Put new window motor in and still has doesn't work
Discussion in '1st Gen. Tacomas (1995-2004)' started by Troyd, Jun 9, 2012.
  1. Jun 9, 2012 at 6:22 PM
    Troyd
    Troyd [OP] Well-Known Member
    PA
    04 TRD Off Road 5 speed
    stock for now
    Today my passanger side window wouldn't go up from my driver side switch or from the pass side switch. I took the door all apparent and replaced the motor. Still doesn't move the window. My wires look good. Could it be a bad switch ? If so wouldn't it still work from my driver side switch. There calling for rain and my windows stuck down and doors all apart. Help needed ....
  2. Jun 9, 2012 at 9:56 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Bad relay for the passenger window?
    Isn't that truck under warranty? Its only a year old.
  3. Jun 9, 2012 at 10:35 PM
    ProForce
    ProForce IG @proforce.expeditions OB#5411
    Anthony
    Alaska
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    Check wires/harness for driver side switch. When driver side switch is unplugged or if a single wire is damaged, the corresponding window AND individual switch will not work (if that makes sense)
    Check relays and fuses. Don't believe each window has its own but worth a 2 minute check anyways.
    You need to start eliminating options. First if you have a multi meter, start at the passenger window motor and check for power. If power and ground is good, then its the motor. If no power AND/OR ground is present, move back to the passenger switch. Test again. If still no power/ground, check driver side. If it has power/ground, then the problem is the switch. If it didn't and your checking the driver side, be sure to check power/ground for ALL four window individually. If has no power and you checked all relays and fuses, then I'm stumped.
    In order to check a switch, you must check for power and ground when the switch is at rest, AND check with the switch in the up AND down position. Hopefully you have some knowledge of electrical or this could get very difficult to explain.
    My bets are on a lose wire or broken/corroded switch. Good luck!
    Brie likes this.
  4. Jun 10, 2012 at 5:17 AM
    Troyd
    PA
    stock for now
    I traded my 11 in on an 04 on thursday and this happens with no warranty what so ever. Thanks for the advice. I just checked my old motor , and it turns still both ways when I touch it to my battery depending on which one lead I put to positive and negative. I guess my motor is still good. I just checked my switch to see if it was getting power to the plug where the motor is plugged into. When the switch isn't be pressed it reads zero on the volt meter, when the button is pressed up or down the volts jump all over the place , never really consistent. Any ideas ?
  5. Jun 10, 2012 at 5:19 AM
    Troyd
    PA
    stock for now
    How do I check my relays?
    Brie likes this.
  6. Jun 10, 2012 at 6:14 AM
    rushr
    rushr Well-Known Member
    04 DC TRD 4X4
    OME 883 Coils, Dakar Leaf Packs/D6XL AAL, Nitrocharger Sport Shocks, ARB Bumper, Warn M8000 w/Synthetic Line, BAMF Sliders, Odyssey Battery, ProComp 7069 15x8, BFG KM2 33x10.5x15, Frame End Cap Mod, Hayden Transmission Cooler
    Since neither switch works to operate the passenger window check the window lock switch first.
  7. Jun 11, 2012 at 2:31 AM
    ProForce
    Anthony
    Alaska
    Just switch it with a like relay know to work. Use one that isn't important such as fog light relay etc. If window now works and fogs don't, then you have an answer. That is easier then applying voltage/ground to pin 85/86 and testing continuity from 30-87 and 30-87a
    Brie likes this.
  8. Jun 11, 2012 at 6:09 AM
    BamaToy1997
    Bill
    Navarre, FL
    NOTICE: My suggestions posted here are based on over 20 years as an ASE certified Master Automotive Technician. I am stating here that if you use my suggestions, I am not to be held responsible for anything that may break or become damaged. Always check your own work, and look up information.
    OK, I am going to assume that since you are only complaining of a pass window problem, that the other window(s) work fine. If that is the case, then your fuse and power relay work just fine. So with that eliminated, lets look a little deeper:
    According to the wiring schematics, and your description, I would believe the fault to be in the driver's window switch. If you attempt to operate the window up from the passenger's door, it applies power from terminal 2 to terminal 1 at the passenger's switch. because terminal 3 is normally connected to ground through terminal 5, which is grounded thru the driver's window switch, normal up-operation should occur. Since this does NOT happen, I suspect that there is an internal problem in the drivers switch. The way to properly test this is as follows:
    Step 1: disconnect all connectors from driver's window switch.
