Pros and cons of spindle lift w 3 in suspension lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LiveFreeOrDie2015, Feb 7, 2016.
  1. Feb 7, 2016 at 6:38 AM
    LiveFreeOrDie2015
    LiveFreeOrDie2015 [OP] Well-Known Member
    York PA
    15 DCSB TRD OFFROAD
    3in lift,Fox suspension,chaos UCA,AAL,leer 180 topper,SilverStar zXe headlights & fog lights,BAMF kickout sliders,Mobtown full skids,Pelfreybuilt center hoop, Pelfreybuilt Gas Tank Skid,50" curved LED light bar, Hood scoop LED, Tran cooler and fan,Oil Catch can,LED Strip lights under hood & Bed,
    I'm trying to find some info on added a spindle lift to my truck. I have 3 in lift w fox over-coils
    Now and was hoping to gain more ground clearance and lift without going with a 6in lift kit.
    After my 285s wear out I'll be going to 35s but until then.
    Will I see a difference with adding a spindle lift?
    Is there any negatives on going spindles?
    Any off topic discussions on lifts and suspension are welcome
  2. Feb 7, 2016 at 6:45 AM
    Kerleyfries
    Kerleyfries Idk what the hell I'm doing
    Zack
    Lebanon
    ‘17 F150 and SAS ‘98 4runner
    Spindle lift (2wd only) literally just move the hub down 4 inches and retain the factory suspension geometry. So it will ride and feel exactly like it does now, just 4inches taller.
    I have maxtrac spindles with fox 2.0 coilovers and only have about a half inch of preload on my coilovers and it rides great.
  3. Feb 7, 2016 at 7:19 AM
    LiveFreeOrDie2015
    York PA
    15 DCSB TRD OFFROAD
    I saw BDS has 4x4 spindles for 4 & 6in lifts and wasn't sure if they would work without getting the full kit.
  4. Feb 7, 2016 at 7:26 AM
    Kerleyfries
    Zack
    Lebanon
    No, those only work with a drop bracket lift.
  5. Jul 9, 2017 at 9:44 PM
    cnote4l
    cnote4l Gear Tech Customs Vendor
    Cody
    Evergreen, CO
    2016 TRD OR
    *REVIVAL*
    Literally contemplating the same thing. I understand the spindle lift will allow you to maintain the geometry of the stock suspenation. I'm riding a 3in fox coilover in the fronts and wondering if adding a maxtrac spindle lift will add to the ground clearance. Essentially, will the 3in suspension coilovers and a 4in spindle lift add up to roughly 6-7in of lift?
    :cheers:
    ChadsPride likes this.
  6. Jul 9, 2017 at 10:22 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    Yes
  7. Jul 9, 2017 at 10:24 PM
    cnote4l
    Cody
    Evergreen, CO
    2016 TRD OR
    Thanks, I like the stance of your profile pic. What setup you running?
  8. Jul 9, 2017 at 10:26 PM
    desertrunner24
    Jake
    Fresno , CA
    Some
    Maxtrac spindals ADS coilovers set at 1" camburg ball joint uca 1.5" wheel spacers
  9. Jul 9, 2017 at 10:29 PM
    desertrunner24
    Jake
    Fresno , CA
    Some
  10. Jul 9, 2017 at 10:33 PM
    cnote4l
    Cody
    Evergreen, CO
    2016 TRD OR
  11. Jul 9, 2017 at 10:35 PM
    desertrunner24
    Jake
    Fresno , CA
    Some
    I almost bought a db lift before I found it. Sure glad I didn't buy a junk lift like that
  12. Jul 9, 2017 at 10:40 PM
    cnote4l
    Cody
    Evergreen, CO
    2016 TRD OR
    Same main reason I went with my 3in setup. Seems like the maxtrac and a 3in coilover is the way to go for those trying to reach for the sky
