Prolonged high idle at cold start?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BARE BONES TACO 4X4, Mar 12, 2019.
  1. Mar 12, 2019 at 7:48 AM
    BARE BONES TACO 4X4
    BARE BONES TACO 4X4 [OP] extremely deplorable
    RUSTBELT -N. E. OHIO
    2nd gen offroad
    I had a random bad hesitation on acceleration , and was told to " clean throttle body, and / maybe mass air sensor ". I did both- the hesitation is cured , but , now it has a prolonged high idle at cold start lasting a few minutes. I keep truck in garage , air temp is generally around 40. any ( helpful }suggestions ? and, yes, I,ve already thought of beating the crap out of it with a hammer, so don't go there....
  2. Mar 12, 2019 at 7:59 AM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    Sounds all normal for cold start operation. Define prolonged? Ever time it, should only occur on cold start defined as cold engine not cold ambient temperature. What year? Engine?
  3. Mar 12, 2019 at 8:07 AM
    BARE BONES TACO 4X4
    2nd gen offroad
    2010 , 4 cylinder .- 1100 ish rpm for several minutes -calms down to 6 -800 rpm. I,ll time it later
  4. Mar 12, 2019 at 8:24 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    After cleaning the throttle body it can take a little bit for the idle to settle down into its sweet spot. Take it out and drive it, stop at lots of stop-signs with your foot on the brake, turn the a/c on and off, cycle the steering wheel lock to lock. All of those things will force the adaptive idle to relearn quicker
  5. Mar 12, 2019 at 8:32 AM
    BARE BONES TACO 4X4
    2nd gen offroad
    the cleaning was done 11-28-18 . 1000 miles ago . I have since replaced the air cleaner filter , and recleaned mass air thing in December. I did not remove throttle body for cleaning , maybe I should ?
    b_r_o[QUOTED] likes this.
  6. Mar 12, 2019 at 8:35 AM
    zippsub9
    Halfmoon, NY
    14 DCLB
    If this only on cold start, not cold weather, just first time in the morning on a cold engine then t sounds perfectly normal. I have a 4.0 but it does the same thing.
  7. Mar 12, 2019 at 8:37 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Removing and cleaning both sides of the throttle plate is always a good idea. Probably not going to affect the hi idle youre experiencing though. Honestly it could be normal, as it does eventually settle down to 600-800. Any check engine light/codes?
  8. Mar 12, 2019 at 8:43 AM
    BARE BONES TACO 4X4
    2nd gen offroad
    no check engine light - before the cleaning, the idle calmed down in under a minute. I notice it cause its a 5 speed
  9. Mar 12, 2019 at 8:47 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    how high an idle are we talking?
  10. Mar 12, 2019 at 8:48 AM
    zippsub9
    Halfmoon, NY
    14 DCLB
    Read five posts above yours
  11. Mar 12, 2019 at 8:50 AM
    zippsub9
    Halfmoon, NY
    14 DCLB
    The duration of the high idle will vary based upon ambient temp and how long it takes the engine to reach normal operating temps. But day to day with same morning temps you should not notice a difference if you time it.
  12. Mar 12, 2019 at 9:02 AM
    BARE BONES TACO 4X4
    2nd gen offroad
    ok- its 32 degrees out - truk has been sitting for 2 hours , I timed it
    start up 1500 rpm -( after 1 minute idling , 11-1200}
    - (2 min., 1100 )-( 2.5 min, over 1000-) (3 min, 1000 ) -(4 min, 900 )- (5 min, 800 ) (- 6.5 min, 700)====all sitting idling
    b_r_o likes this.
  13. Mar 12, 2019 at 9:08 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    This may be a long shot, but... try disconnecting your battery overnight, and then reconnect it first thing in the morning before you start it up. I just replaced my battery and did the reconnect first thing in the morning, when the engine is stone cold. The cold start RPM was noticeably lower than it was before. Of course, after a battery disconnect the computer will have to re-learn all the fuel trims similar to what b_r_o said in post #4 above... not sure if all that stuff is necessary (cycle A/C, turn steering lock-lock, etc) but any battery disconnect will require this re-learn procedure for the fuel & emissions system.
    b_r_o likes this.
  14. Mar 12, 2019 at 9:11 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Battery disconnect wont hurt. But its not the fuel trims that need to stabilize, its the actual position of the throttle plate. When you clean the throttle bore you're making a bigger path for air to flow through. The throttle plate needs to adjust (electrically) and pinch off the air flow.
    Adding a/c and turning the steering wheel require the pcm to bump up the idle speed, this forces a relearn quicker.
  15. Mar 12, 2019 at 9:14 AM
    TacomaMike37
    13' DCLB MGM
    A whole lot of nothing OP. Stop stressing over something that is completely normal.
    BillsSR5, TACOGUY23 and b_r_o like this.
  16. Mar 12, 2019 at 9:14 AM
    KalamaKid
    KalamaKid Well-Known Member
    Oregon
    same shit as everyone else
    Sounds like your truck is running as it should...
  17. Mar 12, 2019 at 9:15 AM
    BARE BONES TACO 4X4
    2nd gen offroad
    I,m pretty sure I,ve done the battery thing, but will try again overnite - thanx
  18. Mar 12, 2019 at 9:17 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Agreed.. i know OP is wondering why its different now after the cleaning but its not really a problem, just different
  19. Mar 12, 2019 at 9:17 AM
    KalamaKid
    Oregon
    I’d put some garlic over the hood and a cross in the garage. Might help as much as the battery hocus pocus :fingerscrossed:
    TacomaMike37 likes this.
  20. Mar 12, 2019 at 9:27 AM
    BARE BONES TACO 4X4
    2nd gen offroad
    really - 5 - 6 minutes to get lower / possibly normal idle ????? I think you r waaaay wrong , but thanx for the input.
