Propane smell coming from my truck
Discussion in 'Performance and Tuning' started by mrfrogdude, Jul 16, 2012.
  1. Jul 16, 2012 at 10:33 AM
    mrfrogdude
    mrfrogdude [OP] Well-Known Member
    Glendale, AZ
    99' SR5 V6 31" BFG AT
    I have a 99 Tacoma and when driving i get a smell almost like propane. Any ideas to what it could be?
    Thanks,
    Mark
  2. Jul 16, 2012 at 4:32 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    You running propane?
  3. Jul 16, 2012 at 5:25 PM
    mrfrogdude
    Glendale, AZ
    No, that's what stumps me....anything that would smell similar?
    Mark
  4. Jul 16, 2012 at 5:47 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Where do you smell it coming from? At idle, from the exhaust, or hood proped with engine running?
  5. Jul 16, 2012 at 6:22 PM
    mrfrogdude
    Glendale, AZ
    I smell it when driving(windows down or up with ac on), usually when I'm going up hills.
    Mark
  6. Jul 16, 2012 at 6:24 PM
    cgrhyne
    cgrhyne Well-Known Member
    Cameron
    Lincolnton, NC
    2002 4Runner (the best 3rd gen)
    Bilstein/OME Lift, 5th Gen Wheels, BFGs, fun stuff... Had a 3rd Gen, twin turbo'ed it (traded in on a F150 Gen 2 3.5 Ecoboost)
    was a diesel truck in front of you?
  7. Jul 16, 2012 at 6:24 PM
    jgwheeler17
    jgwheeler17 I'm a zit. Get it?
    NC
    07 Double Cab TRD Off-Road 4x4
    neglect, mostly.
    :rofl:
  8. Jul 16, 2012 at 6:24 PM
    SoCalTacos
    SoCalTacos Turd runner
    socal
    2017 4Runner TRD Pro
    Led head/dtr lights.
    There's a leaky propane tank in yer car bub.
  9. Jul 16, 2012 at 6:30 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    LoL... I can't imagine anything smelling like propane. Check for leaks around your valves/heads. Are you smoking your clutch?
  10. Jul 16, 2012 at 8:10 PM
    mrfrogdude
    Glendale, AZ
    Wasn't smoking my clutch. I'll have to check around the valves/heads.
    I have a slight leak on my rack and pinion, could the power steering fluid be dripping on anything to heat it and make it smell?
    Mark
  11. Jul 16, 2012 at 8:10 PM
    mrfrogdude
    Glendale, AZ
    Haha nope!
  12. Jul 16, 2012 at 8:13 PM
    03is300ztk
    03is300ztk Well-Known Member
    Zach
    Somewhere in the hills NC
    07 Tacoma 4X4
    Grillcraft, with front and rear bumper/bed in the works.
    Since you have noticed the smell, has anything changed?
    Either you made a change or something no longer functions as your used to?
  13. Jul 16, 2012 at 8:26 PM
    mrfrogdude
    Glendale, AZ
    No changes were made to the truck, and everything works flawlessly. I'm stumped on this one..
    Mark
  14. Jul 16, 2012 at 8:47 PM
    03is300ztk
    Zach
    07 Tacoma 4X4
    Have you had it on a lift since the smell started? preferably with it running?
  15. Jul 17, 2012 at 6:05 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Wud you have for dinner the night before?
    Sorry, cant think of anything helpful.
  16. Jul 17, 2012 at 6:10 AM
    98tacoma27
    Ben
    Not Beech Creek
    It could be:
    -bad battery (see if it is leaking)
    -bad CAT
    -exhaust leak
  17. Jul 17, 2012 at 6:34 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Quit eating so many dairy products. The gas will subside.
  18. Jul 17, 2012 at 8:47 AM
    nut
    nut she'll ride
    Patrick
    Arizona
    Totaled
    TRD SKEWP DCSB 4x4 Silver Mica | URD TCAI/MAF CAL | BHLM | GrillCraft | FF Sliders | LED's All Around | 12v Constant On | EGR In Channel | 15% Tint | Trimmed mud flaps | Fog Light Anytime Mod | Debadged | Tailgate Hoseclamp | DTRL Switch | Disabled Lock Beep/Seatbelt Chime | Husky Liners | HID's | BedRug | WO Seat Covers | ABS Kill Switch | Oil Catch Can | Viper 5704 | Custom Carbon Cabin Filter | Backup Camera Anytime | 400W Anytime | In Cab Outlet W/USB | Firestone Ride Rites | Ams Oil All Around | 32" LED In Lower Grill | BlackVue DR500GW-HD |
    go to the doctor and have your schnoz checked out!
  19. Jul 17, 2012 at 8:53 AM
    Chipskip
    Chipskip N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
    I have a 98 and have experienced this before too.
  20. Jul 17, 2012 at 8:58 AM
    Joels98taco
    Joels98taco Well-Known Member
    joel
    chino hills
    98 5 lug tacoma
    fabtech 3" spindles, icon aal, 10" bilstein 7100 rear shocks, daystar coil spacers, AFE Pro Dry-s drop in filter, sony head unit, 2 12" pioneer subs, pioneer 6.5s all around, custom 1.25 lift shackles, custom lower ball joint brackets fabbed by me
    I get the smell usually going up long hills. I think its just gases other cars and our trucks release. My dads tundra has had it too.
