Putting HID kit in ebay projector headlights?
Discussion in 'Lighting' started by beavis87, Apr 7, 2016.
  1. Apr 7, 2016 at 8:33 PM
    beavis87
    beavis87 [OP] Well-Known Member
    El Paso
    '10 Silver TRD OR
    I saw these and was wondering if anyone bought them and installed a good Amazon HID bulb into it? Seems like the cheapest and most convenient way to do the BHLM mod, and HID retrofit. Just wondering when it says H1 bulbs included for projector beam, I'm assuming they are for H1 halogens? But what about high and low beam? So could you just stick in H4 bi-xenon bulbs in it? I do wonder about the quality of the headlight assembly but at this price might as well see how well they are sealed and reseal them later.
    http://www.ebay.com/itm/2005-2011-T...ash=item464a342fba:g:mDQAAOSwmmxW36d4&vxp=mtr
  2. Apr 8, 2016 at 12:17 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    If it is designed for H1s then it will not take H4s. There will be no high beam if they are actually H1s.
  3. Apr 8, 2016 at 7:46 PM
    snowbrdd
    snowbrdd Well-Known Member
    A pair of good projectors alone start at about $250. There is no way they can sell the housing and the projectors for HIDs for under $200. They're using crappy halogen projectors, and you'll get even worse light sticking HIDs in them. However, they should be relatively simple to mod to use HID projectors. Just buy a kit from TRS.
  4. Apr 11, 2016 at 11:01 AM
    unlewser
    unlewser Well-Known Member
    Tempe, AZ
    $250 for a good set of projectors consumer retail, manufactures get cheaper prices, which makes their price point plausible. I see this as being a step up from HIDs in stock reflector housings. These should have a cutoff which won't blind traffic. Be the guinea pig and test them out.
    12TRDTacoma likes this.
  5. Apr 11, 2016 at 1:12 PM
    gollnerj1
    gollnerj1 New Member
    jeff
    06 tacoma and 92 4runner
    3 in lift and 33s on Tacoma and 4 in lift and 35s on 4runner
    Was just looking at doing the same thing but getting a projector/hid kit from retrofitsource.com that is specific for spec d headlights. Have you looked into this any further?
  6. Apr 14, 2016 at 9:35 PM
    snowbrdd
    Do you know how ridiculous you sound?
    What sounds more plausible, a $250 HID projector set, plus housing materials, plus bulbs, plus assembly for $185, or a $50 halogen projector set plus the rest for $185? It's not even remotely plausible, especially since aftermarket headlight housings do not have the benefit of large volumes. They have very low volumes, and have to make it up with larger margins.
    The cutoff might not blind traffic, but the shape of the output would be less than usable. Plus, even with a cutoff shield, there will be some glare leakage with HIDs in halogen projectors. My brother put HIDs in his Crossfire's stock projectors, it has noticeable glare. Not excessive glare like reflectors, but still noticeable.
    The spec d kit has not yet been updated to the new Mini H1 7.0s, which are significantly improved from the 6.0s. I have a pair of Spec D Mercedes E320 headlights I'm about to retrofit with the 7.0s, still waiting for those which are on backorder. Honestly speaking, if you're not handy enough to make your own custom mount for the projectors, you shouldn't be doing your own retrofit.
  7. Apr 14, 2016 at 10:03 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
  8. Apr 16, 2016 at 1:55 PM
    CaptainMorgan
    CaptainMorgan Custom headlight retrofits
    Mesa, Arizona
    2014 White Tacoma TRD Sport
    17 inch Black Rhino Rockwell Wheels, BFG 275/70/17 Ko2 Tires, 3 Inch Rough Country Front lift 2 inch Rough Country Rear Lift
    Typically prefabbed headlights like that use halogen bulbs, ive never used them, but im sure your could put an HID bulb in it and get the necessary conversion plug to run them without doing an actual retrofit (again ive never put HIDS in a halogen wiring harness so im not 100% sure on that, im just going based off of what I have seen other folks do) it will probably work well enough and will be a definite step up from HIDs in your stock housing. Obviously the plan you have wouldn't be as good as a full HID retrofit, but if you're looking to save money, then you can give it a try. Let us know how it goes!
