Pros & Cons From Enlarging or Downsizing Your Exhaust Pipe Diameter
Discussion in 'Performance and Tuning' started by Ihatetacomas, Sep 1, 2014.
  1. Sep 1, 2014 at 3:59 PM
    Ihatetacomas
    Ihatetacomas [OP] Because tacomas hate me
    Dylan
    Elko NV
    '12 White LB TRD Sport
    Used @ 23,283 Volant Intake (w/ scoop)(removed August 2016), BAKFlip G2 Tonneau Cover, (drain tube mod), Pop & Lock Tailgate Lock, Stampede Vigilante Premium VP Series Hood Protector, 5lb Extinguisher, Shovel & Axe mounted in bed, Shok Industries Sound Deadener, Mercury: (K62, MGR-1200, MGR-495) Triton 8" Subs, Custom-Made: Sub Box, Speaker Templates, Vapor Barrier, All-Pro Bumper w/Kickouts, hidden trailer hitch, wooden cup-holder Misc: Knukonceptz RCA, speaker, and power wires, Big 3 Upgrade, a very full Husky technician tool box
    I'm interested to hear what people have to say. First post by the way...
    HAVE FUN!
  2. Sep 1, 2014 at 6:27 PM
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    Welcome to TW, Tacomas... :wave:
    I run an aftermarket header so I went with a slightly smaller 2 1/4" OD tailpipe from the factory stock 2 3/8" OD exhaust. It helps the exhaust gases to retain their velocity, because velocity enhances scavenging.
    Greg
  3. Sep 1, 2014 at 6:35 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    I went to a 3" with headers and y pipe..... Had no low end tq. It was like driving a civic. Don't open it up too much!
  4. Sep 1, 2014 at 7:26 PM
    shr133
    shr133 Well-Known Member
    Muskego, WI
    2010 V6 Sport
    K & N filter, 275 70 17 Cooper AT3, OME Nitrocharger shocks, 884 Springs, Dakar leafs.
  5. Sep 2, 2014 at 10:12 AM
    tooter
    Greg
    Los Angeles
    Yes. That's the larger exhaust trade off. You give up low end pull to get top end power.
    Greg
  6. Sep 2, 2014 at 9:22 PM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    Over 30 years ago I did a little drag racing. There was calculation we used for how much pipe was needed after the headers to get correct backpressure. After that the pipe does nothing but move exhaust away from passengerrs. Not much point to this story except to confirm that all the magic happens within a few feet of the heads.
  7. Sep 2, 2014 at 10:34 PM
    shr133
    Muskego, WI
    2010 V6 Sport
    For racing, for hp the length is determined where the bluing stops or use a yellow crayon draw a line on the pipe and where it stops melting is the proper length.
    Biscuits likes this.
  8. Sep 3, 2014 at 12:27 AM
    tooter
    Greg
    Los Angeles
    It's more than backpressure alone. It's also the timing of the reflected exhaust pulses travelling back to the exhaust ports which creates the scavenging effect. The greater the exhaust gas velocity, the more powerful the scavenging effect. Larger pipe diameters slow down the flow, and reduce the scavenging effect.
    Greg
  9. Sep 6, 2014 at 10:56 PM
    Ihatetacomas
    Dylan
    Elko NV
    Very interesting... I'm going to make another thread on this but since I have the question in my head, what's 49 states legal? Or does it come down to what can you get away with?
  10. Sep 6, 2014 at 11:43 PM
    tooter
    Greg
    Los Angeles
    It means that it's legal everywhere except California.
    Everything comes down to what you can get away with. ;)
    Greg
  11. Sep 10, 2014 at 3:00 PM
    Ihatetacomas
    Dylan
    Elko NV
    Ok so I just measured my tacoma's exhaust and I measured a 2 1/2 inch diameter with a 3 inch tip. Is this normal? I bought this preowned from a dealership and it only had 28,XXX miles on it, I don't think whoever had it would spend that much on an exhaust and only keep it for 2 years... By the way there's no logo anywhere on the exhaust...looks pretty stock to me.
  12. Sep 11, 2014 at 5:31 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Later year Tacomas (at least the 6 luggers) are reportedly getting 2.5 exhaust piping stock. Not sure what year they changed, but I know my 09 is 2.25. So updating one of these 2.5 stockers makes even less sense then on the earlier models. Just get a new muffler welded on if you want more sound, or if you do want more high end at the expense of low end, move up to a 3".
  13. Sep 15, 2014 at 11:22 AM
    Ihatetacomas
    Dylan
    Elko NV
    I think ill stick to stock for now, at least until I become a brain surgeon and can actually afford the supercharger
  14. Sep 15, 2014 at 11:31 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    It's kind of like inhaling air through a super thick straw. If it's too thick, you aren't going to get a whole lot of airflow going through it. If it's too thin it will be more difficult to move air and you will essentially choke yourself. Exhaust piping should be setup according to the horsepower/torque that the engine is capable of putting out. Anything over and you aren't helping anything.
    Matter of fact, with our given HP/TQ #'s 2.25" piping is more then adequate. Hell My 440HP/425TQ 2005 GTO ran 2.5" piping and that size was more then plenty to satisfy it's power needs.
  15. Sep 15, 2014 at 11:36 AM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    2.5" duals on the GTO though, not a single out, right.
  16. Sep 15, 2014 at 11:47 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Correct, duals attached to an X then at which point split up again at the exit and went out as duals.
    Oh I forgot, we don't run duals. Lol.
  17. Sep 15, 2014 at 11:57 AM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Yup, that's my point. But for the close to stock Tacoma, the point is still valid 2.25-2.5 is adequate, while 3" starts moving the flow characteristics to a higher rpm.
  18. Sep 15, 2014 at 12:09 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Yeah. I still believe that 2.25-2.5" is more then adequate for a stock non supercharged Tacoma. 2.5" probably being the better size for it.
  19. Sep 15, 2014 at 12:17 PM
    BamaToy1997
    Bill
    Navarre, FL
    I would suggest talking to a proctologist before getting your exhaust pipe enlarged OR downsized. Just to be sure it was safe to do so. :D:D:D:D
  20. Sep 15, 2014 at 12:21 PM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Not downsized,,, rejuvenated.... :eek:
