Puddle on the passenger floor mat, crank/no start, Win the DTC Lottery!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tirediron, Oct 12, 2020.
  1. Oct 12, 2020 at 2:55 PM
    tirediron
    tirediron [OP] Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    So for the last two nights we've had some pretty serious rain, and I had my truck (DCLB, Sport, V6, Auto) parked in a fairly pronounced (but not crazy) nosed down aspect. When I went to get something out of it yesterday, I noticed a puddle on the passenger floor mat, maybe a couple of tablespoons worth of rain water. I poked around for a couple of minutes with a mirror and inspection camera, but it was raining so much I didn't put a lot of effort in to it. This morning, leaving for a job in town, crank...start for about 2 seconds, die and then.... no start at all. Cranks fine, and after I pulled a battery cable off, it started once more for about two seconds and stopped, and that's it.
    It's throwing the following codes (some of which may be the result of the battery disconnect and not cleared since the truck hasn't restarted):
    P1604 - Startability malfunction
    B279986 - Immobilizer system signal
    U0163 - Lost comms with nav control
    B150A - Lost comms with HMI LAN
    B1206 - Power Window Master ECU comm stop
    B1244 - Light Sensor Circuit
    B231 - Driver Door Motor ECU comm stop
    U0142 - Lost comm with BCM 'B'
    U0155 - Lost comm instrument cluster control moduel
    U0140 - Lost comm with BCM
    Because of the sheer number of DTCs and the water on the floor, I'm guessing that one of the connectors in the passenger side dash area got a little moist and cranky - I don't have access to my Mitchel's ATM, does anyone have wiring diagrams that they could post that might shed some light on this?
    I'm not overly fussed as I'm still under warranty, but it's a HUGE PIA to get the truck from where I am to the dealership, get that all dealt with, etc.
  2. Oct 12, 2020 at 3:00 PM
    Juliet Lima
    Juliet Lima Well-Known Member
    I feel your pain.
    Exact same issue with a Cherokee a couple years ago. Turns out the drain grilles at the bottom of the windshield were clogged and the overflow was coming down the inside passenger footwell (wtf) and shorting out a panel buried in there.
    Wasn’t obvious until I lifted the hood and really looked. Don’t know if it’s the same for a Tacoma but it is the exact same symptoms I had. Good luck.
    tirediron[OP] likes this.
  3. Oct 12, 2020 at 3:00 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Oh, Man
  4. Oct 12, 2020 at 4:16 PM
    tirediron
    I'm pretty sure the solution is simple, getting to it might be a HUGE pain though....
  5. Oct 12, 2020 at 4:20 PM
    Bishop84
    Bishop84 Well-Known Member
    I've gotten lucky with this recently on a sienna.
    Remove the right lower kick panel, blow out all connections one by one. Remove glove box and inspect for water damage to ecu.
    TnShooter and tirediron[OP] like this.
  6. Oct 12, 2020 at 5:05 PM
    wopdego
    wopdego Well-Known Member
    Jarret
    East Bay
    BlackPRO
    Nitro 5.29's
    No fun :(
  7. Oct 12, 2020 at 5:33 PM
    tirediron
    Nope, especially when I know exactly how to load all my gear into my truck and where it goes. Trying to get all the kit you fit into a double=cab pick-up into a Mustang is a challenge.
  8. Oct 13, 2020 at 6:42 AM
    tirediron
    On a different note - can anyone think of anything that they might push back on as far as a warranty claim?
  9. Aug 30, 2024 at 1:35 PM
    John taco
    John taco Well-Known Member
    JT - Johnny
    King of Prussia PA
    Any update with fix? I am having the exact same issue. Water enter my passenger side after a huge storm and truck will crank over strong but will not start. toyota diag came back with malfunction code b279986
