Pulling out a tree stump?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by oldschoolczar, May 31, 2017.
  1. May 31, 2017 at 4:28 PM
    oldschoolczar
    oldschoolczar [OP] Well-Known Member
    '16 DCSB TRD OR
    So I was thinking about wrapping a chain around this small tree stump and trying to rip 'er out in 4LO. It's about 8" diameter. Think this is doable without fucking up the truck? I'd just chain it up to the rear frame and have a go...
    JWROSE4, MarX and nDub like this.
  2. May 31, 2017 at 4:28 PM
    Paul123
    Paul123 Web-Wheeler
    Paul
    Reno
    2014 TRDOR pyrite mica, 3" lift 33's, 4.56’s
    I'd try it
  3. May 31, 2017 at 4:29 PM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Your tires should spin in the dirt before you break anything
  4. May 31, 2017 at 4:29 PM
    Broccoli
    Broccoli Well-Known Member
    Airdrie Alberta
    2016 trd sport blazing blue,
    Put your strap through the receiver on a pin not the frame.
  5. May 31, 2017 at 4:32 PM
    oldschoolczar
    '16 DCSB TRD OR
    How's bouts on pavement? It's right next to my driveway... don't wanna tear up my piece of shit yard.
    JWROSE4, boondoc89 and Guerrilla like this.
  6. May 31, 2017 at 4:33 PM
    smitty99
    Scottsdale
    I pulled out way worse but that was with my old bulletproof 4.0L Ford Ranger, and she had plenty of low end torque.
  7. May 31, 2017 at 4:36 PM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    This is a horrible idea, if you try it like this you will bend the pin and be screwed.
    Take a pickaxe and break up the ground around it first
  8. May 31, 2017 at 4:36 PM
    IronPeak
    IronPeak PermaLurker
    AuggieX
    Back to Back
    2007 sr5 4x4 DCLB/2015 TRD sport 4x4 DCLB sold
    Bigger Taller Slower
    Subbed for the video
    lynyrd3, Toynado and Spare Parts like this.
  9. May 31, 2017 at 4:37 PM
    smitty99
    Scottsdale
    o_O:facepalm:
  10. May 31, 2017 at 4:51 PM
    SWB Tacoma
    SWB Tacoma Well-Known Member
    Arkansas
    2017 Tacoma Limited DC AT SB 4x4
    If it doesn't work. Take an axe an cut roots all way around. An it will. Hope you don't bend that pin you would be able to pull 5000 lb trailers any more. :ballchain:
    Kilokato and tacofish like this.
  11. May 31, 2017 at 4:52 PM
    Broccoli
    Airdrie Alberta
    I thought it be better than the frame, since these things tend to bend/twist with only slight weight/impact.
    Guess not, i retract my statement...
    Sauer Taco likes this.
  12. May 31, 2017 at 4:53 PM
    boynoyce
    boynoyce .
    16SR5AC4X4V6QS
    I have done this with my old truck a few times. It is important to loosen the ground beforehand and get the chain as low as possible/ under is better. Just go slow, and when it starts to go, it will probably go quick.
    Good luck!
    Krucen 01 and J Bumble like this.
  13. May 31, 2017 at 4:55 PM
    TinyTech626
    TinyTech626 reverses st. signs & steals everyone's left shoe
    Liz
    Bucks Co, PA
    05 TRD AmoCat
    Stuff. Things.
    Did it several times, used a Bubba rope and the front tow hook / rear hook ups depending where the stump was.
    Most of them were of similar size
  14. May 31, 2017 at 4:55 PM
    TinyTech626
    Liz
    Bucks Co, PA
    05 TRD AmoCat
    Stuff. Things.
    But like everyone said, cut as much of the roots as you can
  15. May 31, 2017 at 4:55 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    What's up with the shoe?
    NickleCityTaco and BassAckwards like this.
  16. May 31, 2017 at 4:56 PM
    daddy_o
    daddy_o Well-Known Member
    Bossier City, La
    2018 TRD Sport, Inferno, w/tech package
    Factory Blackout package, Soft roll up bed cover, Cheap seat covers, Front and rear dash cam, AVS in channel vent visors
    Next post from OP, Anybody have a 3rd gen tailgate for sale?
    Just dig around it and chop the roots you can get to and go slow, or
    Remove your tailgate and give it a good yank and it will load itself in your bed.
    In for video.:thumbsup:
    Krucen 01, over60, Braves95 and 2 others like this.
  17. May 31, 2017 at 4:56 PM
    jsi
    jsi Well-Known Member
    native earthling
    Uh, yeah, that stump ain't coming out with your little Toyota. :rofl:
    Here's a full size truck failing to pull a stump of about the same size:
    and I can't find the link but there's a video out there where some clown hooks on to a stump and has a bunch of slack in the rope. He then proceeds to give it full throttle. Let's just say very bad things happen when then end of the rope is reached.
    All that said here's how to remove a stump like that without damaging you or your truck. Hook onto the stump and pull on it good and tight. Keeping tension on the rope put it in park. Then dig around the base cutting all of the roots that are under tension. In my experience it will only be one or two. Then get back in the truck and repeat the process. It ain't as sexy as just popping the stump out in one pull, but in the real world that never happens anyway.
    R11B, Krucen 01, BlakeM and 5 others like this.
  18. May 31, 2017 at 4:56 PM
    Guerrilla
    Guerrilla L(.)(.)K@G(.)(.)Dz
    D. Cooley
    Coast to Coast
    El' Black 13 DCSB 4x4
    Stuff
    :laughing:
    DO IT anyway, it needs to be tilled. Might as well do it with your truck tires.
    Please do video and post here.
    DrFunker likes this.
  19. May 31, 2017 at 4:57 PM
    TinyTech626
    Liz
    Bucks Co, PA
    05 TRD AmoCat
    Stuff. Things.
    Size reference?
  20. May 31, 2017 at 4:57 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    Yeah, but we don't know what size the shoe is haha.