    Step 2: connect a jumper from terminal 6 to terminal 3 of the driver's switch connector (this applies a ground to the passenger's window motor for "up" mode)
    Step 3: operate the passenger's switch to the "up" position. The window should go up. WARNING! DO NOT PRESS "WINDOW DOWN" WHILE THE JUMPER IS BETWEEN TERMINALS 6 AND 3!!! This will short the window power circuit to ground, resulting in at minimum a blown fuse.
    If you complete these steps and the window still does not go up:
    Remove jumper, reconnect driver's window switch. Disconnect passenger's window switch and check for ground on terminals 5 and 2. If the above attempt resulted in a no-go condition, I would look to see no ground on terminal 2. If there is no ground on terminal 2, check for a loose connection at terminal 6 of the driver's switch connector, or a open wire between the driver's switch connector terminal 6, and passenger's switch connector terminal 2.
    Driver's switch connector information:
    Terminal 3: white/black wire
    Terminal 6: red/green wire
    Terminal 14: red/black wire
    Passenger's switch connector information:
    Terminal 1: green wire
    Terminal 2: red/green wire
    Terminal 3: blue/orange wire
    Terminal 4: blue/red wire
    Terminal 5: red/black wire
    Brie likes this.
  9. Jun 11, 2012 at 6:17 AM
    BamaToy1997
    Bill
    Navarre, FL
    Depending on application, this could be a possibility. If the truck only has 2 doors. If it is a 4-door truck, and the other windows work correctly, then it can't be the lock switch.
    Brie likes this.
  10. Jun 11, 2012 at 6:34 AM
    JSFoster75
    JSFoster75 Well-Known Member
    Scott
    Bluff City, TN
    2018 Wrangler JLU Sahara
    Too many to list.
    His truck is a double cab which means it has 4 windows, unless all his passenger windows aren't working, then it isn't the lock switch...
    It should be under warranty since it's a 2011...
  11. Jun 11, 2012 at 8:55 AM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    :smack:
    Brie likes this.
  12. Jun 11, 2012 at 10:21 AM
    BamaToy1997
    Bill
    Navarre, FL
    I think that is exactly what I just said..... lol
    Since he traded it in I have no idea if his new truck is a 2 or 4 door model. hence the post.
  13. Jun 11, 2012 at 11:26 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    ^^^ This!
    The lock button is easy to accidentally lock. It is located on the driver side door window controls.
  14. Jun 11, 2012 at 12:27 PM
    JSFoster75
    Scott
    Bluff City, TN
    Too many to list.
    I wasn't aware he had traded his truck and was re-affirming what you said about the window lock... :)
  15. Jun 12, 2012 at 12:24 AM
    ProForce
    Anthony
    Alaska
    ^^ This! Great info. Exactly what I was trying to say about the switches. Most people don't get that if the the driver side switch is damaged then the other switch will not work either. They need each other in order to function.
    Brie likes this.
  16. Jun 13, 2012 at 6:24 AM
    BamaToy1997
    Bill
    Navarre, FL
    Just a note to the OP.... Did you get things fixed? Kinda curious how things turned out. Don't leave us hangin bro! lol
    Brie likes this.
  17. Jan 30, 2014 at 8:22 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    This is kind of a old thread but it's the only one i can find with info on my issue.
    My passenger window went out and I've been fighting it for a while now. The motor has been changed the passenger window switch and I switched out the driver switch assembly with another 1st Gen to see if it worked and nothing! I'm stumped on it so I figured I'd post up in here to see if you guys have an any insight mainly you Bill :)
    Driver side switch for the passenger window does nothing and the passenger switch will roll it up but not down.
    Brie likes this.
  18. Sep 20, 2016 at 10:28 PM
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    There are window fuses inside. And one in the engine compartment. For me, the RR won't roll up-down, yes.
    Hoping it's simple enough-like the motor.
    Brie likes this.
  19. Aug 10, 2017 at 5:01 AM
    Brie
    Brie Well-Known Member
    Brieanna
    CA
    2001 Tacoma TRD, Prerunner
    There's a window fuse in the engine compartment?
  20. Aug 10, 2017 at 1:14 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Sounds like a possible broken wire. There is a blue wire, blue/red and blue/white wire the sends power from switch to door lock relay. The blue and red should have power all the time.
    Brie likes this.
