Push start problem
Discussion in '3rd Gen. Tacomas (2016-2023)' started by kjttaco, Mar 17, 2022.
  1. Mar 17, 2022 at 8:02 PM
    kjttaco
    kjttaco [OP] Well-Known Member
    Ken
    NJ
    2020 Black Limited
    Tonight I used remote start on my 2020 limited via the key fob. When I opened the door the truck remained running. I pushed the truck start button and the truck shut off.I then tried to restart it but it would not start after multiple tries and 15 minutes later it started. Has this happened to anyone else?
    Any thought are appreciated!
  2. Mar 17, 2022 at 8:25 PM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    There have been a few posts of this happening. It's like the system temporarily gets locked into autostart mode and won't do anything else until it self resets. If it continues to do it though, a trip to the dealer may be in order.
  3. Mar 17, 2022 at 9:20 PM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    Just put the key in.
    Oh... no key.
    Give me a key or give me death.
  4. Mar 18, 2022 at 6:39 AM
    dan33410
    dan33410 Well-Known Member
    2020 Quicksand TRD Off Road
    Has happened to me on my 2020 as well. Truck remote started, I unlocked the vehicle by grabbing the driver's side door handle with the engine still running, door unlocked but the truck kept running. I tried to shift to reverse, engine shut off and push button start wouldn't work. I waited about 10 minutes, at which point the engine would start without issue.
    A possible work around is to just unlock via the fob, it's only happened to me while using the door handle to unlock.
    I haven't asked the dealer to look at it, because it's one of those issues that they won't be able to replicate. My research on here pointed to either a weak signal from the touch sensor in the door handle or possible interference in the signal caused by aftermarket LED lighting in the cabin? No idea if either of those are true.
  5. Mar 18, 2022 at 6:49 AM
    VictorFox78
    VictorFox78 Well-Known Member
    Michigan [Yooper]
    2022 DCSB LR OR
    :rofl::rofl::rofl:
  6. Mar 18, 2022 at 6:52 AM
    Grindstone
    Grindstone Requires Adult Supervision
    I had this happen a few months ago. My battery died in the cold a few days later. Replaced battery, this hasn't happened since.
  7. Mar 18, 2022 at 8:25 AM
    PhogDog
    PhogDog Well-Known Member
    20 MGM Sport
    Happened a couple of times on my 2020, so now I just unlock with fob first...have not had the issue since I started doing it that way.
  8. Mar 18, 2022 at 8:26 AM
    ryanvar42
    ryanvar42 Well-Known Member
    2024 Silverado Trailboss
    None
  9. Mar 18, 2022 at 8:34 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Not to be 'that guy' but I agree
  10. Mar 26, 2022 at 11:59 AM
    kjttaco
    Ken
    NJ
    2020 Black Limited
    Happened again today. Went to start the truck iwth push start, rapid clicking noise after releasing push button and the headlights were rapidly flashing. Disconnected the battery and waited an hour to reconnect, the same noise and light flashing occured.
    disconnected battery again and reconnected with a jumper battery attached. The truck started up. Shut the truck off and removed jumper battery and the truck starts normally.....crazy!!!
  11. Mar 26, 2022 at 3:27 PM
    513Mugsy
    513Mugsy Well-Known Member
    Cincy
    2020 VOODOO AC OR MT sold now
    Replace the battery. First thing to do when the electrical weirdness starts. Stock batteries suck!
  12. Mar 26, 2022 at 4:47 PM
    kjttaco
    Ken
    NJ
    2020 Black Limited
    Update.... Now the display above the steering wheel does not turn off..I have disconnected the battery to turn it off...will investigate more tomorrow
  13. Mar 26, 2022 at 5:52 PM
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    Is the truck stock?
    Chew likes this.
  14. Mar 26, 2022 at 7:29 PM
    kjttaco
    Ken
    NJ
    2020 Black Limited
    Pure stock no mods at all, not even a bulb change!!
  15. Mar 26, 2022 at 7:41 PM
    513Mugsy
    Cincy
    Mice?
    SR-71A likes this.
  16. Mar 28, 2022 at 6:06 PM
    kjttaco
    Ken
    NJ
    2020 Black Limited
    No mice! But thanks for suggestion.
  17. Apr 5, 2022 at 6:50 PM
    kjttaco
    Ken
    NJ
    2020 Black Limited
    Flatbed to dealer tonight ..same problem...no start
    My4thTacoma likes this.
  18. Jun 18, 2022 at 6:26 PM
    Lava-road
    Lava-road Well-Known Member
    2019 trd-off road
    Hard top camper...many more to add+
    The 2020 Tacoma does have a remote start. System is call the “Toyota Remote Connect”, $8.00 a month or $80.00 a year.
    Includes remotely lock/unlock
    Performs a vehicle status check
    Gives update on driving information when a “guest” is driving you vehicle
    Finds where you park your Tacoma, a vehicle finder.
    Sounds like the system does not work very good.? Or there is some issues still on going?
  19. Jun 20, 2022 at 11:30 AM
    shiftd
    shiftd Well-Known Member
    Pennsylvania, USA
    2020 Tacoma TRD Pro
    I've experienced this same thing with my 2020 TRD Pro.
    It has happened to me 3 times in total (so far). The first time was just over a year of ownership.
    Scenario is the same each time. Use the keyfob to remote start but when you approach the vehicle to get in the engine continues to run. Push to start button kills the engine but subsequently the push to start will only power on accessories, it doesn't start the engine.
    First time I attempted to start about 10 times over a 15-20 minute period. After around 20 minutes it started. This puzzled me for a while.
    Second time I decided to experiment and pulled the fuse for the DCM under the hood on the assumption that it had to do with the remote connected services. I never paid for, used, wanted or downloaded the app for any of the remote services but figured that the truck might be attempting to phone home. Replaced the fuse and it started up the next attempt. Did the same thing on the third time that I experienced the strange remote start.
    A few days after this happened to me the 2nd time I experimented by removing the DCM fuse (keeping it removed) and attempting to remote start with the keyfob. While doing this I was unsuccessful in getting the vehicle to remote start at all. I could lock and unlock the doors but not get it started with the fob.
    The truck has not behaved like this for a few months and I have not done any further testing to prove its connection to remote services, but I saw this thread today and having experienced the same thing figured I'd contribute.
    Kev250R, SR-71A and xxTacocaTxx like this.
  20. Jun 20, 2022 at 11:53 AM
    gsubioguy
    gsubioguy Well-Known Member
    Evan
    Maine
    '21 TRD OR
    Wonder if this has any connection to the recall concerning trying to restart inside a short window after shutting off the trucks? Seems like a long time from OP's initial post to a recall but idk!
