Question about axle wrap?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jonny_jard, May 12, 2008.
  1. May 12, 2008 at 5:46 PM
    jonny_jard
    jonny_jard [OP] Well-Known Member
    Alberta
    06 Taco
    3" suspension lift, bull bar, IPF 100w flood light system, side bars, custom fit leather seat covers, URD CAI, URD MAF calibrator,
    Just thinking that with all the concern of having the blocks in the rear for the lift and the possible chance of having axle wrap, should i have the blocks taken out? How much of a concern is axle wrap?
  2. May 12, 2008 at 6:08 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Axel wrap can cause premature wear on your springs. If you have an automatic, it may make a "thump" sound when you come to a stop and let off the brakes.
  3. May 12, 2008 at 6:19 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    Wow Chris- I've got that too, and it's done it since new and I thought it was the tranny not coming into 1st, because it happens if I stop more abruptly than usual. What's the cause?
  4. May 12, 2008 at 6:21 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i had axle wrap on my 06 prerunner, but that basically went away when i got the rear leaf tsb done. i guess it was the spring stiffness that made it go away. i have also heard traction bars help alot with axle wrap.
  5. May 12, 2008 at 6:30 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The leaf springs on the Tacomas are on the soft side of the spectrum. That being said ( please follow me on this) When power is applied to the tires, the torque moves your rear axel up a little bit causing the springs to twist like an "S" just not as dramatic. When you are at crusing speed the springs relax into their normal state. Now, when comming to a stop ( with an auto and below about 15 m.p.h. ) your engine is still trying to turn the tires and the differential is moveing up a little bit twisting the springs. When you are stopped and let off the brakes or ease off them, the springs unload and you hear the "thump". A small amount a axel wrap is not a bad thing and is normal on most Tacomas. It can be tammed with the addition of an AAL. Blocks will amplify the problem and as they move the fulcrume point where the axel mounts on the springs, thus leading to premature wear on the springs. In many cases if the block is poorly made, they can shatter, crack, or whatever and cause a big problem.:)
  6. May 12, 2008 at 6:34 PM
    Toy4Life
    Toy4Life 668: The Neighbor of the Beast
    Chad
    Slippery Rock, PA
    96 Subaru Outback 2.2 5mt
    92 4Runner SR5 3.0v6 4x4(sold) 02 Tacoma SR5 TRD Offroad 4x4 (sold)
    +1 I always thought my truck was just klunking into 1st. Now that you mention it, It really hasn't done it since the addition of my AAL. Good info, Chris.
  7. May 12, 2008 at 6:34 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I have a very little bit of axel wrap on my truck. Even with the TSB springs and my AAL. My AAL is a long thin one made just to give 3/4" lift and to help keep the truck level from side to side. Trac bars help if they are mounted correctly, but they can get in the way when off roading. :)
  8. May 12, 2008 at 6:38 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    Damm Chris you're a polished stone on these things! I get what you described perfectly-thanks. Also can you please answer my recent thread on MAF? I trust in your answers
  9. May 12, 2008 at 6:41 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Thank you!:) I'll look for the post.
  10. May 12, 2008 at 6:46 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yeah.....from some of the trac bars i've seen.....they look like they would be in the way alot for offroading. with a lift....they look really low.
  11. May 13, 2008 at 3:09 AM
    GotLift37
    GotLift37 Bangers Runner
    North East AL
    07 4Runner 4WD
    2.5" front lift (leeper coilover) 1" body 16" Dick Cepek DC1 Black/polished 295/75/16 General Grabber AT2 Tinted Taillights 5% tint OEM Acura TSX HID Retrofit White LED dash light conversion WMW roof rack
    Hmm no axles wrap with my truck. Figure I would with a 6" block. Must have been done right:D
  12. May 13, 2008 at 4:01 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Axle wrap also.....when you stomp on the gas and the rear-end bounces around and doesn't stay firm on the road.
  13. May 13, 2008 at 8:57 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    The traction bar I'm having built is purposely going to hang lower than the driveshaft to serve as protection. It'll have a skid on the bottom to slide over obstacles and keep the driveshaft out of harm's way.
    Low isn't always a bad thing, depending on what it's just lower than. :p The trick is to design it so it doesn't affect articulation.
  14. May 13, 2008 at 9:48 AM
    nd
    nd Radical Town. It's a hell of a place!
    Nate
    Greenville, SC
    07 TRD Off-Road 4x4 debadged
    De badged, 5100's, Black Toyota Baja wheels
    very good explanation, that deserves some rep...
  15. May 13, 2008 at 9:56 AM
    jonny_jard
    Alberta
    06 Taco
    So as long as a guy keeps an eye on the blocks everything should be somewhat ok....?
  16. May 13, 2008 at 12:22 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    ..............already there:)
  17. May 13, 2008 at 1:03 PM
    j4x4ar3
    j4x4ar3 Well-Known Member
    Jay
    Austin, TX
    05 DC 4x4 - TRD Off Road - White
    Round Step Bars, Bed Mat, Cargo Bars, Rocky Mounts bike mount, JVC MP3 Head Unit, TRD Cat Back Exhaust, Rigid Industries front and rear light pods, dual HAM radio with remote mount heads.
    Take a look at this link... I added this system to my truck as opposed to getting the TSB. Didn't want the stiffer ride from adding an AAL and didn't want to spend the $$$ for air bags. Did my first trip over the weekend pulling my trailer and it made a very big difference in handling. My trailer is 26' 5000# loaded with about 650# tongue weight.
    This system works not just for towing but for daily driving as well. Also said to help eliminate axle wrap without sacraficing ride. I personally never noticed axle wrap but I did notice a difference (improvement) in ride once I added them.
    http://www.activesuspension.com/how05.htm
