Pros and cons with traditional side steps vs predator style steps
Discussion in '3rd Gen. Tacomas (2016-2023)' started by sureshot, Apr 9, 2023.
  1. Apr 9, 2023 at 7:23 PM
    sureshot
    sureshot [OP] Well-Known Member
    Middle TN
    2016 TRD Sport
    Nothing yet...
  2. Apr 9, 2023 at 7:28 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    pro:
    you can get into the truck easier.
    con:
    opinions are like assholes, and everyone's got a stinky one.
    musicisevil and skippyscage like this.
  3. Apr 9, 2023 at 7:38 PM
    Rollo67
    Rollo67 Well-Known Member
    Depends on how much (or how serious of) off roading you plan on doing. I've always been terrified of ripping my predator steps off if I drag. But they do allow shorter/older people to get in the truck easier (especially if its lifted..). I think proper sliders are more practical all the way around, just more expensive.
    skippyscage likes this.
  4. Apr 9, 2023 at 7:48 PM
    Hugh_Jaynus
    Hugh_Jaynus Well-Known Member
  5. Apr 9, 2023 at 7:55 PM
    MadKatt
    MadKatt In need of serious help..
    Frozen Midwest Tundra
    2019 TRD OR DCLB Calvary Blue
    If you live where it snows a bunch you end up with very large frozen chunks on the front edges of the steps you don’t get this issue with sliders. But if you want an easy in easy out steps are great if you want a chance to rip them off go off roading. Personally I opted for sliders more $ but way more useful overall.
    OZ TRD likes this.
  6. Apr 9, 2023 at 8:30 PM
    old.shopteacher
    old.shopteacher Active Member
    2022 Tacoma TRD Sport AC MT
  7. Apr 9, 2023 at 9:03 PM
    RichochetRabbit
    RichochetRabbit Ping Ping Ping
    Only reporting existence of, not offering an opinion (as it is probably wrong). RCI offers sliders (no surprise), but an option is a plate on the more-or-less open bars and an option to angle the sliders closer to "flat step up". Flat bottom to sliders instead of steps hanging down.
    Reject as just noise or consider seriously, as you decide to ...
  8. Apr 9, 2023 at 9:37 PM
    skippyscage
    skippyscage Well-Known Member
    2023 Tacoma TRD Off Road
    and then you end up with loads of dirty melted snow (water) in your garage - I make sure I brush them down before I park in the garage now when the snow is stuck
  9. Apr 9, 2023 at 9:40 PM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    I kept hitting my shin on the steps so I got rid of mine.
  10. Apr 10, 2023 at 12:05 AM
    23MGM
    23MGM Well-Known Member
    2023 TRD Off Road
    Does anyone know the difference between the Rough Country SR2 and SRX2 side steps? It looks like they are both adjustable and fit the same. I'm considering those because they're adjustable. They're a little more expensive though.
  11. Apr 10, 2023 at 12:35 AM
    Vjustinc
    Vjustinc Talk Nerdy to Me
    City of Angels CA
    2021 Toyota Tacoma (it's white)
    I have the predator like type on mine. Mostly cause I have my parents with me and theyre older so they find it easier to go in and out of the truck. My brother in law has the rock slider kind and they feel like because there isnt a "step" they have a hard time getting out specially
  12. Apr 10, 2023 at 4:34 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    I have the OEM Predator steps.
    Pros: my petite smoking hot trophy wife can get in and out of the truck.
    Cons: my petite smoking hot trophy wife can get in and out of the truck.
  13. Apr 10, 2023 at 6:12 AM
    sureshot
    Middle TN
    2016 TRD Sport
    Nothing yet...
    Thanks for the opinions. I'm not going to be doing any major off roading, and mostly off roading when I go camping or have to pull something on the farm, so no rock sliders... I'm 47 and my new truck has larger tires on it and I want help getting in and out of the truck.
    From what info I have recevied, I think I will go with the predator style steps.
  14. Apr 10, 2023 at 7:33 AM
    RichochetRabbit
    Remove the predators from the driver side only.
    BC Hunter and sureshot[OP] like this.
  15. Apr 10, 2023 at 7:39 AM
    Ballz
    Ballz Well-Known Member
    Bfe SF Bay
    2023 Ice Cap Taco TRD Pro
  16. Apr 10, 2023 at 7:47 AM
    Firn
    Firn Well-Known Member
    White OR
    Opinion incoming
    Most steps are not low enough to be truely helpful and end up just being more in the way. The farther out they stick, and the lower they hang, the more helpful they are.
    I don't have predator steps but I have a similar design, they actually make getting into the truck more difficult than anything else. I end up stepping over them to get in and sometimes brush up against them getting my pants dirty (office worker). Ultimately they are still too high to comfortably get into the cab and the small step area makes them a bit hard to get your foot in the correct spot. My wife (passenger) also find them less than helpful. My 9yr old on the other hand can use them and they help there (the reason I have them), rear grab handles off the front headrest assist with this.
    I expect running boards are better in this regard, although from what I have seen here are not significantly better.
    The AMP research ($$$) power steps get up and out of the way but also come down lower and farther out than a traditional step. If you can afford the money its the best of both worlds.
  17. Apr 10, 2023 at 7:50 AM
    Ballz
    Bfe SF Bay
    Yeah. The AMP Research are sweet! Had those on my big boy tundra.
  18. Jun 28, 2024 at 9:39 PM
    Amorak
    Amorak Well-Known Member
    2021 Magnetic Gray Metallic Tacoma TRD OR DCSB Premium
    YES!
    I am done w/ dirty pant legs (from the steps) and the mud and massive ice/snow holders (picks it up from snowy roads) that are Predator steps (when I took them off they had dried packed mud inside the steps as well). I kept them on so long as I'm on gravel roads a lot, as they help deflect stones, etc.
    Saw these offered on Extreme Terrain - as I never seen them before. Nice look. Then cheaper elsewhere, still cheaper on Amazon, and finally I bought from Iron Bison direct for $259 ($10 cheaper than Amazon) and free shipping. Got here in about 4 days. They are very solid, easily installed, and I really like the crinkle black finish. And unlike Predator steps, they are indeed perfect height to truly defend against door dings.
    Rollo67 and Ballz[QUOTED] like this.
  19. Jun 28, 2024 at 9:43 PM
    offroadguy651
    offroadguy651 Well-Known Member
    The North
    2023 TRDoffRoad
    5100's 1.5 front. 1 inch Eibach block in the rear. KO3 285/70/17 RRW RR6-H 17x8.5.
    They both suck
    petethemeat likes this.
  20. Jun 29, 2024 at 7:52 AM
    Ballz
    Bfe SF Bay
    They look sweet on your Taco! I also bought a set for my new 24’ Trd Pro 4Runner IMG_1601.jpg
    Amorak[QUOTED] likes this.
