Question about auto headlights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tacomashopper, Dec 28, 2018.
  1. Dec 28, 2018 at 2:02 PM
    Tacomashopper
    Tacomashopper [OP] Ricardo's Taco
    RICHARD
    Birmingham, Al
    2019 Cavalry Blue Sr5 DCSB 4x4
    The 2018 SR I am looking at has auto high-beams, does that mean that the headlights are auto? or, just the high beams?
    Thanks
  2. Dec 28, 2018 at 2:04 PM
    daddy_o
    daddy_o Well-Known Member
    Bossier City, La
    2018 TRD Sport, Inferno, w/tech package
    Factory Blackout package, Soft roll up bed cover, Cheap seat covers, Front and rear dash cam, AVS in channel vent visors
    It means when you have your high beams on, if it senses another vehicle it will automatically dim. The problem with this is reflections from road signs.
  3. Dec 28, 2018 at 2:05 PM
    Tacomashopper
    RICHARD
    Birmingham, Al
    OK, but this doesn't mean that the headlights will automatically turn off when you stop the engine, correct?
  4. Dec 28, 2018 at 2:07 PM
    Tacoma3rdGen
    Tacoma3rdGen Well-Known Member
    New Mexico
    2018 Tacoma Limited
  5. Dec 28, 2018 at 2:09 PM
    Tacoma3rdGen
    New Mexico
    2018 Tacoma Limited
    You’re confusing “auto” headlights with “auto high beams”...
    garbagebarge likes this.
  6. Dec 28, 2018 at 2:10 PM
    Tacomashopper
    RICHARD
    Birmingham, Al
    I understand the difference, I am just asking if there are auto highbeams, if the headlights are auto as well. Two different things, just trying to see if they are both there.
  7. Dec 28, 2018 at 2:11 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    I don't think so on this model. I think it simply means it will turn the headlights off with the key if you happen to leave them on.
  8. Dec 28, 2018 at 2:11 PM
    Tacoma3rdGen
    New Mexico
    2018 Tacoma Limited
    You will have a push button for auto high beams... stalk switch (turn function) for auto lights
  9. Dec 28, 2018 at 2:18 PM
    mmatheny
    mmatheny Well-Known Member
    Dickinson, Tx
    2017 SR5 DCSB Magnetic Gray Metallic
    BakFlip MX4
    My brother has a new Ridgeline with it and the reflection off the signs give it hell.
    shakerhood and daddy_o[QUOTED] like this.
  10. Dec 28, 2018 at 2:18 PM
    daddy_o
    Bossier City, La
    2018 it has the TSS added, which I thought included auto high beams. That will be a button down by the left cubby.
    hiPSI[QUOTED] likes this.
  11. Dec 28, 2018 at 2:43 PM
    LDrider
    LDrider Well-Known Member
    New England
    2019 SR 2.7 Access Cab 4x4 (sold to Carvana!)
    No. Yes.
    Secondchildhood likes this.
  12. Jan 25, 2019 at 5:14 PM
    garbagebarge
    garbagebarge Well-Known Member
    Occasionally someone in a parking lot will try to tell me that I've left my lights on.
  13. Jan 25, 2019 at 5:30 PM
    bluzharp
    bluzharp Well-Known Member
    Central AR
    19 OR DC LB Cement (the slowest color)
    Pro Suspension, Roadmaster overloads, Diamondback
    The auto dim function is horrible and worse than just dipping the high beam manually.
    Auto off headlights are fine and work as designed.
  14. Jan 25, 2019 at 5:36 PM
    Volt
    Volt Well-Known Member
    Overland Park, Kansas
    2022 SR5 4x4 Double Cab V6
    My fourth red Tacoma
    My 2018 SR has the auto high beams and it does not work well. I keep it deactivated. It does not have auto headlights.
    Boghog1 likes this.
