Putco LED Nite Lux Headlight Bulbs and Sylvania Dome Lights installed! Update: Putco LED Fogs too!
Discussion in 'Lighting' started by xjoey dubsx, Oct 23, 2015.
  1. Oct 23, 2015 at 8:34 PM
    xjoey dubsx
    xjoey dubsx [OP] Curb Crawler
    Joe
    Cleveland, Ohio
    2015 Taco TRD Sport 6" Coil Overed
    6" PC Coil Over Lift, 35s, 18s, Extang Bed Lights, Garage Door Opener Hack, Bullydog GT Tuner, BHLM, 8300 Tinted everything else, Raptor Lights, Bakflip G2
    Picked these up from work on Tuesday...
    Nice set up, the carbon fiber fins keep the cooling better for dust/dirt I guess. Makes sense since their other LED lights have a fan built into them.
    Before the install (Forgot to turn off fog lights.. :/ )
    Driverside LEDs installed.. Comparing the two...
    Both installed..
    I definitely notice the difference driving, clearer and the reflections off signs are rediculous. Plan in getting their LED Fog lights soon so they match up in clearity, plus you can clearly see the difference visually when you look at them from in front of the vehicle.
    Also, today while picking up the wife wiper blades, picked up some Sylvania LED lights for the dome lights from Advance Auto. A whopping $24.
    Stock:
    #selfie
    LED in right side vs. stock in left side.
    Happier me when they were done!
  2. Oct 23, 2015 at 8:45 PM
    amack8024
    amack8024 Active Member
    Vermont
    2012 T/X Baja
    nice clean looking light. i would think about doing this if i didnt just replace both head lights. does anyone have experience driving against LEDs in traffic? are they painfully brighter to oncoming cars?
  3. Oct 24, 2015 at 8:34 PM
    Ruggybuggy
    Ruggybuggy Well-Known Member
    NW ONT, CANADA
    2020 Tundra SX
    How did you install the rubber boot back onto the headlight assembly?
  4. Oct 24, 2015 at 9:01 PM
    kitsym
    kitsym Well-Known Member
    Portland, OR
    2015 4x4 MGM DCSB TRD Sport
    Nice.
    Curious. How much did the headlight bulbs run you (if you don't mind me asking)?
  5. Oct 24, 2015 at 9:09 PM
    xjoey dubsx
    Joe
    Cleveland, Ohio
    Perks of the job. :) I believe we sell them for $170ish at 4 Wheel Parts.
  6. Oct 24, 2015 at 9:56 PM
    kitsym
    Portland, OR
    Not bad, but they are a bit pricey for bulbs.
    I bet the discount makes them more appealing. ;)
  7. Oct 24, 2015 at 10:03 PM
    xjoey dubsx
    Joe
    Cleveland, Ohio
    We sell quite a bit of them. Best thing about being in the industry is seeing customers reviews and installed items in our shop.
  8. Oct 25, 2015 at 6:24 AM
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    Did you reinstall the rubber boot? Inquiring minds would like to know.
  9. Oct 25, 2015 at 6:28 AM
    Phototaker
    Phototaker Well-Known Member
    Karl
    2015 Tacoma TRD LB
    I popped in new LED lights (Dome/map) and I like the cool temp blue color and low amp draw when out doing night photography..
  10. Oct 25, 2015 at 7:35 PM
    xjoey dubsx
    Joe
    Cleveland, Ohio
    I did not.. Was worried about that...
    Did you reinstall boot?
  11. Oct 25, 2015 at 7:37 PM
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    Without the boot on aren't you worried water and dust will get into the headlight housing?
    TacoMEDIC likes this.
  12. Oct 25, 2015 at 7:51 PM
    xjoey dubsx
    Joe
    Cleveland, Ohio
    Theoretically the bulb's seal to the housing should seal it.. We'll see. Rained last night and didn't have an issue.
  13. Oct 25, 2015 at 7:54 PM
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    I frequently wash under my hood and won't want to run without the boot. Do the bulbs come apart (front or back) or maybe you could stretch the rubber over the back.
  14. Oct 25, 2015 at 7:57 PM
    xjoey dubsx
    Joe
    Cleveland, Ohio
    I can try to stretch it or cut a small slit. I saved it for that reason.
  15. Oct 25, 2015 at 8:00 PM
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    A little WD40 and warm it with a hair dry I better you could work it over. Prestretch it before you start. Let me know because I'm considering the bulbs.
  16. Oct 26, 2015 at 7:08 AM
    xjoey dubsx
    Joe
    Cleveland, Ohio
    When I originally tried it, I almost started to spread the heat sink so I nixed that right away.
  17. Nov 7, 2015 at 9:09 PM
    xjoey dubsx
    Joe
    Cleveland, Ohio
    Got my LED Foglights in the other day, never got around to posting it, so here we are..
    Fog lights:
    OEM Fogs on with LED Headlights:
    One LED Fog vs. OEM Fog:
    All LED Fogs:
  18. Nov 12, 2015 at 8:22 AM
    TuffRuffDangerous
    TuffRuffDangerous Well-Known Member
    San Diego, CA
    2011 TRD Off Road 4x4 DCSB
    Salex glovebox/console organizers, Philips H4 MotoVision headlight bulbs, Optilux H10 Extreme Yellow XY foglight bulbs, csjumper2003 LED domelight & license plate bulbs
    The halogens looks better. No stray light at all. The headlight LEDs don't look too bad but the fogs look like crap. I saw a thread talking about shrouds for LEDs, perhaps something for the fogs would help. Or maybe the camera is capturing what can't be seen with the naked eye.
    The interior LEDs however, can't go wrong with those. And those 194s look short enough to fit in the license plate light housing, so you might want to buy another pair if you haven't done so already.
  19. Dec 3, 2015 at 5:56 PM
    xjoey dubsx
    Joe
    Cleveland, Ohio
    Well had a ton of moisture in headlights last few days. Took lights out and drying them now. Realized how open housing is and why it was so wet inside. Didn't have an issue til the last week or two. Had to cut a small slit in boots but stretched around the led and taped around inside to seal slit I cut. Hopefully that resolves this issue.
