Question about chain hoists
Discussion in 'Recovery' started by Hurley_man, Mar 24, 2017.
  1. Mar 24, 2017 at 7:35 PM
    Hurley_man
    Hurley_man [OP] Well-Known Member
    Las Vegas, NV
    16 DCSB OR 4x4
    Traded my 2012 sport for the 16
    Afternoon gents, I was wondering if anyone on this wonderful forum has used a chain hoist for recovery. I'm not really ready to get a winch and bumper however, I wanted some type of recovery when I'm out exploring. I was looking at vertical as well as horizontal chain hoists as an option and I am wondering if anyone has used or uses thrm for recovery.
    I think vertical hoists might be out of the picture because if I'm right, which I'm usually not, need to be used vertical only so the chains are in line.
    Thanks for any info/feedback.
    Hurley
  2. Mar 28, 2017 at 11:14 PM
    tetten
    tetten Cynical Twat Waffle
    Andy
    Socal
    That last part of your post is accurate. Also general recommended winch rating is 1.5times your vehicle weight, which on an armored or expo truck puts you at around 8500lb-ish or more. A 4ton come-along or hoist weighs a shit load and would be completely impractical out on a trail. I know this because I use them at my job from time to time. Also they would likely be just as expensive or more so than a budget brand winch.
    If your going for budget recovery you can always use a hilift as a winch.
  3. Mar 29, 2017 at 10:23 AM
    '14RC
    '14RC WA State
    Seattle
    2014 4x4 Regular Cab 5MT
    2" Lift & 32" tires w/ Camping Setup (see details) Suspension: Dobinson 2" Coils (PN: C59-316) 4x Bilstein 5100's (base setting) SPC Upper Control Arms Deaver J66 Leaf Springs Ride-Rite Airbags Archive Garage Hammer Hangers Poly Leaf Spring Bushing Camping: SnugTop Canopy ARB awning Built a Camping Shelf in the Bed Yakima Mega Warrior Roof Basket Interior: Bucket Seat Conversion Acoustically Insulated Interior Added Cruise Control Rear Storage Organizers Traction: Yellow Wire Mod Alloy's with 265/75/16 Towing: Aftermarket Class III Tow Hitch Trailer Wiring Brake Controller (wired, not installed) Misc: ECGS Bearing NH Oil Undercoating
    Im not willing to upgrade to a bumper/winch either so I have a 2 ton US made come-along, Hi lift, snatch block, and an extra 60 feet of good cable.
    Alternatively, you could get one of those winches that sit in a basket and mount to a trailer hitch. That way you just remove it when your not out exploring.
  4. Mar 29, 2017 at 10:28 AM
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    '18 T4R & '06 F250
    6" lift 40s
    Winch. It really isn't that expensive when you compare it. Budget winch for ~$400. (nice winch for $1000) The big variable is how you mount it. I made my bumper so it cost about $75. So there is that...
    Without winch you might justify (and these are good things to have as well)
    -Hi-Lift (~$100)
    -Maxtrax (~$400)
    -Come along (~$50)
    etc.
  5. Mar 29, 2017 at 10:35 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    I have a chain hoist in my shop, but its only 1 ton. but it has to be vertical to use. I does however work great, not that fast but Ive only used it once to remove/install a 2.2 4 cylinder engine. So speed isnt really what you need. I do plan on using it for hanging animals during hunting season as well but other than that its not really used for much.
  6. Apr 4, 2017 at 1:29 PM
    tacojefe
    tacojefe Well-Known Member
    Eric
    Western Maine
    2012 Tacoma
    +1 A Highlift Jack will "work you" hard, but I've gotten out of many jam's with one, always pulling, never jacking. I'm not sure what the new jacks come with for attaching chains to when pulling, but make sure you have that hardware with you. (a couple of screw clevis's & chain grab hook's).
  7. Jul 26, 2017 at 11:24 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    I've seen a griphoist used this way on a long cable - they are expensive though!
