Push Button Start Malfunction
Discussion in '3rd Gen. Tacomas (2016-2023)' started by LTacoman, Feb 10, 2020.
  1. Feb 10, 2020 at 3:08 PM
    LTacoman
    LTacoman [OP] Well-Known Member
    Luis
    Gilbert, Az
    2019 F150 Lariat EB
    Lately I've noticed that my Push Button Start/Stop button seems to be malfunctioning. I will shut off the truck using the button, engine will stop, but ignition will still be on. When I began to notice it I thought maybe I just didn't push the button correctly, but now it is becoming a more common occurrence.
    This only happens when shutting the truck off, not on startup.
    Anyone else notice this?
  2. Feb 10, 2020 at 3:16 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    maybe you are holding the button down too long when turning it off?
  3. Feb 10, 2020 at 3:19 PM
    LTacoman
    Luis
    Gilbert, Az
    2019 F150 Lariat EB
    I tested that theory as well, but that doesn't seem to be the case. I also thought I was pressing too quickly, but that doesn't seem to be the case either...
  4. Feb 10, 2020 at 3:22 PM
    kahanabob
    Maui
    16 TRD 2WD 4DR
    so if your radio is on and you turn the engine off the radio stays on? how do you eventually get the ignition turned off?
  5. Feb 10, 2020 at 3:26 PM
    tcjacado
    tcjacado Well-Known Member
    Sounds like it's in accessory mode in the ignition. Try pressing it twice:notsure:.
    I have a actual key for mine... so just throwing stuff into the fan.
    Superdave1.0 likes this.
  6. Feb 10, 2020 at 3:29 PM
    LTacoman
    Luis
    Gilbert, Az
    2019 F150 Lariat EB
    the radio shuts off for a second then cycles back on, that's how I initially noticed that it was happening. To eventually turn it off I just have to push it again until it actually shuts off completely.
  7. Feb 10, 2020 at 3:30 PM
    the_dau
    the_dau Well-Known Member
    Vancouver BC
    2017 Inferno TRD OR DCSB
    sounds like there's a bad contact in the button that's re-engaging after you press it the first time
    DSRamsey13, over60 and Superdave1.0 like this.
  8. Feb 10, 2020 at 3:30 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
  9. Feb 10, 2020 at 3:31 PM
    tcjacado
    :rofl:
  10. Feb 10, 2020 at 3:31 PM
    tacomarin
    tacomarin ig: @travelswithchubbs
    Bay Area
    2018 DCLB TRD OR
    Prinsu Cab and Top Rack VO Drifter LED Interior, License Plate, and Reverse Lights Huskyliner Weather Beater floor mats Salex Center Console Organizers 35% Front/15% Rear Tint Debadged and De-stickered Anytime Front and Rear Cameras Brute force front bumper BAMF HC Dual swing out 285/75r17 BFG KO2 Front: ADS 2.5, EXT, RR, Clickers Rear: OME Dakar HD, ADS 2.5, EXT, RR, Clickers Stainless steel brake lines (+4 in rear) Wheeler's Offroad Superbumps Front and Rear Wheeler's Offroad U-bolt flip ECGS CV Axle Bushing SCS Stealth 6 17x8.5 wheels, matte dark bronze
    You sure you put it in park?
  11. Feb 10, 2020 at 3:36 PM
    Superdave1.0
    SoCal
    If you know another tacoma owner near you, maybe you can swap the switch out. Installing a known good switch is what I would try. GL.
    huskcummerbund and LTacoman[OP] like this.
  12. Feb 10, 2020 at 3:36 PM
    LTacoman
    Luis
    Gilbert, Az
    2019 F150 Lariat EB
    that's what my thought is, figured I'd ask here to see if anyone else experienced something similar
    positive, although if I am being honest I have left it in D on more than one occasion when i'm in a hurry.. :tinfoilhat:
  13. Feb 10, 2020 at 3:39 PM
    CaptainTikihut
    CaptainTikihut Well-Known Member
    NorCal
    2017 Taco Supreme w Stuff
    Interesting...curious if your foot was on the brake when you pushed the button to shut off the engine? I've never encountered that problem and my foot has always been off the brake when I kill the engine. Just throwing it out there.
  14. Feb 10, 2020 at 3:40 PM
    LTacoman
    Luis
    Gilbert, Az
    2019 F150 Lariat EB
    I think my next move will be to buy the switch and swap it out and hope for the best, don't want to go fooling with another taco owner's electronics...
    very strange that i'm the only one experiencing this though right?o_O
  15. Feb 10, 2020 at 3:40 PM
    Superdave1.0
    SoCal
    Make sure you can return the switch. Then it will be a free diagnostic attempt.
    LTacoman[QUOTED][OP] likes this.
  16. Feb 10, 2020 at 3:41 PM
    tcjacado
    Don't know.... this didn't show up in every 3rd gen with a push starts mail box.... only a few have seen this thread in the 15 minutes it's been alive.
  17. Feb 10, 2020 at 3:42 PM
    LTacoman
    Luis
    Gilbert, Az
    2019 F150 Lariat EB
    I think I usually have my foot off the brake on shutoff, but I'll definitely test and see what happens.
  18. Feb 10, 2020 at 3:46 PM
    LTacoman
    Luis
    Gilbert, Az
    2019 F150 Lariat EB
    I was more surprised that I didn't find any other threads on the subject (not to write off the possibility that my google-fu game is weak though...)
    even with more rare issues there always seems to be other threads out here
    tcjacado[QUOTED] likes this.
  19. Feb 10, 2020 at 3:49 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Try the voodoo fixer upper.
    Pull the both battery cables (negative first off and last on) and touch both together for about 10sec while disconnected.
    over60 likes this.
  20. Feb 10, 2020 at 7:25 PM
    dman100
    dman100 Well-Known Member
    Central Coast, California
    2016 TRD OR DCSB
    If you shut off in neutral, it stays in accessory mode. If you’re definitely in Park, could it be a faulty neutral start switch? Or, are you shutting off while you move it from Drive to Park and it”s detecting the Off signal when it is (or thinks it’s in) Neutral?
    kahanabob likes this.
