Pros and Cons of Load Range E Tires
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Voos, Mar 10, 2015.
  1. Mar 10, 2015 at 4:38 PM
    Voos
    Voos [OP] Well-Known Member
    Eric
    Albuquerque, NM
    Dbl Cab SB TRD Off Road
    Icon CO's, Total Chaos UCA's All-Pro 3" leaf packs w/ U bolt flip +Timbren, Rear Bilstein 5100's, Dick Cepek DC1's Black, 285/70R17 BFG ATko, ProDryS drop in, Dynomax Super Turbo
    I am wanting to put new 285s on my '15 DC and I(as always) want to go with BFG AT's... and why not KO2's???? Unfortunately, they are ONLY available in load range E!!!..... So, I know they will ride stiffer and are heavier but what are the REAL world pros and cons of running a load range E tire vs a D or C??? The original KO can still be bought in a LR D.....
    Go!
  2. Mar 10, 2015 at 4:43 PM
    reece13
    reece13 Well-Known Member
    North Carolina
    2010 TRD sport, 6spd, 4wd
    Toytec Coilovers, Total Chaos uca's, Wheelers aal+Bilstein 5160's. 285/70/17's, Method Double Standards. Magnaflow exhaust, GrilleCraft grille, Allpro bumper,diff breather relocate, yellow wire mod, oil catch can, weathertechs.
    I have E load firestone MT's. HARD ride for sure. Mine are super hard compound and will last forever and can take a beating, but have not so good sipping for wet weather.
  3. Mar 10, 2015 at 4:44 PM
    Idaholandho
    Idaholandho The other white meat
    3 Now - 2022 Trail Edition, 2015 TRD 4x4 and a 2006 SR5 4x4
    2015 Tacoma, Magnuson Supercharger, Bully Dog Flash and GT, Safari Snorkel, Toytec BOSS 2.5 Coil Over Front, Toytec BOSS Aluma 2.5 Rear, Toytec 10 Leaf Pack, Stainless Brake Lines, Icon UCA's, CBI Reverse Adj Shackle Mounts, CBI Ubolt Flip Kit, Timbren Bump Stops, CBI Bushmaster 2.0 Front Bumper w/ Warn M8000S Winch and SR2 Rigid Flood Lights, CBI Bushmaster 2.0 Rear Swingout Bumper, Rigid SR2 backup lights and Dual RotopaX / Fuel/First Aid Pack, CBI Rock Sliders, CBI Full Skids and CBI Rear Diff Armor, BAMF LCA Skids, FrontRunner Outfitters Slimline II Roof Rack w/ Rigid SR2 40" Combo Light Bar, Rock lights, Rigid pods in Bed Rack, Intelligent Battery System w/ Dual NorthStar batteries, Spod Power Distribution, illuminated switch panel in sunglasses holder, Viar Extreme Duty On-Board Air w/ 2.5 Gallon Tank under bed, Air 2 Air Sys, Magnaflow Exhaust, Fuel Off Road Trophy Wheels, 285/75/17 Toyo Open Country R/T, Diff breather mod, FX-R BHLM Demon Eye headlights, Esuse LED Fog Kit, Pelfreybilt Camera Relocation mount, Pelfreybilt ax/shovel bed mount, Debadged, tint, a 2006 Tacoma SR5 and a 2022 Trail Edition
    Fuel mileage suffers enough without adding needless tire weight.
  4. Mar 10, 2015 at 4:46 PM
    Voos
    Eric
    Albuquerque, NM
    Fuel mileage is definitely a concern(already losing a lot at that size) How much loss is there vs a LR C or D tire??
  5. Mar 10, 2015 at 4:52 PM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    MPG will be lower because of added weight. 10 Ply also cost more. Unless they are needed for heavy loads or rough service they are a waste of money. ;)
  6. Mar 10, 2015 at 4:55 PM
    Voos
    Eric
    Albuquerque, NM
    Actually in a BFG(again, only in the original KO), load range D will cost MORE because they are not as readily available. Usually special order
  7. Mar 10, 2015 at 4:56 PM
    reece13
    North Carolina
    if you're gonna run a 285 like alot of us, you prob aren't THAT worried about mpg to begin with, E load rated or not.
  8. Mar 10, 2015 at 4:59 PM
    Voos
    Eric
    Albuquerque, NM
    LOL!!! I know the pain of running 285's as I did so on my '09... I told myself I'd be happy at 2" and 265s ... BUT I"M NOT HAHA:D
  9. Mar 10, 2015 at 5:02 PM
    Voos
    Eric
    Albuquerque, NM
    .. I figure I'll take what I can get!
  10. Mar 10, 2015 at 5:03 PM
    reece13
    North Carolina
    I think everyone tells themselves that.....and then you do the first mod, then its all over from there!
