Qi Wireless Charger not working...Any Suggestions?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ecesp004, Jan 30, 2017.
  1. Jan 30, 2017 at 5:01 AM
    Ecesp004
    Ecesp004 [OP] Well-Known Member
    Eric
    2017 Tacoma TRD Off Road
    Hello Tacoma World Family!
    I just purchased my Tacoma TRD OR DCSB and have not been able to enjoy my Qi Charger. I have a Samsung S7 that has wireless charging capabilities and says it is compatible on the Qi Website.
    Does anyone have any suggestions? Or should I just take it to the dealer maybe its just faulty or disconnected?
    Thanks.
  2. Jan 30, 2017 at 5:03 AM
    tacoflavoredkisses1
    tacoflavoredkisses1 Well-Known Member
    16 TRDOR DCSB (SOLD)
    I would get my hands on an old galaxy note 7 and leave it charging overnight. That should fix your problem.
    smitty99 likes this.
  3. Jan 30, 2017 at 5:04 AM
    TRDRon14
    TRDRon14 Active Member
    WV
    2014 Pyrite Tacoma TRD Sport
    Do you have a case on it?
  4. Jan 30, 2017 at 5:06 AM
    Ecesp004
    Eric
    Lol.....I like my Tacoma too much.
  5. Jan 30, 2017 at 5:07 AM
    Ecesp004
    Eric
    I do have a UAG case on it but removed it to test. Still does not work. I wirelessly charge with my samsung one every night with the case though.
  6. Jan 30, 2017 at 5:23 AM
    daddy_o
    daddy_o Well-Known Member
    Bossier City, La
    2018 TRD Sport, Inferno, w/tech package
    Factory Blackout package, Soft roll up bed cover, Cheap seat covers, Front and rear dash cam, AVS in channel vent visors
    Not trying to be an ass here, but you are pushing the button to turn on the qi pad arent you?
    Sometimes you have to move the phone around to find the sweet spot.
  7. Jan 30, 2017 at 5:26 AM
    gpb
    gpb Well-Known Member
    Atlanta
    2017 White DCSB TRDOR 4x4
    Hang out here a while, TW will cure you of that soon enough.
    As for the Qi charger, definitely make sure you're turning it on as mentioned by daddy_o. Find a friend with a Qi enabled phone and try it with theirs. Ideally, also try your phone in a different truck.
    i.e. basic diagnostics technique...
  8. Jan 30, 2017 at 5:40 AM
    TRDRon14
    WV
    I know with some cases wireless charging can have problems and also with placement. I don't do much of it but it sounds like you aren't a rookie at it. I'd try to check a fuse. Just drawing straws
  9. Jan 30, 2017 at 6:09 AM
    Istan
    Istan Leave it stock they said
    Stan
    Vegas and Yuma
    03 Xtra Cab 5Speed 4*4
    Where are you placing the phone? I have a s7 edge with a flip Samsung case on it and mine works. Just make sure the phone is placed on the pad closest to you in the driver seat. Ie, Southwest portion of the pad. You should see the yellow indicator light turn on.
  10. Jan 30, 2017 at 6:37 AM
    Ecesp004
    Eric
    Yes I have the Qi switch turned on. Just restarted my phone and placed it closer to the passenger side and it started working. Found the sweet spot. I don't know if I just needed to restart my phone or just had to find the sweet spot. Thanks Guys.
    gpb likes this.
  11. Jan 30, 2017 at 6:38 AM
    Ecesp004
    Eric
    It's working now issue resolved. Just reset my phone and made sure it was up to date. Started working.
  12. Jan 30, 2017 at 7:08 AM
    gpb
    Atlanta
    Yep, having disassembled Qi chargers (see my charging mount DIY in my signature) the coils are about 2" diameter and you really need to get centered on it. Much easier when the puck is on a table, not quite so easy when it's sitting under the floor of a cubby. There are markings/outlines that should help once you've found the sweet spot.
  13. Nov 9, 2017 at 5:19 PM
    KB3
    KB3 Member
    2018 Inferno Tacoma DBLCB OR
    Mine just flashes both orange and green lights but never connects to the phone.
  14. Feb 25, 2018 at 11:27 AM
    TJenkins
    TJenkins New Member
    2017 black Tacoma TRD Sport
    leveling kit, fuel 17" wheels, TRD PRO grille
    Mine is doing the exact same thing. It worked until today. Anyone know how to fix this?
