Pros/Cons of a Split CV Boot
Discussion in '2nd Gen. Tacomas (2005-2015)' started by byrdman970, Aug 18, 2024.
  1. Aug 18, 2024 at 7:12 PM
    byrdman970
    byrdman970 [OP] New Member
    2014 Tacoma TRD Sport
    2.5 Inch Bilstein Level kit
    I want to replace my torn inner boot on both my CV axles, Tacoma 2014.
    After some research I've seen several types of boot replacement methods. The Split CV Boot seems like a cheap and efficient way to replace a CV Boot, but is it actually effective and will it last? If I could get a few years out of it that would be fine, not doing any heavy off-roading. Does anyone have any experience with these? Or should I go with the standard boot replacement? I know cleaning the old grease out is an issue but I'm open to suggestions.
    https://www.amazon.com/dp/B0080DLLIY/
  2. Aug 18, 2024 at 7:26 PM
    dtaco10
    dtaco10 Well-Known Member
    Dave
    Anoka County, Minnesota
    2010 White Tacoma 4x4, 4.0, Auto
  3. Aug 18, 2024 at 7:51 PM
    OldSchlPunk
    OldSchlPunk A legend in my own mind!
    Rich
    East Central Wisco
    '17 OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    Having used them in an emergency in the VW world, I'd say go with standard boots. It's hard to not get grease or dirt on the split boot when putting it over the axle. Any dirt/grease will cause the seam to not seal properly/glue not hold. Take the time and do it properly or do it again.
    Mully and mattrussmill like this.
  4. Aug 18, 2024 at 7:53 PM
    mattrussmill
    mattrussmill Well-Known Member
    2015 SR5 DCSB
    As a teenager, I did this repair on a Ford Explorer I owned. However the split boot design was different. It was more like the one I have linked where you adhere the two sides where one side fits inside a channel on the other side: https://www.amazon.com/Dorman-614-256-Constant-Velocity-Joint/dp/B000C0YAAO
    ^This design inspires more confidence than the one you posted OP. Also if it's not already obvious, this is not a Toyota boot.
    Luckily this is your inner boot - but if you have a lift that's another reason to steer clear of this method. I'd really only resort to these if the joint is straight most of the time (or really-really only in an emergency).
    Mine lasted several months - then my transmission died and I switched to JDM vehicles. The rest is history.
    Anyway - now, being over a decade older, I'd buy a new boot and the boot stretching tool then re-pack the joint with grease. But that's only if for some reason I didn't want to replace the whole joint.
    GilbertOz and OldSchlPunk like this.
