Pulsating Brake Pedal
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Steve0ct, Oct 3, 2017.
  1. Oct 3, 2017 at 9:25 AM
    Steve0ct
    Steve0ct [OP] Well-Known Member
    CT
    2017 TRD Off-Road DCSB White
    Hello, 2 weeks ago I bought a 2017 TRD Off Road. The truck now has about 1,400 miles on it.
    I've noticed that when I am coming to a stop at a stop sign, light, etc. there is a pulsating in the brake pedal when the truck gets down to about 30 mph. It pulsates until the truck stops.
    Any idea what can be going on?
    Thanks,
  2. Oct 3, 2017 at 9:28 AM
    LivinOnEdge
    LivinOnEdge ¯\_(ツ)_/¯
    Land of The Lost
    Four wheels and a refrigerator
    If your a person who brakes hard, it could be the ABS.
    hoverlover and nudavinci64 like this.
  3. Oct 3, 2017 at 9:28 AM
    Modesto Tacoma
    Modesto Tacoma Well-Known Member
    central california
    LIMITED 4X4
  4. Oct 3, 2017 at 9:33 AM
    Clearwater Bill
    Billy
    Largo Florida
    You didn't bed the pads properly.
    http://www.stoptech.com/technical-s...ions-and-procedures/stock-brake-system-bed-in
    Rotors don't warp.
    http://www.stoptech.com/technical-support/technical-white-papers/-warped-brake-disc-and-other-myths
    It's possible that you could make a few hard stops, short of ABS engagement, and clean up the rotors.
    Otherwise, at such low mileage, take it in for a warranty claim. Yeah, brakes are a wear item, so they may deny you, but then again, maybe not.
    Also there have been some mis-cast rear drums (out of round) that folks have had replaced too. Just so you are sensitive to the pulsation location.
    tonered likes this.
  5. Oct 3, 2017 at 9:33 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    If at a stop after some decent braking, do not stand on the brake pedal. It will transfer an excess of material to the rotor causing an uneven spot that can be felt. You can sometimes see this as the outline of the pad on the rotor. This can be cleaned up by doing some hard, but not ABS, slow downs (50mph to 5mph).
    Also, check your lug nuts for even torque. Even torque is needed to true the rotor.
    If that doesn't solve it, it might be warped rotors.
  6. Oct 3, 2017 at 10:00 AM
    Steve0ct
    CT
    Thanks for the quick replies guys. I had no idea about a bed in process.
    The pulsation does feel like the pulsing ABS makes.
    I'll try a few hard stops and see if that clears it up.
    Thanks again,
    tonered likes this.
  7. Oct 3, 2017 at 10:02 AM
    Exracer2
    Exracer2 Well-Known Member
    Colchester Ontario
    2017 TRD Off-Road Alpine White ACLB
    BRO grille, KICKER speakers, Key amp, Hideaway sub
    I believe the operation manual states no hard stopping for the first 500 km or whatever that is in miles.
  8. Oct 3, 2017 at 1:10 PM
    TacoRD16
    TacoRD16 Well-Known Member
    Houston, TX
    2016 Tacoma TRD Off Road 4x4
    Fox 2.5 RR C/O Fox 2.0 RR Rear Dakar leaf Pack Headstong Brakeline Extension Bracket 16"Konig Countersteer wheels BFG's KO2 285/75r16 All-Pro UCA 1.25" All-Pro APEX Slidders Unided CB w/ Firestick II Lamin-X fog Lens 1" Diff Drop OME 1/2" CB Drip OME Mobtown 3/16" Skid plates: Front, Trans and Transfer case Relentless Hood Brackets AuxBeam Ditch Lights DBCustons Grill "Recolored" Matt Black Relentless High Lift Mount Softopper Diff Breather Mod Tail Gate Inserts HondoGarage Tablet Vent Mount Weather Tech Floor Liner
    The pulsation is from the electronic brake booster only found in the offroad and I believe TRD Pro. Since the truck can apply its own brakes under crawl control it requires electronic booster and what you are feeling is the electronic aid, along with I believe manual hydraulics, system designed with rotor and drums and a bit of downshifting flares.
  9. Oct 3, 2017 at 2:13 PM
    MandosTaco
    MandosTaco Well-Known Member
    Armando
    Redding, CA
    2017 Tacoma TRD Off Road DCLB - Blue Pearl
    TRD Pro Fox takeoffs; Wescott TRD Pro lift; ATW4 285's Method 703 -12 offset; TacomaGrilles; OEM bed mat; tailgate vinyl decals; recovery hitch receiver; Subaru Tweeters and Kicker speaker upgrade; derped badges; CoverKing neoprene seat covers; cool stickers and rad patches!
    Does it almost feel like your truck is downshifting as you're breaking and coming closer to a complete stop?
