Question about what jack/lift/inflatable jack would be good for offroading
Discussion in '3rd Gen. Tacomas (2016-2023)' started by urchim, Apr 29, 2024.
  1. Apr 29, 2024 at 8:18 AM
    urchim
    urchim [OP] Well-Known Member
    Tacoma 2016 TRD Offroad Inferno
    Looking for advice there, so ran trails this weekends and ran a flat on trail, so found out that using my solution which is 5ton jackstand lift
    Amazon.com: Powerbuilt 3 Ton, Bottle Jack and Jack Stands in One, 6000 Pound All-in-One Car Lift, Heavy Duty Vehicle Unijack, 640912 : Automotive
    didn't work to well, because we were on rocky trail and it didn't go under to well and couldn't get enough clearance and in end up using scissors jack from a friend, and after looking over other options, i can not use the Amazon.com: Torin TRA8335 33" Ratcheting Off Road Utility Farm Jack, 3 Ton (6,000 lb) Capacity, Red : Industrial & Scientific
    and looking for advice what others have use, i don't want to carry whole 200 pound lift jack on 4 wheels but curious what others used,
    i came cross inflatable lift bags, was wondering if anyone use these
    Amazon.com: VEVOR Air Jack, 3 Ton/6600 lbs Triple Bag Air Jack, Airbag Jack with Six Steel Pipes, Lift up to 17.7", 3-5 s Fast Lifting Pneumatic Jack, with Adjustable Long Handles for Cars, Garages, Repair (Blue) : Everything Else
    any input is welcome.
  2. Apr 29, 2024 at 8:58 AM
    RichochetRabbit
    RichochetRabbit Ping Ping Ping
    This has big tires for mud/dirt and you can put wood under as well ... seems popular enough to have been (and maybe still) not immediately in stock at Harbor Freight:
  3. Apr 29, 2024 at 1:16 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    oem jack and a 2x8 piece of wood
    ricco333 and Tocamo like this.
  4. Apr 29, 2024 at 1:37 PM
    RichochetRabbit
    I made a flat structure that also serves as my makeshift service ramps. If I plan to be far off-road I will toss in those and my traction boards.
    RIX TUX[QUOTED] likes this.
  5. Apr 29, 2024 at 3:15 PM
    Volt
    Volt Well-Known Member
    Overland Park, Kansas
    2022 SR5 4x4 Double Cab V6
    My fourth red Tacoma
    Concerning those farm jacks, back in the day I witness a bumper jack pop off the bumper of a 69 Caprice. It hit a guy across the face with a lot of force causing considerable injury. It was an inch from braining him or perhaps killing him.
    soundman98 likes this.
  6. Apr 29, 2024 at 3:19 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    The one time I needed a jack, the oem jack worked fine. I also own a hi-lift, but stopped bringing it with me after multiple bad experiences.
    TBQH, I haven’t had a flat in over 10 years and never with my 2016 or 2020 tacos.
    Was it not feasible to drive your truck to a better location to fix a flat?
  7. Apr 29, 2024 at 3:20 PM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    M85 likes this.
  8. Apr 29, 2024 at 3:33 PM
    urchim
    how about anyone experience with scissors jack? i dont like oem lift bottle because its to unstable in my opinion even with all boards you put on it, given it has less than 2 " head to push against. Anyone used these phenamatic things?
  9. Apr 29, 2024 at 4:29 PM
    M85
    M85 Well-Known Member
    Colorado
    2019 SR ACLB
    Safe Jack makes kits with a bottle jack and various attachments like an axle cup and extension, that help add stability and height. The travel on the bottle jack is still pretty limited, so even with extensions you might have trouble if you try to lift by the frame rather than by the axle, depending on where you lift.
  10. Apr 29, 2024 at 4:30 PM
    TacoTuesday1
    FL
    Don’t see what’s wrong with a cheap 60 hi lift
    And badlands off road Jack
    used them in parking lot. Used them at home. People use it off road.
    haven’t slammed into a sharp rock to pop the tire on trail to need that but I carry it for if that does happen.
    my old Alcan floor jack without a spacer wouldn’t even reach the truck at max height. Sold it. Guy said he was gonna get a spacer adapter and his truck was lower. Confirmed it reached.
    I guess an air bag jack could be good if it’s quick to operate, safe, portable
    For a wider footprint than teetering on an angle with a conventional jack.
  11. Apr 29, 2024 at 4:37 PM
    gudujarlson
    Minnesota
    Another trick I have used is to dig a hole and place the bottle jack at the bottom with some wood or rocks under it.
  12. Apr 29, 2024 at 5:35 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Another vote for the 2x8. Fits behind your back seat...
  13. Apr 29, 2024 at 6:04 PM
    RichochetRabbit
    Useful for controlling unruly passengers ... :eek:
  14. May 5, 2024 at 2:36 PM
    urchim
