    ticklemytaco
    ticklemytaco Well-Known Member
    I just ordered a set of Six-1 deeps. Hopefully they thread well.
    Were yours the standard six-1 or the six-1 deep?
  11. Feb 23, 2024 at 7:34 AM
    atc250r
    Orange County, NY
    Mine are the standard ones. They thread OK. I'd like more engagement in the front but it is what it is.
