Purge solenoid
Discussion in '1st Gen. Tacomas (1995-2004)' started by Thedoobster, Apr 9, 2022.
  1. Apr 9, 2022 at 11:56 AM
    Thedoobster
    Thedoobster [OP] Well-Known Member
    Brandon
    California
    1999 Tacoma SR5 3.4L 4x4
    3" Lift, 1.5" Wheel Spacers, 285/75r16 Tires
    I have a 3.4l 99 Tacoma the check engine like comes on about every 100 miles for the code p0446. This website has let me to believe the most common cause is the vacuum purge solenoid but my problem is I can't find one to match the serial numbers of the one I have.
    It's 258-75160 and 101362-1520 I've looked these up and it brings me to something that looks exactly like it but with different numbers, I'm hoping someone here can point me in the direction of the correct part.
  2. Apr 9, 2022 at 11:59 AM
    Clearwater Bill
    Billy
    Largo Florida
    Numbers often change the older a vehicle gets. It's called a 'superseded number'. Doesn't mean the part isn't the right one.
    Calling the parts guy at a dealer, give him your current numbers, ask for a price and then ask if there is a new number.
    TACOTU3 likes this.
  3. Apr 9, 2022 at 12:18 PM
    Thedoobster
    Brandon
    California
    Ok that makes sense, thank you
  4. Apr 9, 2022 at 12:21 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    96 thru 01 3.4L V6 Purge Selnoid
    25860 - 75140
    crazytacoman and Kiloyard like this.
  5. Apr 9, 2022 at 3:23 PM
    snaggs
    snaggs Well-Known Member
    Shaun
    Nova scotia , Canada
    2001 tacoma sr5 2.7 4x4
    None
    Clearwater bill is correct, number has superseded. I once bought a part for my 2001 tacoma and number had been superseded 5 times but part was still correct.
  6. Apr 9, 2022 at 6:40 PM
    crazytacoman
    crazytacoman Well-Known Member
    Tacoman
    Taco World
    02 2.7 doublecab & 07 4.0 doublecab
    Color Wheels
    Make sure you get the correct one. Yours should be #1 from the purge valves shown below. #2 is for 2001+ models
    #1 part number 2586075140
    #2 part number 2586075160
  7. Apr 10, 2022 at 10:27 AM
    Kiloyard
    Kiloyard Road Warrior
    Phoenix, AZ
    1999 3.4L SR5 4X4 405K miles
    Toytec Boss/Eibach Coils & Deaver J59's
    This info isn't accurate. I have a '99 V6 as well and mine uses the 25860 - 75160 as shown in the second photo. Toyota parts counter guy can help if you give the VIN.
    crazytacoman[QUOTED] likes this.
  8. Apr 10, 2022 at 11:56 AM
    crazytacoman
    Tacoman
    Taco World
    Color Wheels
    Interesting. I was going off of this post
    When I checked the toyotaparts website I got this:
    I just figured that's how it was for the pre-2001 models. Mines is an 02' and uses the solenoid on the 2nd picture
  9. Apr 10, 2022 at 12:01 PM
    crazytacoman
    Tacoman
    Taco World
    Color Wheels
    ^in any case.. just check which one looks like the one on your truck? :notsure:
    Kiloyard likes this.
  10. May 18, 2023 at 2:42 PM
    mrduran
    mrduran Member
    1999 Pre Runner, RWD Standard Cab, 2.7L 3RZ-FE, A/T
    Full street header, add-a-leaf spring (rear)
    I'm on this project as well. My short answer is that sadly some suppliers are lazy with their information. And the terms referring to parts in the aftermarket are influenced by what people know them as. This is for the sake of making them easier to find. In this case, this is one where the part names and numbers are closely related and communication as to which is which is unclear. I say this because my 99 Taco Prerunner uses both styles pictured above. And no, one doesn't replace the other. That would require adapter hoses which are nowhere to be found as far as I'm seeing, and the only thing I've heard of like that was the 2002 Sequoia front break caliper retrofit which took an angle grinder to get in.
    I'm resorting to narrowing down the parts by number, and verifying the accuracy by picture.
    Thedoobster[OP] likes this.
  11. May 18, 2023 at 2:44 PM
    Thedoobster
    Brandon
    California
    For me the code ended up being my charcoal canister, it was cracked along the bottom. I did a quick epoxy job and it passed smog.
    mrduran likes this.
  12. May 18, 2023 at 2:53 PM
    mrduran
    mrduran Member
    I <3 epoxy.
  13. May 18, 2023 at 2:55 PM
    Thedoobster
    Brandon
    California
    Right right, it really was a life saver lol. I'll get a new charcoal canister eventually but it works for now.
    mrduran[QUOTED] likes this.
  14. May 18, 2023 at 4:08 PM
    mrduran
    mrduran Member
    And that's exactly one of my issues. And for others who might come across this thread, his is a common problem. Cracks along the bottom lower edge. One was hard to see, but another was obvious. I painted the entire bottom boarder with epoxy, he he.
