Pro Grill TSS Cover push nut removal
Discussion in '3rd Gen. Tacomas (2016-2023)' started by thedudeabides22, Sep 14, 2022.
  1. Sep 14, 2022 at 1:25 PM
    thedudeabides22
    thedudeabides22 [OP] Well-Known Member
    2024 Tacoma 4x4 TRD Offroad
    I was wondering if anyone has any tips for removing the push nuts that hold on the TSS cover on a Pro Grill? This is an OEM grill and I need to remove the default cover to put the TSS cover on. The problem is these push nuts are a-holes and I don't want to break the grill.
    Small jewelry screwdrivers don't seem to move it much. I was thinking Dremel and cutting them off, but worried I might cut into the plastic.
    Any tips?
  2. Sep 14, 2022 at 1:35 PM
    Martian__
    Martian__ Well-Known Member
    Southern California
    Get under the washer with a 90 degree pick and bend the tabs out more to loosen the grip on the stud. Also try turning the washer like you’re taking off a nut.
  3. Sep 14, 2022 at 1:37 PM
    SEVtaco
    SEVtaco Well-Known Member
    Orange County
    2021 Tacoma TRD OR
    king2.5s/33s/Deaver/SCS wheels
    heat gun also works great. Heat up and spray WD40 it should pop right out
  4. Sep 14, 2022 at 2:08 PM
    thedudeabides22
    That worked well! Thanks!
    Martian__[QUOTED] likes this.
  5. Sep 14, 2022 at 2:08 PM
    thedudeabides22
    I didn't get that far, the 90 degree pick took care of it! Thanks!
