Pulsating Brake
Discussion in '2nd Gen. Tacomas (2005-2015)' started by yellow_bandit, May 3, 2018.
  1. May 3, 2018 at 3:22 AM
    yellow_bandit
    yellow_bandit [OP] Well-Known Member
    MA
    2013 TRD Sport DCSB
    HS 2" Lift Kit
    Sometimes when braking I get a pulsating feel under the pedal. It's worse at higher speeds but sometimes it doesn't happen at all. Should I replace the drums or would I have to replace the shoes as well? I'm not sure when the rear brakes have been changed. Currently at 60k miles.
  2. May 3, 2018 at 5:04 AM
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    Probably your front rotors, get them serviced.
    Alexely999 likes this.
  3. May 3, 2018 at 5:08 AM
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    It's not ABS or traction control engaging is it?
    Strong pulse or very slight?
    Does it vary by speed at all or always feel the same?
  4. May 3, 2018 at 5:13 AM
    TexasTacoLT
    TexasTacoLT Well-Known Member
    Killeen, TX
    '14 TRD Offroad
    3" Lift (ToyTech Coilovers and AAL) Bilstein 5100 Shocks Total Chaos UCAs Method Double Standard 17" BFG All-Terrain T/A KO2 (Removed) 33" BFG Mud Terrain Tires Colormatched Grill surround HomerTaco mesh grill insert Legacy "Toyota" Emblem Shrockworks plate rear bumper All-Pro plate front bumper w/ foglights All-Pro rock sliders Smoked Tail-lights DIY Steel Tailgate reinforcement Locking Tailgate handle Tint (15%) w/ sunstrip Tyger Tonneau cover (Removed) Bestop Soft Topper Bushwhacker colormatched fender flares DIY 8-ball shift knob DIY Amber LED grill lights DIY Debadged WeatherTech floormats Sudued US Flag door decals T-100 style tailgate decal Two way radio w/ 3' whip antenna Warn 8000lb winch CalTrend Neoprene seat covers DIY Bed tie-down anchors
    Sounds like it may be warped rotors :notsure:
  5. May 3, 2018 at 5:32 AM
    _gray_knight_
    _gray_knight_ Well-Known Member
    SoCal
    '18 Mall Crawler
    Just washed
    Sounds like rotors need to be serviced. Drums should be checked nonetheless, they only give your roughly 20% of your braking power.
  6. May 3, 2018 at 5:41 AM
    yellow_bandit
    MA
    2013 TRD Sport DCSB
    HS 2" Lift Kit
    It's a light pulsating under the pedal but more vibration in the rear. I can feel it in my seat. Varies by speed.
  7. May 3, 2018 at 5:47 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Poor front brake pad wear from excessive braking.
    Change out your front brakes and rotors, seat them properly and then don’t brake so aggressively lol
  8. May 3, 2018 at 5:52 AM
    _gray_knight_
    SoCal
    '18 Mall Crawler
    Just washed
    Just get it checked out to see what could be the cause, might just need to be cleaned out and what not. After that, if it still continues then there's concern.
  9. May 3, 2018 at 5:58 AM
    yellow_bandit
    MA
    2013 TRD Sport DCSB
    HS 2" Lift Kit
    I was thinking about changing pads, rotors, and drums. But I'm not too comofortable with rear drum brakes and changing the shoes may be a challenge for me.
  10. May 3, 2018 at 6:12 AM
    _gray_knight_
    SoCal
    '18 Mall Crawler
    Just washed
    I've done a few jobs in past and can say they are not fun to do at all haha
  11. May 3, 2018 at 6:13 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    MolonLabeTaco, PackCon and Biscuits like this.
  12. May 3, 2018 at 6:26 AM
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    The rear drum brakes are not that difficult to work on. Believe me, if I can do it, you can. There are a number of little pieces and springs that are under tension and can be lost if you’re not careful. Once you get the dust cover off, take a picture of everything to assist you when reassembling everything. I also used the service manual to help me, as well as numerous threads here on TW.
    Whatever you do, buy the right tools for the job:
    OTC Rear Drum Brake Kit
    If you don’t buy anything else, buy this spring plier:
    OTC Brake Spring Plier & Claw
    And last but not least...
    A good pair of mechanic’s gloves and safety glasses. IMHO, the potential of your hands and fingers getting torn up, stabbed, mashed, amputated dissolved in acid working on drum brakes is significantly higher than working on most other aspects of your truck. I have worked on my Tacoma’s drum brakes twice; I did not use the tools listed above in the first instance and I successfully mashed and stabbed my hands. Second go around was much quicker and without pain as I used the rear drum brake kit I listed above.
    techride and MolonLabeTaco like this.
  13. May 3, 2018 at 6:34 AM
    yellow_bandit
    MA
    2013 TRD Sport DCSB
    HS 2" Lift Kit
  14. May 3, 2018 at 6:35 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    I think drum brakes are easy even with a couple of pairs of Pliers and a screwdriver. Of course I grew up when disc brakes didn't exist yet and all four corners had drum brakes.
    Why does everybody use gloves these days to work on the car/truck. I hate those damn things, they just get in my way.
    Alexely999 and Sandman614 like this.
  15. May 3, 2018 at 6:36 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    It should. Worst case, use fine steel wool on the rotors first.
  16. May 3, 2018 at 6:39 AM
    Biscuits
    Also, for what it’s worth, I have significant pulsating at low speeds when coming to a stop. I only have 30k mi on my 2014, so the cause could be from rotor fouling, but should I decide to replace both pads and rotors, my current intention is to use @crashnburn80 ’s recommendation found here. I have found his reasoning to be sound and I honestly don’t think that, for the money, there is a significantly better brake setup than his, unless upgrading the entire front brake system, e.g. StopTech big brake kit.
    crashnburn80 likes this.
  17. May 3, 2018 at 6:43 AM
    Biscuits
    You had better fortune than I did or maybe you’re just more capable. Which is fine. Lol. Regardless, I was infuriated during my first go at servicing the drum brakes.
    I use gloves because they’re mandatory for field duties at work, so I’ve just gotten used to wearing them. There are times that I’ll take the work gloves off, but then I’ll wear nitrile gloves for fine work.
    Good to know. Thank you!
  18. May 3, 2018 at 6:44 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Causes:
    • Unevenly worn tires, typically to bad alignment or other worn parts
    • "warped rotors"
    • Worn tie-rods
    • Worn ball joints
  19. May 3, 2018 at 6:48 AM
    PackCon
    Connor
    You would need to shave both the pad and the rotor in order to reseat.
    You can’t clean the uneven pad material off the rotors. It basically needs to be aggressively buffed off.
    Biscuits likes this.
  20. May 3, 2018 at 7:19 AM
    MolonLabeTaco
    MolonLabeTaco Well-Known Member
    Dude
    N. Texas
    '12 DC 4x4 OR
    If front & rear pads are good then it's uneven pad deposits on the rotors and/or drums (what people think are warped rotors). If that's the case then do an aggressive re-bedding of the pads/shoes & it should fix the issue.