  11. Mar 10, 2015 at 7:40 PM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    Pros - heavier sidewalls and greater load carrying capacity. Heavier sidewalls are more resistant to cuts. If you arent in the rocks a lot then its a waste. And without a serious upgrade to the suspension our trucks cant carry enough weight to justify the rating. Cons - Our trucks are too light to make the tires properly elongate when airing down. Every pound of added rotating mass impacts the ability to accelerate and decelerate by a factor of something like three compared to an pound of added non-rotating mass. Fuel economy goes down. They ride rougher, especially on washboard roads. Its a shame they dont make more large LT tires in load range D or even C because E range tires generally suck for our trucks. And 99% of the Tacos you see with have sacrificed money and performance for...looks. The trucks will never see sharp, jagged, rocks or carry very heavy loads.
    Sammy's Taco and kap1425 like this.
  12. Mar 10, 2015 at 8:01 PM
    RearViewMirror
    RearViewMirror Saw things so much clearer once you... were in my
    Craig Christ
    State of Love and Trust
    2023 Subaru WRX GT Manual
    I've got Load Range E MT tires. Ride is rougher and mileage has suffered about 2mpg. I take it back country in Colorado and there are jagged rocks that we navigate. That said, I didn't buy my truck for mpg. I bought it to use.
    Kahpo likes this.
  13. Mar 10, 2015 at 8:07 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    I have load range E 275/70/17 Hankook ATm's because rabble Prius
  14. Mar 10, 2015 at 8:09 PM
    Jefes Taco
    Jefes Taco Well-Known Member
    Denver, CO
    14' DCLB TRD Sport supercharged
    Nailed it.
    Unless you need an actual rock tire or haul a truck camper in the bed, go w/ the lowest range tire you can find.
  15. Mar 10, 2015 at 8:12 PM
    AZBACKCOUNTRY
    AZBACKCOUNTRY Well-Known Member
    Doug
    AZ-between the hammer and the anvil
    11' AC TRD OFF-ROAD 4x4
    Pelfreybilt front aluminum bumper,AVID off road weld on sliders, RCI Offroad IFS & transmission Skid (steel), RCI LCA skids (aluminum),upper grillcraft, relentless hi clearance bumper,OEM color matched front grill color, ARE MX camper shell, wet Okole realtree seat covers,pelfreybuilt hi lift mounts,ICON 2.5 Coil-overs extended,, ICON tubular UCA's. Allpro expo leafs, SS extended brake lines.Bilstein 110 extended rear shocks.prinsu Cabrac.dwreck pod mounts OKLED 18w cubes.Baja Designs Squadron-R Sport, LED Wide Cornering, Ambers fog/driving 20" IGGY LED Single Row bar.tepui awning,rotopax 2 gallon, TREDs and mount , 100 watt renogy solar panel.victron 20 amp Bluetooth charge controller,Pro comp wheels - cooper st maxx 285/75/16 tires. Skygear bussman fuse relay smart box. ARB 12v plug hard wired for ARB fridge. Pelfreybilt gas tank skid. Smittybilt X2O 10K winch
    voos you live in the southwest like I do . E rated tires for rough Rocky country are fantastic in this environment. Sure they are heavy , but not really that bad. I say get the kos. I'm running the BFg ats e rated and they've been great / reliable offroad tires.
  16. Mar 10, 2015 at 8:32 PM
    MKW
    MKW Well-Known Member
    Murrells Inlet, SC
    2014 RC 4x4
    OME 3" lift MK6 wheels 285 Fierce MTs & 4.88s!!
    There just aren't many(none that suited me) good looking, aggressive tires in 285 that aren't load range E. Screw mileage, I want my truck to look good.:D
  17. Mar 10, 2015 at 8:37 PM
    slolane
    slolane Well-Known Member
    Chelan, WA
    07 DCSB TRD OR
    I run a load E Cooper STMAXX in 255/85/16... Ride isn't horrible like people make it out to be. Fairly smooth actually. Airs down and gets good sidewall flex while wheeling. No complaints here.
  18. Mar 10, 2015 at 8:56 PM
    steezinstangl
    steezinstangl Well-Known Member
    Elk Grove, Ca
    2008 FJ Cruiser
    buy lighter rims to combat the difference in weight. that's what i am in the process of doing. going from 30lb rims and 40lb tires to 19lb rims and 56lb tires. Only a 5lb difference now. I know rotational mass makes more of a difference, but it shouldn't be too bad.
  19. Mar 10, 2015 at 10:55 PM
    TSJESME
    TSJESME Well-Known Member
    James
    Maui
    14 TRD SPORT A/C 4X4 M/T
    I run 265/70/17/E rated. Lost about .5-1 mpg. I have used these on previous Tacoma, got 80k miles, with more to spare. I like the stiffness in the twisties.
  20. Mar 11, 2015 at 9:12 AM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    As for the "thicker sidewalls resist cutting" argument: if you come across a rock or stick that is going to cleave through a C load tire, it's probably going to go right through an E load just as easily. Even if it doesn't go all the way through, you are now driving around on a tire with a severely compromised sidewall which I consider a bigger safety issue. I'd rather change a tire that went flat out on the low speed trail than have one delaminate on me doing 70 on the highway. If your truck is a designated trail rig, then this isn't a problem. However, if it's your DD, just something to consider.
    Sammy's Taco likes this.