  10. Oct 3, 2017 at 2:32 PM
    Steve0ct
    CT
    Thanks again guys. It does not feel like it’s downshifting.
  11. Oct 3, 2017 at 10:26 PM
    chugach
    chugach Well-Known Member
    Durango, CO
    2017 Off Road here. I've noticed the same sensation the OP has. An electro-mechanical feeling pulsing in the pedal at odd times, when initiating braking and upon startup (sometimes).
    I believe TacoRD16 is right.
    OP, you have an Off Road or TRD Pro?
  12. Oct 4, 2017 at 12:34 AM
    Toyo_newb
    Toyo_newb Well-Known Member
    Matthew
    2017 DCLB TRD OR 4x4 QUICKSAND
    I had this going on in my OR, but it went away after I had driven the truck for a while, maybe 1k miles or so. I've read of others having the same issue, but can't remember any consensus being reached. I'd take it to the dealer, or just ride it out like I did and see if it goes away.
  13. Oct 4, 2017 at 1:47 AM
    Steve0ct
    CT
    I have an Off Road
  14. Oct 4, 2017 at 4:31 AM
    TacoRD16
    Houston, TX
    Or your front needle bearing is going out on the driver side which is starting to happen on mine with 24,000 miles. Only way to temp fix is switch to 4wd below 60 mph in a straight line and drive a few hundred feet and turn off. Usually fixes it for a few thousand miles. I'll replacing mine which I get new gears.
  15. Oct 4, 2017 at 4:46 AM
    tacoflavoredkisses1
    tacoflavoredkisses1 Well-Known Member
    16 TRDOR DCSB (SOLD)
    Jesus Christ there is a bunch of wild ass guessing going on.
    OP, it's the brake booster. Does it feel a bit like a cell phone going off under your foot? If you get it real quiet can you hear something electric actuate when it happens?
    You can induce the behavior by pumping the brakes. On the 3-4th push it will pulsate/vibrate.
    Here's the thing: Toyota will tell you it's normal. That's half true. It shouldn't be too harsh or obvious; it shouldn't happen very frequently.
    Mine was pulsating/buzzing like crazy (ie every other low speed braking press it was bzzzzt). They replaced that entire assembly and made it much less noticeable.
    Good luck. It's a stupid design and Toyota should be embarrassed that they can't sort out something that's been "solved" for a hundred years.
    Tig3r_Bit, Steve0ct[OP] and fdbyrne like this.
  16. Oct 4, 2017 at 5:32 AM
    fdbyrne
    fdbyrne Well-Known Member
    Missouri
    2016 Tacoma TRD Off Road (Manual), 2004 4RUNNER V6 4x4
    I'll just add that this isn't a new thing for Toyota, it's just new to the Tacoma. My 2004 4Runner has the same system. I thought it was odd at first but it works well. The buzzing is the motor building boost pressure so it can apply the brakes when it feels the need. It's on the OR models because it can apply the brakes to individual wheels to prevent them from spinning and redirect power to the wheels that aren't slipping.
  17. Oct 4, 2017 at 1:30 PM
    Steve0ct
    CT
    Thanks for the replies. Yes, it kind of does feel like a cell phone vibration/pulse.
    I guess I’m satisfied in knowing it’s somewhat normal.
    Seems like the booster should be something that turns on when using the MTS controls. To have it on all the time is a little annoying.
    Thanks again everyone.
    -Steve
  18. Oct 4, 2017 at 4:01 PM
    Riding Dirty
    Riding Dirty Sinner; saved by grace
    Before: '16 TRD OR 4x4 AC QS//After: 17 T4R Pro 040
    PlastiDip
    Yup, brake booster. My OR did the same, and my 4runner pro does it too, just a little less noticeable than the taco did.
  19. Oct 14, 2017 at 11:59 AM
    greengs
    greengs Well-Known Member
    AB, Canada
    2022 Tacoma Pro, 2023 Gladiator Mojave, 89 W126
    I have an off road. Just got it a few days ago and noticed the pedal will randomly pulse coming to a stop at low speeds. My brother has a 2003 4Runner and he says it does the exact same thing.
  20. Feb 12, 2021 at 4:56 AM
    Lscates03
    Lscates03 Active Member
    Luke
    2002 Red Tacoma TRD & 2018 Cement Gray TRD OFF ROAD
    I just bought a 2018 OR with 50k miles. Truck did great on the test drive. Afterwards I tried out the crawl control just for fun. Ever since I’ve noticed this issue... I’m assuming the crawl control was never used by the previous owner and my tampering simply started the inevitable....
    I imagine the brakes need a quick once over either way but it seems this issue pertains more towards the electronic braking.
    Thank God for TacomaWorld... this site always gives me a course of action/piece of mind.
