Question about bolts for hitch...help
Discussion in 'Towing' started by r12rex, Aug 11, 2009.
  1. Aug 11, 2009 at 8:48 PM
    r12rex
    r12rex [OP] Well-Known Member
    Cleared headlights, Black emblems, Painted black valence on front bumper, 2.5" 5100 Billys front, 1.5" AAL rear, Satin black TRD O/F wheels with 265/75 16 Definity M/T, Spidertrax spacers
    Guys,
    Just bought a Uhaul hitch from a local used. He did not include the four bolts that mount the hitch to the frame (the other two that mount to the bumper I have). I was wondering what size bolts are to be used so I can go pick some up? Need thread pitch and size. Also any spacers needed or anything for the install?
    Kind Regards,
    BTW, it is a class III hitch
  2. Aug 12, 2009 at 4:17 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Is the frame actually threaded? Or no?
    I wasn't sure....
  3. Aug 12, 2009 at 4:35 PM
    JKD
    JKD Well-Known Member
    I just put on a hitch yesterday (a Valley hitch). The front bolts are listed on the instruction sheet as 12mm x 1.25mm x 35mm Hex Bolt. I think they were metric grade 8.8, stamped on the bolt heads. They each had a conical washer installed, and were torqued to 75 foot pounds. The frame mounting points were threaded.
    The bolts that go through the bumper were listed as 5/8-11 x 3-1/2 Flat Head Socket Bolt. They had wedge-shaped spacers, a 5/8 lockwasher, and a 5/8-11 hex nut. I didn't see a grade. The torque spec on the bumper bolts was 150 foot pounds, so I would probably just go with grade 8 (standard, not metric) hardware on these to be safe.
    By the way, when I replaced the plastic covers on the bumper step, I had to trim a lot of the plastic "X" and the ring surrounding the "X" before the covers would snap on.
  4. Aug 12, 2009 at 5:40 PM
    06dak
    06dak Well-Known Member
    Central Ohio
    05 PreRunner SR5 4cyl
    Undercover hard tonneau, Husky front liners
    Ryan, make sure you got the spacers needed, or the hitch really wouldn't sit right! Also, the Uhaul hitch is the same as the Valley but different than all the others.
  5. Aug 12, 2009 at 9:15 PM
    r12rex
    Thanks guys!
    I have the bolts and the wedge spacer for the bumper :)
    Went to Fastenal, Home Depot, and Autozone with no luck finding the right size/pitch bolts. I ended up at the Toyota Dealership and bought the four bolts they use to mount the factory hitch. $7 bucks and some change. :) Just have to wait till Friday to pick them up.
    I installed the hitch using the two bolts and removed one bolt on each side of the bumper mounts to temporarily mount the hitch. No worries it won't be used lol, just don't want to have to get under there again.
    Kind Regards,
    PzTank likes this.
  6. Nov 10, 2021 at 1:53 PM
    Keefox
    Keefox Active Member
    Cory
    2011 Tacoma Sr5 2.7l
    What size were the bolts that Toyota sold you?
