PROS AND CONS OF A 3" LIFT
Discussion in 'Suspension' started by gome29, Nov 21, 2012.
  1. Nov 21, 2012 at 7:55 AM
    gome29
    gome29 [OP] Member
    mike
    California
    06 PreRunner SR5
    2.5" spacers on front shock mounts, Plasti-Dip stock rims
    I have been doing some research about lifting my truck and i wanted to know what taco owners think about it specifically on our trucks. Whether is about future problems or how badass it's going to look. :)
  2. Nov 21, 2012 at 8:37 AM
    Enzo
    Enzo Well-Known Member
    Opie
    Bedford, Va
    2012 FJ Cruiser
    2012 FJ Cruiser Maggiolina Medium Grand Tour w/winter hood National Luna dual battery split charging system ABR Sidewinder Aux battery tray ARB 50qt Fridge w/Transit Bag Bajarack flat rack w/ladder Crawlarado flat black hood blackout TRD exhaust Trasharoo Outback FJ roof console
    Not trying to be an ass but there must be 8,000 threads on 3" lifts on this site alone. Try the search function.
  3. Nov 21, 2012 at 9:06 AM
    lawless
    lawless the rent is too damn high
    Lawson
    San Jose, CA
    2012 dcsb mgm sc
    i don't think OP is asking about 3" lift rather the pros and cons of a 3" lift. he could search the lift threads and figure it out thorugh hours or research or somone with experience can chime in an attempt to address the pros and cons.
    or perhaps OP is looking for information on 3" lifts in which case the search advice is pretty good :)
  4. Nov 21, 2012 at 9:59 AM
    Enzo
    Opie
    Bedford, Va
    2012 FJ Cruiser
    Yes I know what he was asking. My thing is, somewhere on the internets someone has taken the time to write out tons of info on lifts but people don't think to search. I don't mean any harm. Google is easy.:D
  5. Nov 21, 2012 at 10:13 AM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    Op if you get a 3 inch lift be sure to look into getting new upper control arms like camburg/total chaos etc... If you don't get new uppers then your alignment won't be close to stock. That's the only con I see with getting 3 in lift
  6. Nov 21, 2012 at 10:22 AM
    NiceTaco
    NiceTaco Canadian Redneck
    Ontario, Canada
    2012 TRD Sport
    Aero Turbine 2525, Front bilstein 5100's @1.75, rear 5100's, 1" Toytec rear block, Devil Horns, BGF AT's, 18" Moto Metal 962's
    Search yes but what sometimes comes back with way to many useless threads to what your looking for.. Anyway...
    OP.. From what I have seen and read my ass off on here you will def need new UCA'S. Everyone says stay away from spacers, yet a lot of people use them.. I won't but that's my opinion.. I would say the only con that scares me is the vibration problems some people seem to have. Lots of options out there I am still trying to make my decision! But I am almost there.
  7. Nov 21, 2012 at 10:31 AM
    BAMFTACO
    Juan
    Kings bruh
    Vibration isn't that bad I have it you get used to it but I think 2.5 inch lift all around Would be best cuz then you don't really need to get new uppers and your alignment will be somewhat close to stock. Uppers is optional
  8. Nov 21, 2012 at 10:35 AM
    NiceTaco
    Ontario, Canada
    2012 TRD Sport
    That's a good point, how bad is the alignment issue at 2.5?
  9. Nov 21, 2012 at 10:55 AM
    BAMFTACO
    Juan
    Kings bruh
    2.5 in you can get away with not having aftermarket uppers I have my coilovers set at 2.5 and I don't have any issues.
  10. Nov 21, 2012 at 1:47 PM
    Hairy Taco
    Hairy Taco Jungle of Love
    North of Hell
    08 TRD
    I had alignment issues. Some do, some don't. This has been discussed countless times. Poor alignment can cause uneven tire wear and steering issues. Lifts can create vibration issues and CV issues as well.
    Outside of appearance, I think the main reason to lift a truck is to create clearance for larger tires. Larger tires are what create clearance from the ground.
  11. Nov 22, 2012 at 2:05 AM
    gome29
    gome29 [OP] Member
    mike
    California
    06 PreRunner SR5
    See, your guys' conversation allowed me to learn it alot better and directly :)
  12. Nov 22, 2012 at 2:12 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    pro: more clearance, allows fitment of larger tire, which equates to better offroad ability. Looks
    women also throw their underwear at you, visciously.
    cons-
    increased wear on suspension parts
    larger tires can cause wear on transmission
    larger tires can rub
    larger tires cause loss in MPG
    higher center of gravity means in emergency high-speed manuvers, the truck can roll much easier.
  13. Nov 22, 2012 at 2:19 AM
    the.sight.picture
    the.sight.picture Wishes he was in the woods.
    Nick
    Blue Ridge
    2018 QuickSand
    Check out my build thread (Beginning of Money Pit)
  14. Nov 22, 2012 at 6:34 AM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Pros outweigh cons to most. That's why so many people run a 3" lift. Seriously increases offroad ability is the biggest pro IMO.
  15. Nov 22, 2012 at 8:43 AM
    TruKnight
    TruKnight Well-Known Member
    Tru
    Arkansas
    Autobot Mall Crawler
    read build thread
    pros: looks awesomez
    cons: cost $$$
  16. Nov 23, 2012 at 4:12 AM
    Bussy36
    Bussy36 Member
    Pittsburgh, PA
    08 Tacoma Sport - Speedway Blue
    This is pretty much what has me on the fence about lifting my truck, not knowing how it will wear other parts of the truck (suspension, etc) and the long term reliability/durability for those of us who keep it mostly on the pavement.
  17. Nov 23, 2012 at 5:19 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Personally I do not like 3" lifts.
    No one has mentioned the amount of down travel you lose when you lift 3".
    In simple terms with a basic lift ~ if you lift 3" you lose 3" of down travel.
    My current set up is about 1" of lift. I drive mostly on fire roads where speed is wanted more then clearance. I do drag my skids on a good deal of obstacles, but that's what they are there for. This mild lift is why I run the largest tires you can stuff under a Tacoma without major modifications (255/85/16).
  18. Nov 23, 2012 at 5:25 AM
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2018 Jeep Wrangler JL Rubicon
    Can you post up your set up and where you got it. That is what I am looking to do, I am not a hard core offroader. I go off during hunting and fishing trips but that is also on fire/logging roads
  19. Nov 23, 2012 at 5:31 AM
    XXXX
    sKiP
    05 Prius
    Every truck will be different depending on use and weight. I have front/rear plate bumpers and full ATO skids making it much heavier then a stock Tacoma.
    Front:
    King 2.5 remotes with 700# springs and 1/4" of pre-load (threads showing)
    TC UCA's with FK stainless uni-balls
    Wheelers bump stops
    Rear:
    TSB springs with overload removed
    Wheelers 3 leaf progressive AAL
    Bilstein 5100's (not the extended version but should be)
    Wheelers bump stops with no tower mounted to the frame not the leaves
  20. Nov 23, 2012 at 5:34 AM
    BostonBilly
    Easton
    Thanks. Ya I am stock 2012 just looking for a little height for tires in the future
