Problems with Siri unlock/lock start commands on iPhone
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AMGTRDPRO, Dec 15, 2021.
  1. Dec 15, 2021 at 11:06 AM
    AMGTRDPRO
    AMGTRDPRO [OP] Well-Known Member
    2021 Lunar Rock TRD PRO
    I'm getting this message when I try using the voice commands through the Toyota app with my Iphone.
    sorry, something went wrong. Toyota says sorry could not remote unlock your vehicle.
    Invalid token: Token is not found. Never had this problem. If I go into the app and press the unlock button it works just not the voice commands. I have deleted the app and reinstalled and did a soft reset on the JBL head unit no luck.
  2. Dec 15, 2021 at 5:56 PM
    AMGTRDPRO
    bump any ideas ?
  3. Dec 15, 2021 at 6:54 PM
    outdoor frenzy
    outdoor frenzy Well-Known Member
    Aaron
    Roanoke, VA
    2021 TRDOR DCLB Super White
    Goodyear DuraTracs
    Didn’t even know this was an option.
  4. Dec 15, 2021 at 7:18 PM
    AMGTRDPRO
    Yes if have the option and service just say start my Toyota, Stop my Toyota, Lock or unlock my Toyota. You can even change the phase to anything really like lock my TRD PRO, Lock my truck/Tacoma you just have to change it in the siri shortcuts on Iphone. sucks mine is not working now for some reason. Maybe has to do with an update to the Toyota App and to ios 15.2 I just did.
  5. Dec 15, 2021 at 7:33 PM
    tacovagon
    tacovagon Well-Known Member
    Dan
    Oceanside CA
    2016 SW SR5 DCLB 4x4
    ARB Locker 5100s w OME 887s OME EL095R Camburg BJ UCAs
    Try another Siri command, just say Home depot and see if she finds a list of nearby HDs. I was getting the same "something went wrong" when I tried to navigate and eventually discovered that Siri couldn't do anything. I had to Reset network settings to get Siri working again.
    outdoor frenzy likes this.
  6. Dec 16, 2021 at 8:44 AM
    ThreeBeers
    ThreeBeers Well-Known Member
    Ron
    2020TRDOR
    Mine isn’t working either. I don’t use it very often but I tried it after the iOS 15.2 update and it still isn’t working.
    I will try the iPhone reset later this evening to see if that works but as far as I can tell Siri works fine on everything else.
  7. Dec 16, 2021 at 9:01 AM
    AMGTRDPRO
    same here. Does it give you the Invalid token message? I wonder if it is something in ios 15.2 or the recent Toyota app update that mess with the commands.
  8. Dec 16, 2021 at 9:04 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Invalid token sounds like a Toyota security issue. Might try removing and reinstalling the app, or logging out and back in if that’s an option.
  9. Dec 16, 2021 at 9:22 AM
    AMGTRDPRO
    I have done that multiply times no luck. Even removed the truck from the Toyota app "Garage" and reentered the VIN and all still no luck.
  10. Dec 16, 2021 at 9:25 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    I'd guess it has something to do with that, most likely. The token issue would likely be related.
    tcjacado likes this.
  11. Dec 17, 2021 at 1:07 PM
    AMGTRDPRO
    just submitted feedback via Toyota app. Are you getting the same message about invalid token, Token not found?
    fmb[QUOTED] likes this.
  12. Dec 18, 2021 at 6:27 PM
    Kholdiman
    Kholdiman New Member
    Anyone found a solution? I’m having the same problem
  13. Dec 18, 2021 at 6:34 PM
    Extra Hard Taco
    Extra Hard Taco Well-Known Member
    R.J.
    Devil's Island
    2012 Tacoma TRD OR, 2007 DC (sold), 2003 TRD OR (sold)
    ARB Bumper, SOS sliders, SOS rear bumper, SOS skid plate. OME Lift. Some other stuff.
    Same here, I gotta say though what a terrific way to make something as simple as locking/unlocking your door into a complete shit show.
    WTF
  14. Dec 21, 2021 at 5:32 AM
    rockstardoug
    rockstardoug Member
    knoxville
    21 TRD
    I just updated to iOS 15.2 on my iPhone and everything is working like it should. I tell Siri to start my truck and she does.
  15. Dec 21, 2021 at 5:35 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Usually a reboot of the phone helps.
  16. Dec 21, 2021 at 7:53 AM
    Johnnyredsand
    Johnnyredsand Well-Known Member
    22 Sport Long Box 4X4 Lunar Rock
    I’m on OS 15.1.1 and just tried and got the invalid token message as well. Will try a restart. The Toyota app is functioning like normal, checked that too.
    update: tried restarting phone - no bueno
  17. Dec 21, 2021 at 8:25 AM
    ThreeBeers
    Ron
    2020TRDOR
    I had updated to iOS 15.2 last week and Siri still would not operate the voice command start feature. I was still getting the invalid token message. Today after following this thread, I tried it again and it now works as it should. Thanks for the updates!
  18. Dec 21, 2021 at 9:22 AM
    AMGTRDPRO
    Hey guys mine is fixed! Toyota app has an update available on Iphone and that fixed my problems. version 1.2.7
    fmb likes this.
  19. Dec 21, 2021 at 12:25 PM
    Phenom3030
    Phenom3030 Well-Known Member
    Jon
    Colorado Springs, CO
    2021 Lunar Rock TRD Pro
    OEM+
    Do you have to do anything to set up Siri to use the Toyota app? I tried asking Siri and get the response “you’ll need an app for that. You can try searching the App Store”.
  20. Dec 21, 2021 at 1:42 PM
    AMGTRDPRO
    need the Toyota app and remote connect setup. the siri commands should be preset. You can edit the phrases in the app or shortcuts on Iphone.