  9. Apr 20, 2016 at 9:24 AM
    07TacoRidah
    07TacoRidah SHHHH, this is interesting
    2007 Base Model Access Cab
    Engine bay: aFe Pro Dry filter Secondary air filter deleted Sokie Tech hood damper kit OReiley battery terminals Big 3 upgrade (0g wiring) 2012 Headlight swap HID kit (headlight 6k/fog light 3k) Sylvania Zevo LED turn signals w/hyper flash resistors Rear back up light GY6 bulb Bullz Audio 0g wire Exterior: Dynamik Retro Projector style headlight housing Depo Euro Black Altezza LED tails 2012 front grill/bumper cover w/ fog light and hood swap Rear bumper swap (to chrome, painted w/bedliner paint) 99 Cents Store tailgate lock Suspension: XR Bilsteins Universal Air Suspension strut bag Custom UCA's DJM 4" rear drop kit 1" spindle spacer kit 4x4 leaf pack swap (middle leaf removed) Air Lift rear helper springs 4 Siria (Asco) 3/8" air valves 3 gallon air tank 1/4' air lines 90's Acura Integra door switches to air valves ViAir 450 air compressor Rims: 18x10 Work VS-KF front w/5" lip 18x11 Work VS-KF rear w/6" lip 225/40/18 tires all around Sick Speed 3 piece spike lug nuts Pepboys valve stem caps 1" wheel spacers all around Interior: Wink Mirror rear view Center console lid fabric Metra Dash kit Kenwood bluetooth headunit Hifonics Zeus ZXi 6410 PB 6 1/2" component speakers up front 10" single Hifonics subwoofer 10" sealed angled box Katana shift knob
    so I bought these ... not bad ... so far. I haven't tried to put in HIDs yet, although I am do want to. The Highbeam sucks imo. They look cool though :D :(
  10. Apr 20, 2016 at 9:29 AM
    Chris24
    Chris24 Well-Known Member
    Greensboro, NC
    09 Black DCSB TRD Sport, V6, 6sp
    HIDs aren't going anywhere anytime soon.
    TacomaArto likes this.
  11. Apr 20, 2016 at 10:44 AM
    unlewser
    Tempe, AZ
    please take a pic of the cut off of the lights. and pics in general.
    :worthless:
  12. Apr 23, 2016 at 8:25 PM
    07TacoRidah
    what do you mean by the cut off. I think I have to realign them cause they look like they are pointing downward too much. Also on my driverside it looks lower cause there is this odd "step" shape within the light beam. I was fiddling with the plugs today making sure the wires weren't stretched too much, the plug prongs are flimsy. Top mounting areas feel like they will break, well one side does. As for the rest... eh I'm giving it a couple till the major headaches come in.
  13. Apr 23, 2016 at 8:35 PM
    07TacoRidah
    found this for the HID's ... not really sure if this will work but ...
    http://store.ijdmtoy.com/HID-Conversion-Kit-Relay-Harness-Installation-DIY-Guide-a/184.htm
    Searched around this site and found these to replace the POS ones that came with the lenses.
    https://www.theretrofitsource.com/morimoto-xb35-h1-bulbs.html?preselect=50558#.Vxw-1_mDFBd
    ... have to do more research, but I mean ... I can probably hack up my old HID's if I need to so I can install new H1's (for testing or what have you).
  14. Apr 23, 2016 at 8:45 PM
    07TacoRidah
    all else, I'm gonna just get some HID's and then plug em in ... like so ... :headbang::headbang::headbang::headbang:
  15. Apr 24, 2016 at 2:12 PM
    07TacoRidah
  16. Apr 24, 2016 at 9:27 PM
    snowbrdd
    /facepalm
    We've already told you how to do it right the first time. If you want to go down this hack path, go ahead, but I guarantee you you are not going to get good results. You will either 1. get poor lighting, or 2. blind every driver out there on the road. If you go with 2, I hope bad things happen to your truck.
  17. Apr 24, 2016 at 9:35 PM
    DukesTaco
    DukesTaco Well-Known Member
    AZ
    2nd Gen Double cab Pre Runner
    Dam wish him hemorrhoids wish him herpes or erectile dysfunction but man leave his Tacoma alone. The Tacoma is the victim here.
  18. Apr 24, 2016 at 10:23 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Or Lou Gehrig's disease. Don't forget about Lou Gehrig's disease.
  19. Apr 24, 2016 at 11:18 PM
    DukesTaco
    AZ
    Just leave the Taco alone. Walk away from the Taco slowly and everything will be OK.
  20. Apr 24, 2016 at 11:28 PM
    RexsTaco
    RexsTaco Well-Known Member
    Vincent
    San Antonio
    Maxtrac spindles Bilstein 5100 adjustable OME 885 coil JBA UCA's Custom leaf pack and Maxtrac extended shocks in the rear. 35x12.5 Atturo Trail blade M/T Moto Metal 18x12 -44 offset wheels.
    Show us how these headlights look turned on
    :worthless:
