PS Belt Tensioner Pulley
Discussion in '1st Gen. Tacomas (1995-2004)' started by DNTaco, Jun 15, 2020.
  1. Jun 15, 2020 at 9:23 AM
    DNTaco
    DNTaco [OP] Member
    '03 XtraCab 2.7L 5spd
    I'm hoping the parts gurus here can point me in the right direction. I'm changing my belts in the near future, and experience on other cars has taught me that after 150K, the idler pulley bearings are shot, or pretty close. So I figured I would replace as a PM. I found the AC pulley easily enough, but the PS pulley only comes with the bracket for an insane amount of money.
    Is there a pulley only replacement for the PS pulley? Are the AC & PS idler pulleys the same? PS pulley & bracket part number is 44350-34010.
    Thanks all!
  2. Jun 15, 2020 at 9:26 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    You should be able to get the bearing number just replace the bearing
    Abeyancer likes this.
  3. Jun 15, 2020 at 11:55 AM
    DNTaco
    DNTaco [OP] Member
    *That* is a great idea! I just assumed it wasn't replaceable. Thank you!
    Wyoming09 likes this.
  4. Jun 15, 2020 at 1:52 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    I have been doing that for 30 years .
  5. Jun 15, 2020 at 2:44 PM
    Glamisman
    Glamisman Well-Known Member
    yes to he bearing replacement... a "competent" parts guy at O' Reilly should be able to source a bearing for you... you could always try to find one on Amazon but the bearing quality from most suppliers is poor as they are Chinese made bearings. You want a Japan or US made bearing double shielded.
  6. Jun 15, 2020 at 2:46 PM
    0xDEADBEEF
    0xDEADBEEF Trash Aficionado
    2000 reg cab 4x4 flatbed MT
    Which engine? The ones on my 2.7 were identical.
    And one of them I could change the bearing on, it had a nice snap ring. The other one had a plate welded in and no slot for a snap ring. It got replaced with one that does.
  7. Jun 16, 2020 at 10:10 AM
    DNTaco
    DNTaco [OP] Member
    I have the 2.7L engine as well. I think my strategy will be to buy one replacement AC pulley, and compare with the PS pulley when I take that off. If same, then buy a bearing for the AC pulley. If for some reason different, measure & check number, and get a new PS pulley bearing. If really crazy, like not replaceable and different figure something else out. Both pulleys definitely have some play with belts installed and tensioned.
