Python 580 remote start pictorial
Discussion in 'Audio & Video' started by hookedontronics, Jan 3, 2012.
  1. Jan 3, 2012 at 6:00 AM
    hookedontronics
    hookedontronics [OP] Well-Known Member
    Jake
    Glenville, NY
    2010 DC Off Road 4x4
    Icon extended travel 3.5" front coilovers, DSM UCAs, TSB leaf pack w/ wheelers AAL, All Pro U-bolt flip kit, Walker Evans 2.0 rear shocks, 18" XD Monster rims, Nitto trail grappler 285/65R18 Tires, Color matched grill, Grillcraft, Kragen HIDs, Carling switches, my bed light mod, diff drop, Alpine IVA-W505, JL Audio C5 componets and coaxials, JL 300/4 and 250/1 amps and JL stealthbox, wheathertechs, avs vent visors, toyota bed x-tender, alcantara center console cover and door pocket covers, console vault, color matched mirrors, heated mirrors, etc etc etc
    Yesterday i had a local guy install a python 580 for me. He made this thread on the12volt.com i've copied it here. I've seen a lot of question here lately on remote starters and installs. I've done a lot of custom audio in the past but didn't want to mess with a remote start on my truck the first time around by myself. This should help people looking for what specific wires and connectors they will need to hook up to do do this install. FYI the python 580 is the same as the viper 5301. This guy has been doing installs for 7 years and this took about 4 hours to compelete start to finish, we spent a little bit of time shooting the shit but just saying even for a professional, installed, this is no quick job.
    http://www.the12volt.com/installbay/forum_posts.asp~TID~130004~PN~1
    Vehicle: 2010 Toyota Tacoma Automatic
    Starter: Python 580
    Bypass: Key-Override-All (Fortin)
    Disassembly:
    - Remove Door sill panel and driver kick panel
    - Pop off small plastic "door" on right side of knee bolster and remove (2) 10mm bolts on either side of bolster
    - Remove (3) 10mm bolts on metal support bracket. Lift up and out to remove bracket.
    - Remove (2) Phillips head screws behind steering wheel and remove lower steering column plastic.
    Installation:
    - Main ignition harness at ignition switch
    - Parking lights (-) at light switch
    - Brake switch and horn at front of fuse panel
    - Door locks found in Driver Kick panel coming from driver door.
    - Keysense at ignition switch
    - Data wires found at ignition switch
    No pictured:
    - Tach signal found at OBD connector
    - Hood pin was added for installation.
  2. Jan 3, 2012 at 2:40 PM
    hvac
    hvac Member
    4X4 Tacoma T|X Pro 2011
    Sony 7" HU with Tomtom navigation, remote starter with 2 way security system.
    Very nice post, I hope he soldered all the electrical connections :D....
  3. Jan 3, 2012 at 5:59 PM
    hookedontronics
    Jake
    Glenville, NY
