Question about bolts / hardware / fasteners
Discussion in '1st Gen. Tacomas (1995-2004)' started by Maestro, Oct 12, 2016.
  1. Oct 12, 2016 at 8:56 PM
    Maestro
    Maestro [OP] Well-Known Member
    The Master
    I am combing through a new purchase - a base 2002 4x4 extended with less than 50k miles and I am finding some rusted bolts here and there. The truck is completely Toyota with no damage and no aftermarket anything. I'd like to keep this one as stock as possible but I also want to swap out some of this old hardware.
    My question is - where do you get automotive metric hardware? Is the stuff from the racks at Home Depot suitable or do I need to order a specific type of fastener for automotive purposes? I'm not talking about mission critical stuff like brake bolts, but more like skid plate bolts. Also, do I increase the chances for rust / metal reactions by using the wrong kind of fastener (zinc / stainless / etc?)
    I know I could find he right size and thread - I just want to do it the RIGHT way.
    I'm hoping someone has already thought this through - thanks in advance.
  2. Oct 12, 2016 at 9:10 PM
    Artruck
    Artruck Well-Known Member
    Lawrence, KS
    '09 Super Basic
    I have always found hardware easy to find in my neighborhood store, but just make sure you get a replacment as strong as the oem part.
    As far as material like zinc or stainless, it wou.d depend on the location and purpose of the fastener. If you are fighting off a rusted to peices bolt, maybe a stainless replacment will be the best bet. And you can always add a little anti seize for insurance against any issues of steel on aluminium.
  3. Oct 12, 2016 at 9:44 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    I purchase from NAPA or my local dealship if I must.
    I prefer using bolts with a higher grade then was the original.
    But if that's not obtainable... I'll get the original at the very least.
    Only a dealership will offer the original hardware.
    Maybe some can be found on ebay... listed by dealerships.
    After market can meet or exceed oem specs...
    But may not look exactly as did the factory originals.
  4. Oct 12, 2016 at 11:04 PM
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    I have a copy of the Toyota electronic parts catalog. I can find the nut and bolt part numbers from that, then order online, like from www.toyotapartsdeal.com. A little pricey, but I know it will be the correct part, like before I remove the nut or bolt. If you know the sizes, you can order online from a place like www.boltdepot.com. They have class 8.8 and 10.9 metric, zinc plated, and stainless steel depending on what you need. Also, flange bolts, the type that's like a washer built in.
  5. Oct 13, 2016 at 12:28 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Remember Toyota uses JIS Hardware (Japanese Industrial Standard) Which some places can be very hard to find local
    The only local place to me is my dealer The hardware prices are quite good.
    M6x1.00 M8x1.25 M10 X 1.25 M12x1.25 are the most often used sizes
    Bel-Metric out of Mass. I have ordered from in the past and I should order before the Holiday Season ramps up
    Now I have a bolt bin for JIS Hardware so I am fixed pretty good .
    SR-71A likes this.
  6. Oct 14, 2016 at 4:43 AM
    Mark D.
    Mark D. Well-Known Member
    '96 base 4 cylinder Tacoma standard bed
    Added ARE fiberglass raised cap & Sony CD head-unit w' aux-input
    Some of the odd-head/odd-thread JIS stuff is just not availible in local hardware or autoparts stores. If you need certain specific Asian nuts & bolts right away, the dealer may be your only choice.
    Otherwise, when I'm looking for some part at the local Pick-N-Pull salvage yard, I'll often grab a handful of metric nuts & bolts. Usually, other people removing parts just leave the hardware on the ground. The fasteners may not all be brand spanking new, but they're factory hardware, you can select the best examples, and the price is right. Over the years, I've built up a decent stockpile of Asian & German automotive hardware.
    Happy Motoring, Mark
  7. Oct 14, 2016 at 4:45 AM
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
    I use Ace Hardward in bolt's section ... good selection.
  8. Oct 18, 2016 at 7:34 PM
    Maestro
    The Master
    Great responses - thanks all.
