Proper way to check lower ball joints?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tah-koh-mah, Feb 24, 2020.
  1. Feb 24, 2020 at 12:53 PM
    Tah-koh-mah
    Tah-koh-mah [OP] Well-Known Member
    2012 Tacoma TRD-Off Road
    What is the proper way to check the lower ball joints on our 2nd gens besides just rocking the tire at 12 o clock and 6 o clock? Do I need to load the LCA before checking?
  2. Feb 24, 2020 at 2:56 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Jack up the corner of the truck and put a jack stand underneath the control arm as close as you can get to the tire without actually touching it. Lower the floor jack so the weight of the vehicle is on the control arm, but not on the tire. This puts the ball joint and the control arm at the same angles where they spend most of their time.
    Then use a block of wood and a pry bar to pry the tire up and down while you check for play. From there you can also take the tire off and use the the bar to pry between the arm and the knuckle in various places around the ball joint, turn the steering back and forth, etc
    If you do it with the control arm drooping the ball joint will be maxed out to the side and often appear tight, even though it is loose.
  3. Feb 24, 2020 at 2:59 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Yes, much better directions. Lol
    I’m more of a shower not a teller. LMAO
    b_r_o[QUOTED] likes this.
