Put on k&n air intake... Now LOUD!!!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by bryman1645, Nov 21, 2012.
  1. Nov 21, 2012 at 9:17 AM
    bryman1645
    bryman1645 [OP] Active Member
    Tucson, Arizona
    99 4x4 SR5 TRD
    I put on a k&n intake about a year ago thinking it would be pretty cool and better for my truck.... I have the 3.4 v6... But it has really made the inside of my cab extremely loud when I drive on the freeway! And my gas mileage really didn't get any better at all ( which i heard it would). I'm just wondering, is this something that is a normal occurence? Is there anyway I can minimize the noise I hear inside my cab?
    Thanks for your help! :)
  2. Nov 21, 2012 at 9:24 AM
    Dcpsychobilly
    Dcpsychobilly Well-Known Member
    Aurora Colorado
    04 dbl cab Taco
    Bumpers, skids, lights and more lights, trail gear bumper, sliders, front kings, dakar lift leaf springs rear, corbeau seats
    It being loud is normal, but are you saying it got even louder? I doubt you can do anything to quiet it, maybe send it to me?:D
  3. Nov 21, 2012 at 9:32 AM
    Amo-cat3
    Amo-cat3 Wizard Sleeve Master
    Maui, Hawaii
    07 TRD Blown dubcab
    TRD Supercharged 4.0 w/ 2.5" Quick change Pulley, UCON EMS, URD 7th injector, AFE Stage II intake, DT Longtubes, MBRP 2.5" dual exhaust w/ Vibrant Ultra resonator, URD Y-pipe w/ vibrant v-bands (Cat free), Walboro 255 fuel pump, SS Oil catch can, Aeroforce gauges, Icon CDC 2.5 coilover set at 3", 1.5" Wleelers Progressive aal, Light racing uca, 17x8.5 Fuel Anza 4.5" backspace/-6 mm offset, Kelly Safari a/t 265/70/17, scanguage 2, AMP electric steps, bed extender, Low-pro tonneau cover, 20% tinted windows/headlights/taillights, tacoma seat covers, Image dynamic sound system w/ Pinoneer avh3200 head, assrtd stickers................
    Put on some headers to counterbalance the noise :D
  4. Nov 21, 2012 at 9:44 AM
    Dcpsychobilly
    Aurora Colorado
    04 dbl cab Taco
    with no exhaust pipes after them:D
  5. Nov 21, 2012 at 9:50 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    They make wraps for them but I doubt they would quiet it down enough to say so. If it's too loud, go back to stock. You didn't gain anything with the K&N anyways, you might have even LOST some power.
  6. Nov 21, 2012 at 9:56 AM
    Dcpsychobilly
    Aurora Colorado
    04 dbl cab Taco
    You mean a pre filter, I thought about telling him that but it probably wont do anything, just keep the filter cleaner. Ive seen foam pre filters but Im not sure where to get those, that might make difference
  7. Nov 21, 2012 at 10:04 AM
    Pugga
    Massachusetts
    No, I wasn't talking about a pre-filter. I'm talking about the sock that goes over the tubing itself. It's meant to slow heat soak but might help deaden the sound a tiny tiny bit.
    Another option, sound deaden the cab.
  8. Nov 22, 2012 at 9:28 AM
    Gooch
    Gooch Well-Known Member
    Orange County CA
    2000 Tacoma SR5 V6 4x4
    Mileage shouldn't change. The computer maintains the perfect air/fuel mixture regardless of resistance in the filter.
    I and several other Tacoma owners have switched back to the stock filter from the K&N or TRD washables because they don't filter as well and dirty up the MAF sensor, causing symptoms like loss of power, bad mileage, rough idling, stalling and CEL. It will take a while though and it is easily remedied by cleaning the MAF sensor with MAF sensor cleaner.
    After the second time I had to do it, though, I went back to the stock paper filter. It happened really quickly the second time as I was off-roading on roads that produced extremely fine dust.
    There are guys that swear by the K&N's and TRD filters but IMHO they are extremely overrated. I also think that if they are dirtying up the MAF sensor, they might also be causing other components to be exposed to more dirt than the paper filter.
  9. Nov 22, 2012 at 9:34 AM
    Gooch
    Orange County CA
    BTW the code I got both times my MAF sensor got dirty was P0171.
  10. Nov 23, 2012 at 10:04 PM
    bryman1645
    Tucson, Arizona
    99 4x4 SR5 TRD
    Thanks for all of your guys' help :)
  11. Nov 23, 2012 at 10:53 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Ditto.
    Lost power, and lost a LOT of filtering quality.
    May as well not even have a filter on there.
  12. Nov 24, 2012 at 8:28 AM
    extremepaint
    extremepaint Well-Known Member
    denver
    04 with stuff
    Agreed with all other posts. I noticed a gain of 1-2 mpg when i went back to stock also i would much prefer the filtering ability of the stock intake vs the k&n. But i also prefer a snorkel over that. I have a tendancy to fet stupid with my truck so having a back up insurance plan is all the better.... especially when i already locked up one motor with two broken connecting rods a cracked block and crankshaft girdle....
