Question about professional vacuum A/C recharge vs A/C Pro Canister
Discussion in '2nd Gen. Tacomas (2005-2015)' started by becker.adam2, Apr 22, 2022.
  1. Apr 22, 2022 at 4:15 PM
    becker.adam2
    becker.adam2 [OP] Member
    Adam
    2000 Toyota Tacoma SR5 3.4L V6
    I have been troubleshooting my A/C system for a while now and have replaced the condenser and compressor and finally figured out that it was a leak in the seal in the compressor housing case where the two pieces of the case seal in the middle.
    Over the past year, I have had the system professionally recharged twice (pulled a vacuum, and replaced the refrigerant). I recently pulled the faulty compressor out and replaced it, so now I need to charge the system again.
    My question is this: Do I need to pay another $85 for a professional recharge? or can I recharge the system with a simple canister? DO I need to pull a vacuum again?
    Thanks in advance!
  2. Apr 22, 2022 at 4:17 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    Absolutely do a professional recharge, especially if it's only $85.
    A proper machine should pull vacuum and dispense the exact correct amount of refrigerant and oil into the system to make sure it works at it's full potential.
  3. Apr 22, 2022 at 6:20 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    No need for a professional but stay clear of the cheap refill kits with built in gauges. Any time the system is breached it’s a good idea to draw a deep vacuum and then you want to make sure the proper amount of PAG oil and refrigerant are added per the FSM
    grizquad and Dm93 like this.
  4. Apr 22, 2022 at 7:10 PM
    $yoda$
    $yoda$ Well-Known Member
    Tom
    2007 Tacoma 4.0
    2.5 inch lift, 285/75r16s, upgraded stereo system, Magnuson mp90 supercharger system.
    Professional for sure on this one.
    grizquad likes this.
  5. Apr 22, 2022 at 7:15 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    You must vac the system down before charging or it will never work correctly -- or for long.
  6. Apr 22, 2022 at 7:49 PM
    Pearson
    Pearson Well-Known Member
    Elliott
    Lexington Texas
    Black 2012 2.7L Prerunner
    IMHO at $85 clams, it's a no-brainer, not that it's a difficult DIY effort. It's more of a question of whether or not you have the time, proper equipment, and know-how. Or perhaps better, is it worth the savings to do what you have to do to properly prepare and do the work yourself.
    grizquad, Dm93 and RustyGreen like this.
  7. Apr 22, 2022 at 8:09 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    I'd agree, assuming the folks doing the work are knowledgeable and do a decent job, hopefully it's not Jiffy Lube or a Pep Boi providing that quote LOL
    Dm93 and Pearson[QUOTED] like this.
