Pro Stick versus Firestick CB Antennas
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2013TacoDCLB, Dec 25, 2021.
  1. Dec 25, 2021 at 8:21 AM
    2013TacoDCLB
    2013TacoDCLB [OP] Well-Known Member
    Mark
    2013DCLB4x4
    Military hitch, CB install, cargo rail brackets
    Hi, are the Prostick antennas any good, or should I just get the Firestick antenna.
    I have used the Firestick before but trying to stretch my upgrade dollars.
    Thanks
    tacotoe likes this.
  2. Dec 25, 2021 at 10:17 PM
    Taco 422
    Taco 422 Well-Known Member
    USA
    Gen 2 AC v6 TRD SR5 Prerunner
    tacotoe likes this.
  3. Dec 26, 2021 at 5:00 AM
    2013TacoDCLB
    Mark
    2013DCLB4x4
    Do you have a picture of how it looks like, mounted?
    tacotoe likes this.
  4. Dec 26, 2021 at 9:24 AM
    No Shoes Nation
    No Shoes Nation Well-Known Member
    2008 Taco SR5 Access Cab 4.0 4x4
    Hmm . . . none as yet, that's why i'm here . . .
    Wilson w5000
    tacotoe likes this.
  5. Dec 27, 2021 at 2:36 PM
    Taco 422
    USA
    Look at any police car...
    tacotoe and FastEddy59 like this.
  6. Dec 27, 2021 at 2:38 PM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    I would assume from the Outside. :ballchain:
    tacotoe likes this.
  7. Dec 27, 2021 at 4:15 PM
    Taco 422
    USA
    From above. I've had arrestees who could see across the roof before getting inside.
    tacotoe and FastEddy59[QUOTED] like this.
  8. Dec 27, 2021 at 4:19 PM
    FastEddy59
    Eddie
    Kinda gives a Whole New Meanin to the term Hard Wired. :)
    Taco 422[QUOTED] likes this.
  9. Dec 27, 2021 at 4:44 PM
    Taco 422
    USA
    Specifically the Larsen NMO27.
    Advantage being: the coax (antenna cable) is out of sight, between the headliner and roof, behind paneling, coming out where you want it; protected from damage. And the performance gains - night and day over anything that's a clamp on.
    Closeup of the mounting, as you can see it's through the roof without any dangly bits.
    Scale pic using an L bracket type "lip mount", same cable/base as above. The performance here will suffer tremendously when compared with the setup above.
    VFpTjv7k1icqkm1tsNW5_atnif8VzYRsrXBU0efT_e487153213406dba89da36aec97726f8d582df32.jpg
    FastEddy59 likes this.
